vertigo72480
MO, USA Status: offline
I work for Sears and we sell the garden tractor batteries from Johnson Controls as well. Ours are marked DieHard instead of EverStart, and the internals of the DieHard are better reinforced. While tractor batteries are great for starting motors, they lack the deep cycle capability that other batteries have, such as sealed lead acid batteries. The reason that the tractor batteries will last for several seasons in a tractor is due to the charging circuit that is built into the mower. This works a lot like an alternator in a car. Engine runs, battery charges. I can't tell you how many batteries we end up making warranty claims on at the beginning of Spring because people didn't leave the battery on a trickle charger over the winter. The tractor batteries don't have the deep cycle capability, the battery ends up dead. Sure tractor batteries are cheap but they end up leaving you flat. I have a sealed lead acid battery in my flight box that provides 7 Ah at 12 volts, much like the starter batteries you see sold in your LHS. Being HAM radio operator has taught me a lot about batteries, as well as working in automotive. Do yourself a favor and dump the tractor battery. Invest, yes it is an investment, in a sealed lead acid battery. They hold their charge much, much longer, and are far more reliable.
_____________________________
Mike in STL.
