RE: Club Enya    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Club Enya
Page: <<   < prev  71 72 73 [74] 75 76 77 78 79 80   next >   >>
Login
RE: Club Enya - 11/22/2012 1:18 AM
blw
Score: 655
Last Login: 5/21/2013
Status: offline
The Triumphs looked good, but not nearly as beautiful as the MGA....imo. But, I don't miss British carbs or electrical systems!
_____________________________
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to Ram Jet)
       Post #: 1826
RE: Club Enya - 11/22/2012 1:29 AM
rrengineer
Score: 100
Status: offline
British carbs are very simple once you take the time to understand them and Lucas electrics gets a bad rap. Almost all problems related to the electrics can be traced to corrosion in the bullet and sleeve connectors due to dissimilar metals. By brushing copper anti-seize past on the bullets before pushing them into the connectors, you will stop corrosion and a very reliable system. My last restoration the was re-wired over 12 years ago still has had no problems.
Hide Signatures
(in reply to blw)
       Post #: 1827
RE: Club Enya - 11/22/2012 2:41 AM
Ram Jet
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: rrengineer
The same could be said of all motorcycles bullet/bayonete connectors regargless of make. I like Radio Shack contact cleaner. I never heard of copper anti-seize, I'll remember that.
Cheers,
Bill
If it ain''''t broke, don''''t fix it.
Hide Signatures
(in reply to rrengineer)
       Post #: 1828
RE: Club Enya - 11/22/2012 4:32 AM
1QwkSport2.5r
Score: 155
Last Login: 5/23/2013
Status: offline
Ron's Heliproz south web shop is having a Black Friday sale. Enya #3 plugs for $4.50USD, #4 and #5 are on sale too.
Ronlund.com there is an orange Black Friday button to click on, new customers get 10% off first order.
Just FYI Enyaland.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 1829
RE: Club Enya - 11/22/2012 1:58 PM
downunder
Score: 123
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: Ram Jet
I'd kill for an MGA. Drove one once. I think the engine had it's origins in a British farm tractor.
Not the MG, the 4 cylinder Triumph TR's used an engine based on the Ferguson tractor engine. My first proper sports car (after a Singer 9 then an Austin 7 Special) was a TR3A. None of them used a glow plug .
Hide Signatures
       Post #: 1830
RE: Club Enya - 11/22/2012 3:16 PM
Ram Jet
Score: 100
Status: offline
quote:
ORIGINAL: downunder
quote:
ORIGINAL: Ram Jet
I knew it was one of them.
Bill
Hide Signatures
(in reply to downunder)
       Post #: 1831
RE: Club Enya - 12/6/2012 4:51 PM
mcledan
Score: 100
Last Login: 5/14/2013
Status: offline
I have an Enya SS25.  I dont know if it is a BB or not.  The Model number is on the backplate 4301.
Is there some way I can identify which it is?
Thanx
Dan
Hide Signatures
       Post #: 1832
RE: Club Enya - 12/6/2012 5:05 PM
Ram Jet
Score: 100
Status: offline
quote:
ORIGINAL: mcledan
Thanx
Dan
I can usually tell, if I'm on eBay, by the buldge in the crankcase immediately behind the prop hub. A bushing main bearing engine is quite a bit smaller (less diameter) in that area than a ball bearing crank model. You could simply pull the four screws that hold the crankcase snout and crankshaft to the main crankcase and have a look inside. If you see a caged ball bearing it's a BB, if not it's bushed.
Cheers,
Bill
Hide Signatures
(in reply to mcledan)
       Post #: 1833
RE: Club Enya - 12/6/2012 5:23 PM
MikeG4936
Score: 100
Last Login: 5/12/2013
Status: offline
Hey guys. New project for a fellow Enya user/collector/fanatic. I'm using an old Enya 35X-H in the newly released Gaui NX4 helicopter.
This bird is a 30-size nitro helicopter designed around the OS .37, so I'm not expecting it to do any crazy 3D - but it will be interesting to see how the 20+ year old Enya holds up in this usage scenario. I'm hoping it will work well for sport flying and some mild aerobatics. I'll be running a flybarless system to lighten up the head and a governor to keep the headspeed constant.
