RE: Club Enya    Gallery
Logged in as Guest
Users viewing this topic: bogbeagle, Ram Jet, tiffitech, wnewbury
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Club Enya
Page: <<   < prev  70 71 72 73 74 [75] 76 77 78 79   next >   >>
Login
RE: Club Enya - 12/19/2012 10:51 PM
Ram Jet
Score: 100
Last Login: 5/20/2013
Status: online
quote:
ORIGINAL: rrengineer
Looks like a good candidate for the antifreeze in the slow cooker treatment!
Mike MacLean
I haven't tried that yet because my girlfriend won't let me use her crock pot. I have had very good luck with lacquer thinner though. Just don't get any lacquer thinner on any rubber parts. It will destroy them.
Bill
_____________________________
If it ain''''t broke, don''''t fix it.
Hide Signatures
(in reply to rrengineer)
       Post #: 1851
RE: Club Enya - 12/19/2012 11:13 PM
mcledan
Score: 100
Last Login: 5/14/2013
Status: offline
Mike
Precisely the question I was going to ask next.  I really dont have a slow cooker, but I presume it holds a certain temp for a specified time.
What might they be?
Dan in Ottawa
P.S.
You may remember me from the query about the train wreck coming down from the mountains.
Hide Signatures
       Post #: 1852
RE: Club Enya - 12/19/2012 11:16 PM
mcledan
Score: 100
Status: offline
Mike
What might they be?
Dan in Ottawa
P.S.
Hide Signatures
       Post #: 1853
RE: Club Enya - 12/19/2012 11:22 PM
mcledan
Score: 100
Status: offline
Bill
Thanx for the <F> tip.  I dont pull engines apart, or very seldom, mostly 1/2A in the past.
I appreciate that tip very much.
Dan in Ottawa
P.S.  You may see my name as Danato on occasion.  Its the short form of Dan-AT-Ottawa.
There are quite a few who have my same name.
I got tired of requests for balsa strippers etc. ;^)
Hide Signatures
(in reply to Ram Jet)
       Post #: 1854
RE: Club Enya - 12/19/2012 11:32 PM
rrengineer
Score: 100
Status: offline
You can get the aluminum looking like new by just putting it in diluted (it will take a little longer sometimes) or full strength antifreeze overnight on the "LOW" setting. If you go back a few pages, you can see a .46 four stroke I "cooked" overnight. The hardest baked on castor oil will be gone the next day. Not rocket science here.
Mike
Hide Signatures
(in reply to mcledan)
       Post #: 1855
RE: Club Enya - 12/19/2012 11:33 PM
rrengineer
Score: 100
Status: offline
By the way, check with you local thrift store. You might find a Crock Pot for 5 or 10 bucks. A new one is only $20.
Hide Signatures
       Post #: 1856
RE: Club Enya - 12/19/2012 11:43 PM
Ram Jet
Score: 100
Status: online
I'll check that out. $20.00 isn't that bad either.
Bill
Hide Signatures
       Post #: 1857
RE: Club Enya - 12/20/2012 4:09 AM
MikeG4936
Score: 100
Last Login: 5/12/2013
Status: offline
A small 1 qt crock pot is only $10 from Walmart or Target. I just got one.
Hide Signatures
       Post #: 1858
RE: Club Enya - 12/20/2012 4:27 AM
Ram Jet
Score: 100
Status: online
quote:
ORIGINAL: MikeG4936
Thank you. Heck, even I can afford THAT!
Cheers,
Bill
Hide Signatures
(in reply to MikeG4936)
       Post #: 1859
RE: Club Enya - 12/20/2012 12:43 PM
1QwkSport2.5r
Score: 155
Last Login: 5/21/2013
Status: offline
I used Dawn Power Dissolver to clean my Enya SS and ST S90K cylinder heads and upper cylinder fins. 5 minutes with a toothbrush and 10 minutes soaking worked perfect. I dont let the castor get too baked on. My 60-4C is the worst, not sure where the oil is leaking... The allen head screw and the area around it is got a little castor goo cooked on. The head has only been off once, when I first got the engine to free up the piston ring and clean up the sticky valves. (It was never run, but stored poorly)
I filled the crankcase of my 60-4C with a mixture of ATF and seafoam to store it for winter. I think that should keep the cambox and valvetrain from rusting I hope.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 1860
RE: Club Enya - 12/20/2012 2:11 PM
mcledan
Score: 100
Status: offline
I have <F>'d my conrod ;^)
Thanx.
Dan
Hide Signatures
       Post #: 1861
RE: Club Enya - 12/20/2012 2:19 PM
mcledan
Score: 100
Status: offline
1QwkSport2.5r
 Is Dawn Power Dissolver sold in stores?  I presume it is safe for aluminum.
BTW, thanx for the nice pix of the Enya 30SS to show me the size of the front BB.
And how to post pix which I missed on the <fast reply>.
Dan
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 1862
RE: Club Enya - 12/20/2012 4:52 PM
Ram Jet
Score: 100
Status: online
quote:
ORIGINAL: mcledan
I have 'd my conrod ;^)
Thanx.
Dan
Dan, that's a good F'n thing! ;-)
Bill
Hide Signatures
       Post #: 1863
RE: Club Enya - 12/20/2012 4:59 PM
Ram Jet
Score: 100
Status: online
quote:
ORIGINAL: mcledan
1QwkSport2.5r
And how to post pix which I missed on the .
Dan
Just for reference here's a .40 BB.
Bill
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1864
RE: Club Enya - 12/20/2012 8:21 PM
mcledan
Score: 100
Status: offline
Thanx again.
It definetly has a <husky> front end.
You certainly can tell its got ball bearing in there compared to the smaller plain bushing one.
