RysiuM
Joined: 4/22/2003 From: Elk Grove, CA, USA Status: offline
quote:
ORIGINAL: IowaSilvia If it was me. I'd go with 2 sets of hooks on each wing. Use rubberbands to hold them together. 2 heavy bands for each set of hooks. Easy to intall. Bolts, nuts, etc get heavy. I had a Creek Hobbie Extra. Had only one hook on each wing. It held fine. You don't need much as there isn't lots of force pulling the wings apart. Hmm... I didn't know you can do it on such big plane. Nylon bolts are not heavy, just a little more work assembling the plane at the field. I was thinking about two nylon screws on each wing: one just in front of the tube, and the other on the back close to the antirotation pin. First would cancell any slack in the wing tube, the other would make sure the pin doesn't get out of the fuse. But it's still open issue. I emptied the fuselage yesterday. It would be easier to install the wing tube if I didn't have all the enforcement already there. I have to cut some plywood plates (added to the frame in weak points) and replace them with a littel bigger that will hold the tube. Because the wing is bigger I had to move a switch and voltage indicator (now it is covered by new wing). I may move a fueler a bit, but I will know for sure, when I set the wing incidence and ten I will know where the leading edge is. I also tested, that the wing tube will not block the access to the fuel and smoke tanks. I decided to keep original rails that hold the old wing as thy add some sthrength to the fuselage sides. Even if I deside to cut them off, I will replace them with lighter wood (spruce). I fit try the wings on the fuselage, and ot looks like the left side is perfect without even small gap between the fuse and the wing, but on the right side I think I may have 1 or 2 mm gap. But if I use screws to mount the wing, something should flex (wing or fuse) and reduce the gap to minimum. If not, I can use 3mm balsa sheeting on the root rib sanded to the perfect fuselage shape. Now the good news is: WEEKEND !!! The only think o like more than weekend is .. a long weekend RysiuM
_____________________________
Mather Aerospace Modelers, Inc. AMA Gold Leader Club, Charter #1243, Sacramento, CA