I'll be sure to get some video of the first flights and post it here for your review.
Hide Signatures
       Post #: 1834
RE: Club Enya - 12/6/2012 5:35 PM
Ram Jet
Score: 100
Status: offline
quote:
ORIGINAL: MikeG4936
One thing you can bet your bippy on. The Enya will outlast 3 OSs. I'm installing a new/old stock Enya .40 T.V. in a 30" catamaran. It's a 1975 engine with 1960 technology and built like a brick outhouse. It's going to be a fun, reliable boat to run.
Cheers,
Bill
Hide Signatures
(in reply to MikeG4936)
       Post #: 1835
RE: Club Enya - 12/6/2012 8:22 PM
speed-panzer
Score: 104
Status: offline
Hi Club Enya.
There are 2 Enya 60X which I bought from the big bay.
The one on the left is a non-ringed one in pretty much used condition, few fins at the cylinder head are partially cracked and bent. The right one is of ringed type, piston, ring and liner look like new parts from overhaul work. Carburetor seems to be the same on both ones.
The cylinder heads are different – the non-ringed 60X has a much more massive head, while the head of the ringed one has less material. Fin height seems to be identical.
On pics 3 and 4 it is visible that the combustion chamber is different, too. The non-ringed 60X has much deeper bowl, resulting in larger chamber volume. The chamber of the ringed 60X is more flat, and together with the reduced head thickness even the glow plug little bit sticks out.
Is this a low compression head on the non-ringed one versus a high-comp head on the ringed engine? So far I thought that Enya made such 2 different heads only for older, smaller engines.
Looking forward to your comments.
Dominik
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to blw)
       Post #: 1836
RE: Club Enya - 12/6/2012 8:26 PM
speed-panzer
Score: 104
Status: offline
Forgot to mention: The cylindrical part of the high-compression head which sticks inside the liner is considerably tapered at its upper part - this being not the case with the low comp head.
Hide Signatures
(in reply to speed-panzer)
       Post #: 1837
RE: Club Enya - 12/6/2012 9:22 PM
Ram Jet
Score: 100
Status: offline
quote:
ORIGINAL: speed-panzer
Hi Club Enya.
Dominik
There's a head gasket on the head on the right, the one with the shallow cumbustion chamber. Maybe an attempt to reduce compression? The head on the right should run a-bit cooler due to recuded surface area. That might be the reason for the shallower combustion chamber - reduced operating temperature and to compensate for increased compression they addd the rather thick head gasket.
Cheers,
Bill
Hide Signatures
       Post #: 1838
RE: Club Enya - 12/7/2012 1:50 AM
downunder
Score: 123
Status: offline
Someone has done some fairly drastic machining on that high compression head which explains why it's thinner than the standard head. Personally I wouldn't use it until I'd carefully checked the squish clearance and actual head volume to determine just what compression it gives. As a guide, I run my 60X at 13.5:1 compression on zero nitro fuel where the standard compression is about 9.5:1.
Hide Signatures
       Post #: 1839
RE: Club Enya - 12/7/2012 2:11 AM
Ram Jet
Score: 100
Status: offline
quote:
ORIGINAL: downunder
l
Looking me closely mate I think you're spot on. I would discard the shallow combustion chamber head or run an additional head gasket AND check piston crown to head clearance with some modeling clay.
Cheers,
bill
Hide Signatures
       Post #: 1840
RE: Club Enya - 12/9/2012 8:33 PM
Ram Jet
Score: 100
Status: offline
quote:
ORIGINAL: AmishWarlord
Bill that guy is a genius!
He has invented a way for you to test out the engine wile at the same time not getting any bills in the mail.
Hi Warlord,
Just to let you know I'm shamelessly stealing your concept for a test stand. If it's patented I'll give you my attorney's name and address. I'm going to use an engine mount made by a fellow in England.
