RE: The new Lanier Edge 87"
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: The new Lanier Edge 87"
Page: <<   < prev  13 14 15 16 17 18 19 [20] 21 22   next >   >>
Login
RE: The new Lanier Edge 87" - 2/26/2008 3:08:11 AM
winstone
Status: offline
OK I have another problem , Are you putting your servos on a y harness?? I am and I found out its making my servo arms bounce back and forth after the stroke, why this problem?? I have a 6.0v 4200mah rx pack so the bat has plenty of power, Im using heavy duty y harness's and extensions so the wire is big enough for current, just stumped and really wanna fly this bird. Well on the bright side of things the SV 50cc engine is a sweet piece of art, very powerful and purrs like a kitten, had to adjust both high and low end, runs great!! lol please help me out with the servo problem.
(in reply to T3beatz)
       Post #: 476
RE: The new Lanier Edge 87" - 2/26/2008 3:28:19 AM
Bosco2
Status: offline
Witch servos are they elevator or eilerons,
are the servos 6 volt rated is yore battery pack charged to high, is youre transmiter entena collaps
when you are round the plane, do a range check with the entena down, The servos are they DS or standard,
How do you have your receiver entena wire run threw the fuse,
_____________________________
Having more fun than a human being should be allowed to have.
(in reply to winstone)
       Post #: 477
RE: The new Lanier Edge 87" - 2/26/2008 4:58:06 AM
winstone
Status: offline
All the servos have the problem like they dont have enough power, i unplug one from the y harness and the servo still connected runs perfectly. yes the servos are futaba 3305's and are 6v rated, pack charged to high??? didnt think that would be a prob, doubt it tho. only messed with it inside the house no range checks, antenna wodded up inside fuse right now for easy get to since still workin on plane now. just stummped never had a problem like this, been flying rc for 8 years
(in reply to Bosco2)
       Post #: 478
RE: The new Lanier Edge 87" - 2/26/2008 5:11:45 AM
T3beatz
Status: online
well, I had that prob with my yak 54 with a spe 26cc on it and it turned out to be that the spark plug cap wasn't tight enough. I tried to single out each servo to see if it was causing the problem but that didn't work. I use nyrod for the trottle servo...
Build em Fly em Crash em!!!
       Post #: 479
RE: The new Lanier Edge 87" - 2/26/2008 6:04:58 AM
T3beatz
Status: online
quote:
ORIGINAL: winstone
sorry about the last post didn't know if you were running it at the time are not...
So it seems that the servo your disconnecting is the one causing the problem. U said that when one is unpluged from the y harness the other one connected runs perfectly... are all the other servos running fine once you do this? if so that one servo could be causing the RF. You said it happens on the stroke, is that when the engine is running? or the servo stroke? check the Y harness and all connections, ( I'm not an expert but just making some sugestions from what im reading)
I Use 6v on my 3305's and they work just fine
       Post #: 480
RE: The new Lanier Edge 87" - 2/28/2008 9:28:57 PM
triangle
Status: offline
bad servo.... been there
       Post #: 481
RE: The new Lanier Edge 87" - 2/29/2008 2:23:14 AM
winstone
Status: offline
agh, well anyways I sent all servos back to tower and gonna get some diffrent ones. Im using a NiMH bat if that was the prob??? and no, its not a bad servo triangle all of them do it bud. Any ways who knows
(in reply to triangle)
       Post #: 482
RE: The new Lanier Edge 87" - 2/29/2008 3:35:50 AM
T3beatz
Status: online
good luck hope everything works out for you...
       Post #: 483
RE: The new Lanier Edge 87" - 2/29/2008 12:17:55 PM
triangle
Status: offline
I'm gonna use the st126mg all arround, and a zdz 60 mount the engine first and then locate the electronics.... hopefully it'll come out light!!!!
       Post #: 484
RE: The new Lanier Edge 87" - 3/2/2008 1:30:33 AM
T3beatz
Status: online
got some video of the 2nd flight today, this thing rocks! at 18.3 lbs It flys like a dream still! would have got more but the bat on the cam went out...
http://www.rcuvideos.com/item/66J6VPSRP8ZV5NVW
       Post #: 485
RE: The new Lanier Edge 87" - 3/5/2008 3:54:48 AM
airlyons
Status: offline
just ordered the Brillelli 366gt for the Edge! Anyone else use this combo?
       Post #: 486
RE: The new Lanier Edge 87" - 3/5/2008 5:25:37 AM
T3beatz
Status: online
not that I have read so far, hey guys got some more video flying the edge sunday. It was very windy, had to dead stick one of them, I was messin with the needles ( and I souldn't have) the other one is with me landing it, had to pull out and go around on the first because I was landing cross the runway because of the cross wind.....
http://www.youtube.com/watch?v=9QWrRyKmhSA
http://www.youtube.com/watch?v=5tMoPmsZFBI&feature=related
(in reply to airlyons)
       Post #: 487
RE: The new Lanier Edge 87" - 3/5/2008 12:08:59 PM
triangle
Status: offline
what do you guys think about using only one servo an st125mg on the outer location of the wing.... will it work???
       Post #: 488
RE: The new Lanier Edge 87" - 3/5/2008 1:22:20 PM
AirWizard
Status: offline
quote:
ORIGINAL: triangle
If you 3D I wouldn't use just one.
David
____I'm having a Yak Attack_____
       Post #: 489
RE: The new Lanier Edge 87" - 3/11/2008 4:37:19 AM
winstone
Status: offline
man t3 looks awesome flys sweet! Bad news man the sv 50cc is a piece of $*#*#$@ !!!!! The engine did run for about 1 tank of gas ran great then it happened, the mounting ear tab broke off and u just cant jb weld it back so... I called hobby city and the said send it back and I'll get a full refund since the problem is real familiar with the engines. So guys dont do what I did and just buy a nice DA or 3W. so Im ordering a DA 50r soon. Prob gonna be another month or so for maiden
(in reply to AirWizard)
       Post #: 490
RE: The new Lanier Edge 87" - 3/11/2008 5:02:20 AM
