Modeltech, by Hobby People
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> Modeltech, by Hobby People
Page: [1]
Login
Modeltech, by Hobby People - 9/10/2005 3:21:09 PM
beelzebubishere
Status: offline
Anyone have any input on Modeltech, or in particular, this ARF...
http://www.hobbypeople.net/gallery/123680.asp
kliff
       Post #: 1
RE: Modeltech, by Hobby People - 9/10/2005 4:55:54 PM
Sturtz
Status: offline
As they say "You get what you pay for." But I've found the Modeltech planes to be a good buy. I'm still flying my Extra300 .25 and it's a little work horse. The main thing on these and several other ARF manufacturers is to REALLY LOOK OVER the plane carefully before slapping it together. Do a mock-up assembly to check wing and tail fit. Check for any warping Don't take any chances with your expensive motors and radio gear. Use plenty of 30min epoxy on high stress areas like the wing hold-downs and the firewall. Add tri-stick where it needs it. Plaster that thin CA around light/thin fuse sides and gear block areas . Let it cure good and apply another coat. Then build your plane. You won't regret it.
Sorry I don't have info on the SE5A. There is a good thread on it here in the ARF forum.
_____________________________
Kurt
AMA# 794291
Saito Club #121
(in reply to beelzebubishere)
       Post #: 2
RE: Modeltech, by Hobby People - 9/10/2005 6:07:14 PM
Zippi
Status: online
I have had the Magic Extra 300L with an OS 50SX and I'm currently flying the Magic Formula 3D with a Super Tigre G90. Both planes were nice kits except the covering on the Magic Extra was not very good. The covering on the new Magic Formula 3D however is Monokote. The Magic Formula 3D is a really nice kit with some thick lumber and solid. I wouldn't hesitate to buy another Model Tech product.
"It Ain''''''''t Lookin Good"
http://zippi.50webs.com/index.htm
(in reply to Sturtz)
       Post #: 3
RE: Modeltech, by Hobby People - 9/11/2005 3:00:19 AM
vertigo72480
Status: offline
I've got the Global Tequila Sunrise in the 25 form factor and it's a tough little plane. A word of caution, it seems like the landing gear ply was added as a second thought on my Tequila. I'm not sure about this aircraft though. Overall, the fit and finish are great. The use a high quality covering and I believe it's a name brand type. I like the quality of the Global/Modeltech ARFs and would gladly buy another.
< Message edited by vertigo72480 -- 9/12/2005 12:13:58 AM >
Mike in STL.
(in reply to Zippi)
       Post #: 4
RE: Modeltech, by Hobby People - 9/11/2005 3:33:49 AM
autopilot
Status: offline
I like their planes. I had the Fokker D7, still have the big P-47, the Dragon Lady, and the RCM Trainer. Good quality planes.
Fly 'em, crash 'em, buy some more. The Circle of Life.
(in reply to vertigo72480)
       Post #: 5
RE: Modeltech, by Hobby People - 9/11/2005 3:07:19 PM
beelzebubishere
Status: offline
Thanks for all the input guys, sounds like a ModelTech ARF is in my future!
(in reply to autopilot)
       Post #: 6
RE: Modeltech, by Hobby People - 9/11/2005 11:42:54 PM
inferno6688
Status: offline
I have a Dragon Lady, and i am very happy with it. I got the ARC version, and it was well built. The hardware included was crap though!
       Post #: 7
RE: Modeltech, by Hobby People - 9/12/2005 12:50:56 AM
LDM
Status: offline
I like both Model tech and the great customer servace from Hobby People
LDM
(in reply to inferno6688)
       Post #: 8
RE: Modeltech, by Hobby People - 9/12/2005 2:01:25 AM
Firewalkerd1
Status: offline
Gang, I have a dragon lady for my next project. Any hints that might save my plane. I am going to put a saito 100 in it. Looks to be a gentle plane am I wrong?
I'm counting on using std. servos.
       Post #: 9
RE: Modeltech, by Hobby People - 9/12/2005 2:44:08 AM
vertigo72480
Status: offline
Well, as far as I can tell, the Dragon Lady looks like a great model. If it's like the Tequila Sunrise, the weak point will be the landing gear pad. Most likely this is the weak point on any ARF. I completely ditched the pad, and the shaped balsa, on my Tequila for five ply light weight birch for the entire portion of the front of the fuselage. I tucked the birch under the wing mount and epoxied the entire thing to the rest of the fuselage. After the epoxy cured I used three long servo screws to reinforce the front of the ply into the motor mount. HUGE DIFFERENCE! The landing gear no longer rips out if I look at the grass cross eyed. Landings have to be hot with the Tequila too. It's not a floater, but it's a blast to fly. It looks good on the ground too. The covering is great, and it's resilient too.
I like the lines on the Dragon Lady. Go a head and fly the crap out of it. You'll have fun. Hopefully I have given you some ideas and such. Let me know if you have any questions.
Mike in STL.
(in reply to Firewalkerd1)
       Post #: 10
RE: Modeltech, by Hobby People - 9/12/2005 8:05:32 AM
Epoxy Cup
Status: offline
Have a Dragon Lady .40 ARC, bought about 8 years ago. The model was well built and came with good instructions. I built it stock out of the box, dont remember about the hardware though. As far as flying, I first had an OS.46fx on it and it was a rocket if I opened it up, as the plane is light . The next engine for the DL was an OS.40 Surpass, not so much power but great for cruising around and cool sounding . Even with the Surpass it is not underpowered, just reasonably powered. The plane is gentle with no bad habits, take off and landings are smooth as silk. Just a nice flyer.
       Post #: 11
RE: Modeltech, by Hobby People - 9/12/2005 8:09:25 AM
inferno6688
Status: offline
Yeah i had a 46Fx in my Dragon lady, and it sure did go like a rocket! i love it!! i am currently flying it with a Enya40SS, for a more relaxed putt around the sky!! I had not problems with my landing gear mounting plate
Firewalkerd1: Dunno about the big Dragon lady but the 40 size was a beautiful plane to fly! a very gentle lady!
(in reply to Epoxy Cup)
       Post #: 12
RE: Modeltech, by Hobby People - 9/12/2005 3:42:13 PM
Stamper
Status: offline
I have been flying my 60 size dragon lady for about 3 years now on a magnum 1.20 4 stroke still on the original landing gear using standard servos. Has well over 150 flights and still rock solid. I swear that this plane is more gentle than my trainer. Handles wind like a champ and really lands like a lady. No 3-D, but a great flyer. A saito 100 will rock!!
       Post #: 13
RE: Modeltech, by Hobby People - 9/12/2005 3:43:53 PM
daven
Status: online
I had the Me-109 and did not like it at all. Nothing seemed to fit right, and it didn't fly very good once completed.
A while back I had the Sonic 500 ARC and that was a different story. Very nicely built and everything went together great.
So I guess I'm kinda 50/50 with them, I would take the advice of looking at the model before buying.
Dave Norman
klasskote.com
supertrc.com
       Post #: 14
RE: Modeltech, by Hobby People - 7/11/2008 8:47:59 PM
rwbennett
Status: offline
I've had two modeltech ARFs lately and both had similar problems...first was a Mach one, the second a brand new demon.
the first problem I had was the lan