Thank you,
Bill
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to AmishWarlord)
       Post #: 1841
RE: Club Enya - 12/13/2012 2:24 PM
speed-panzer
Score: 104
Status: offline
I think you are right - someone made a little bit too much of a machining to that "high comp" head.
A quick email to Mr. Ken Enya solved my problem - a new head is on order and will be shipped soon. Just excellent service.
Hide Signatures
       Post #: 1842
RE: Club Enya - 12/13/2012 2:31 PM
Ram Jet
Score: 100
Status: offline
I think you are right - someone made a little bit too much of a machining to that ''high comp'' head.
Ken's the best. I had lost my Enya files due to a computer problem. I contacted Ken and asked for the PDFs on the 1.55 4C and .46 4C. They were in my inbox inside of 40 minutes.
Bill
Hide Signatures
       Post #: 1843
RE: Club Enya - 12/19/2012 4:45 PM
mcledan
Score: 100
Status: offline
ENYA 25 SS
Ramjet:  I pulled the front housing.  I dont think it has BBs.  Am I right or do I have to remover the crank?
I can not figure out how to attach the photo?
Dan
Hide Signatures
       Post #: 1844
RE: Club Enya - 12/19/2012 4:50 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: mcledan
ENYA 25 SS
Dan
With the prop taken off, its easy to tell if its a BB engine if it has a raised hump right behind the prop driver. (I posted a picture in a reply to your post in the Tach forum). The prop drivers are different between the BB and Bushed engines.
To upload a photo to your post, click the "Click here to upload images and files!" link at the bottom of the reply window. This allows you to upload directly to RCU. If you have a photo host like photobucket, you can click their "IMG" link and paste it to your post.
SS30 BB engine photo showing the raised hump behind the prop driver:
If your engine doesnt have that hump, its a bushing engine.
Hide Signatures
       Post #: 1845
RE: Club Enya - 12/19/2012 6:35 PM
Ram Jet
Score: 100
Status: offline
quote:
ORIGINAL: mcledan
ENYA 25 SS
Dan
If it had BBs the crank would probably have left the engine with the front crankcase housing. If you sight through the crankshaft hole and see bronze/brass colored bushings she's a plain bearing engine. Please don't think that a plain bearing engine is in any way deficient. It's not at all. Two advantages of a plain bearing engine; 1. you can get lazy about running "after run" oil through your engine because your plain bearing won't rust like caged ball bearings (I just had to replace all of my beraings in my Enya .46 4C), 2. your engine with be a great deal lighter not having to haul around all those extra steel BBs and steel cages.
Cheers,
Bill
Hide Signatures
       Post #: 1846
RE: Club Enya - 12/19/2012 6:37 PM
Ram Jet
Score: 100
Status: offline
quote:
ORIGINAL: 1QwkSport2.5r
quote:
ORIGINAL: mcledan
ENYA 25 SS
Dan
To upload a photo to your post, click the ''Click here to upload images and files!'' link at the bottom of the reply window. This allows you to upload directly to RCU. If you have a photo host like photobucket, you can click their ''IMG'' link and paste it to your post.
Yep, what Sport2 said.
Bill
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 1847
RE: Club Enya - 12/19/2012 8:31 PM
mcledan
Score: 100
Status: offline
Thanx Ramjet, Bill;
It has a much slimmer housing out to the prop driver.  It is a plain bearing for sure.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1848
RE: Club Enya - 12/19/2012 9:07 PM
rrengineer
Score: 100
Status: offline
Looks like a good candidate for the antifreeze in the slow cooker treatment!
Mike MacLean
Hide Signatures
       Post #: 1849
RE: Club Enya - 12/19/2012 10:49 PM
Ram Jet
Score: 100
Status: offline
quote:
ORIGINAL: mcledan
Thanx Ramjet, Bill;
I'm sure you need to be told this but I always scratch a small "F" (front) on the forward facing side of the connecting rod so that I put the rod and piston back in right the first time. Oh, duh Bill.
Cheers,
Bill
Hide Signatures
       Post #: 1850
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Club Enya
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
