ctdahle
CO, USA Status: offline
Gentlemen, Please check my math and my theory if you would be so kind. I recently became tired of the forest of walwarts, powerstrips and lamp timers strung about my shop for battery charging and bought a Hobbico Multi-Charger. I discovered the hard way that plugged in to the timer, the multicharger discharges when the timer is on the off part of the cycle and am fixing that problem with a bunch of diodes. (Would have been nice if Hobbico had mentioned that in the instructions) I am also bothered about matching the chargers available rates to my various flight packs. I have 250, 400, 600, 700, and 900 MAH packs, and the charger will deliver 10, 25, 50, 100, 240, and 500 MA charging currents. I understand that the general rule of thumb is to charge at 1/10C for a period of time sufficient to deliver about 120% of the pack's rated capacity. Since the charger's power settings do not match the capacity of my packs, I am assuming that the wise plan is not to exceed 1/10C, therefore I am stepping the rate down to the next lowest rate and increasing the charge time accordingly. Thus, a fully discharged 700MAH pack charged at 50MAH needs to stay on the charger for 16.8 hours. Thoughts, ideas, bouquets, brickbats?
_____________________________
When I get a little money I buy model airplanes and if there is any left over, I buy food.