Dan
Hide Signatures
       Post #: 1865
RE: Club Enya - 12/21/2012 3:16 AM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: mcledan
1QwkSport2.5r
Dan
I got mine at Walmart, but it should be obtainable at a grocery or department store like Walmart or Target. Not sure what they have in Canada. It's in a blue spray bottle, probably 10 ounces or so.
Like the antifreeze method, some aluminum will turn dark gray if left too long. I use an old toothbrush after soaking for 10 minutes, scrub, and rinse. Stubborn stains need more elbow grease.
Hide Signatures
       Post #: 1866
RE: Club Enya - 12/21/2012 5:39 PM  1 votes
blw
Score: 655
Status: offline
Each brand of engine probably requires a test to see how long the Dawn can stay on it. I've close to an hour with Saitos and about 15 minutes with Evolutions.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 1867
RE: Club Enya - 1/5/2013 3:20 AM
speed lover
Score: 100
Last Login: 5/1/2013
Status: offline
I'm looking at an engine and want to know if the stunt version is the same as the carb version it is a .61 cxrs pro a stunt engine but I'd be interested in putting a carb on it is it the sane as the CXR with a carb or is the timing different on the the liner if anyone knows I'd really apreciate the info.
Hide Signatures
       Post #: 1868
RE: Club Enya - 1/5/2013 3:46 PM
downunder
Score: 123
Status: offline
I have the 61 CXLRS pro (rear exhaust) and AFAIK the only change was fitting a venturi instead of a carb plus a lower compression head button. The side exhaust version is essentially the same as the RE so the same holds true for it too. OK, I just checked the parts list and there's only one cylinder liner listed for both the CL and RC versions so no change in timings.
Hide Signatures
(in reply to speed lover)
       Post #: 1869
RE: Club Enya - 1/5/2013 10:37 PM
speed lover
Score: 100
Status: offline
Thanks for the info I did'nt bother with the engine it went for too much. So I might buy a new one from Enya. What do you think of the 61cx is it a good engine ? I've read people having debates about the liner not being chrome and being Nickel. I don't really know about this area in detail so it is pretty hard to get my head around it. Just wondering about the price. It is high and too be honest I'd pay it if I knew it was gonna last like the rest of the Enya range. But is it strictly built around 3D ? Being so light and not as powerfull as a full blown 60 class engine it looks like the engine is built for 3D and from what I've read it seems that it is in the 50 class power range. I can only guess that Enya have tried to produce 50 class power with low weight but with high response from low revs with a very flat power band and giving smooth throttling from anywhere in the band is this what they run ? I have a weston UK 50 T1 which is pretty good for power but I've got to say it is'nt perfect but is still a great engine. But I once had an Enya 60X and that thing had terriffic power and smooth and heard a few small SS Enya engines run and I have to say there are'nt many other engines that I've heard that run that well this is the reason I've been turned onto Enya. I love engines that just run so well anywhere in the band to me it makes flying the aeroplane it's in way more fun.
Hide Signatures
(in reply to downunder)
       Post #: 1870
RE: Club Enya - 1/5/2013 11:48 PM
1QwkSport2.5r
Score: 155
Status: offline
I have two Enyas, an SS30bb and a 60-4C. The SS30 is the most well mannered engine I own, a real sweetheart, and I only paid $40 for it NIB. Mine is iron/steel piston/liner. My 60-4C is a nice running engine too, once I got the hang of tuning the needle that is.
Enyas run on cheap fuel, which is nice, and they are superbly made. What more could you ask for? Even abused Enyas will still run decent.
Hide Signatures
       Post #: 1871
RE: Club Enya - 1/6/2013 12:21 AM
downunder
Score: 123
Status: offline
Enya have always been fairly conservative with their claimed power output but they rate the 61CX at 1.7HP which is comparable to the older 60X. Although the Enya web site just says the liner is ABN (with a ringed piston) the instruction leaflet goes into a bit more detail and says it's nickel plated with a silicon carbide composite. This is similar to Nikasil which is used on very high performance cars including F1.
Hide Signatures
       Post #: 1872
RE: Club Enya - 1/31/2013 4:06 AM
1QwkSport2.5r
Score: 155
Status: offline
Hello happy people in Enyaland. I need a little help. I have a Norvel Neofun Classic that needs an engine. I was borrowing an AP .061 from a buddy but he needed it back. So I figured since it needed more nose weight anyway, why not an Enya .09 or something along those lines. Problem is... I don't have one. Anyone got one or something close that would part with it for a nominal fee..? Been watching RCU's classifieds, only big stuff lately. I won't buy from sleazeBay either.
Hide Signatures
(in reply to Mr Cox)
       Post #: 1873
RE: Club Enya - 1/31/2013 4:20 AM
Ram Jet
Score: 100
Status: online
quote:
ORIGINAL: 1QwkSport2.5r
There's a real pretty .09 I.V. RC w'muffler on ebay right now going for $0.99. Item number 330866355908. I bought a nice NIB .09 a few years back on eBay. What's the risk? I have completed over 10,000 eBay/Pay Pal transactions since about 1998 and only two bad experiences which were nicely resolved. There's also a control line going for $0.99,
Cheers,
Bill
Hide Signatures
       Post #: 1874
RE: Club Enya - 1/31/2013 4:33 AM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Ram Jet
Cheers,
Bill
Because I always get outbid. Even waiting until the last few seconds. I once bid on a used RC car against one other guy.... It was worth about $100 at best, but I ran the guy up until he won the auction having to pay $190. I was entertained by it.
I'll keep my eyes open, but if anyone has an engine they don't want anymore, I'll give it a good home. I have lots of castor oil.
Hide Signatures
       Post #: 1875
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Club Enya
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.579RCU1
