RE: Club Enya    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Club Enya
Page: <<   < prev  50 51 [52] 53 54 55 56 57 58 59   next >   >>
Login
RE: Club Enya - 11/30/2011 12:18 AM
AmishWarlord
Score: 121
Last Login: 5/23/2013
Status: offline
Just got my first Enya engine this past weekend. It's a NIB VT-240 Can't wait to get it on the test stand!
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to philbaker)
       Post #: 1276
RE: Club Enya - 11/30/2011 12:56 AM
rcdude7
Score: 105
Last Login: 2/15/2012
Status: offline
That is a beauty! are you going to put it on a plane someday?
Hide Signatures
(in reply to AmishWarlord)
       Post #: 1277
RE: Club Enya - 11/30/2011 2:45 AM
gkamysz
Score: 120
Last Login: 2/6/2012
Status: offline
quote:
ORIGINAL: 74SEVEN7
A friend of mine is trying to get the cambox off an Enya 46 4-Stroker
and it won't move but more than a hair.
Any ideas?
Chances are pretty good that the cam drive gear is rusted into the bearing in back of the cam box. The usual soaking in penetrating oil and heat is suggested.
Greg
_____________________________
Greg
Hide Signatures
(in reply to 74SEVEN7)
       Post #: 1278
RE: Club Enya - 11/30/2011 8:11 AM
AmishWarlord
Score: 121
Status: offline
quote:
ORIGINAL: rcdude7
Yeah it will be going in a seaplane.
< Message edited by AmishWarlord -- 12/2/2011 10:20 AM >
Hide Signatures
(in reply to rcdude7)
       Post #: 1279
RE: Club Enya - 12/2/2011 3:39 AM
svenska3
Score: 100
Status: offline
I'm going to Japan this summer. I hope to meet Ken.
Hide Signatures
(in reply to MikeG4936)
       Post #: 1280
RE: Club Enya - 12/2/2011 4:54 PM
Kostas1
Score: 330
Last Login: 5/14/2013
Status: offline
I'd like to see a video of that!!!!!
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
       Post #: 1281
RE: Club Enya - 12/15/2011 3:05 AM
wed-subawu
Score: 110
Last Login: 7/24/2012
Status: offline
Here's my group - SuperSport 15, 45CX, 46 4-stroke and R120. They're all destined for planes I am or will be working on. Not pictured is my SuperSport 25 - RIP. It took 2 planes and a few crashes to finally kill it - tough little thing. I like them for their reliability, robustness, and east-to-adjust carbs. And the 4-stroke designs, with the rear-mounted pushrods are a better fit in scale cowls and less vulnerable to crash damage.
A question on the 15. The box included 2 of these little brass split collets, slightly tapered on one end. Anyone know what they are for? The tapered end fits into the muffler opening, but I don't see what that would be for. It doesn't seem to fit anywhere else. I thought it might go in the carb intake  as a restrictor, but it's too small for that. Anyway, if you have any thoughts on it...
cheers
John
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Kostas1)
       Post #: 1282
RE: Club Enya - 12/15/2011 3:25 AM
NM2K
Score: 161
Status: offline
quote:
ORIGINAL: wed-subawu
cheers
John
My eyes are not in the best condition these days, but could they be venturi restrictors for increased fuel draw?
Ed Cregger
"Practice makes prefect"
Hide Signatures
(in reply to wed-subawu)
       Post #: 1283
RE: Club Enya - 12/15/2011 3:48 AM
earlwb
Score: 584
Status: online
I would agree, they look like venturi restrictors. In some events the intake is limited in its maximum bore size. Otherwise it is used to improve duel draw in some cases.
But I vaguely remember something like that for the muffler end to restrict it more where a event has a maximum RPM limit with a certain size prop.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to NM2K)
       Post #: 1284
RE: Club Enya - 12/15/2011 9:27 AM
NM2K
Score: 161
Status: offline
quote:
ORIGINAL: earlwb
I think that you fellows having the muffler restrictor idea are on the right track. Maybe someone that really knows (no offense intended) will drop in and let us know.
Ed, NM2K
Hide Signatures
(in reply to earlwb)
       Post #: 1285
RE: Club Enya - 12/29/2011 10:50 PM
rrengineer
Score: 100
Last Login: 5/21/2013
Status: offline
Got a brand new SS25 on Ebay this week. The seller says it was mounted, but the projest was never finished and the engine never saw fuel. Paid 27 bucks for it! It came with no box or manual. Before I email Ken Enya for a manual, anyone have a manual in PDF form for this engine?
Mike MacLean
Hide Signatures
(in reply to NM2K)
       Post #: 1286
RE: Club Enya - 1/5/2012 2:11 PM
nxconvict
Score: 100
Last Login: 4/29/2013
Status: offline
Any recommendations on a prop nut that accommodates a spinner for the 120c (old)?
Hide Signatures
(in reply to simark)
       Post #: 1287
RE: Club Enya - 1/13/2012 2:35 AM
Altered1
Score: 106
Status: offline
Hi Fellow Enya enthusiasts!
I hope you can take the time to check out my problem with my ENYA 60.
This engine starts fine on a variety of fuels and plugs.  From FAI to 10% Nitro, castor and a synth blend, and OS8 to OS6 plugs. 10 and 11 x 6 props - all fine...... Engine will hold a fast idle all day, and copes with a fast blip of the throttle.... but the moment I try to advance to WOT, slow or fast and maintain, she dies after a few seconds.  This happens about 1/3 open throttle.  Please check out the vid.
http://s1211.photobucket.com/albums/cc434/Altered01/?action=view&current=4677115a.mp4
Engine is plugged into an external muffler to keep the noise down, but problem is there with and without this.
I guess she is running out of fuel or flooding the glow plug, but to be sure, I've tried many variations on fuel settings - HS needle from almost closed to 2 turns open, and the air bleed screw covering the air bleed hole, to open as well.
Tank will preassurise, and doesn't seem to have a leak, its level with the carb, about 2 inches behind the engine.  I'm using a sintered brass ball clunk to reduce bubbles, and cannot see any bubbles coming through the fuel hose.  Fuel hose is about 6 months old since purchase, but was replaced a few weeks ago.
Engine had got new bearings and front bearing housing recently.
Your thoughts guys ?  Should I try another Carb ?
This is a sweet sweet engine.... I dont want to have to change to running only my ASP!
Altered1
Hide Signatures
(in reply to nxconvict)
       Post #: 1288
RE: Club Enya - 1/13/2012 2:56 AM
earlwb
Score: 584
Status: online
You are still too lean, open up the needle valve more. 3 to 4 turns maybe even 5 out or more. Then at full throttle slowly lean it back out. Then when you find peak RPMs back it off about 500 RPMs. Then point the engine up and check the needle valve adjustment so the engine will hold high RPMs near peak without leaning out.
If the engine won't run or it loses a lot of RPMs when you take off the glow plug ignitor then you either have a glow plug going bad or a glow plug with too cold of a heat range.
AMA # 928076
Hide Signatures
(in reply to Altered1)
       Post #: 1289
RE: Club Enya - 1/13/2012 6:21 AM
Altered1
Score: 106
Status: offline
Thanks Earl,
I never would have wound the HS needle out that far..... worked a treat.  I'm not confident about how 'in tune' I've got her as I don't have a tach, but it is close, and atleast she'll hold WOT now.  The HS needle is about 3-3/4 turns out from the stop.  OS8 Plug, 10% Nitro Fuel, 10x6 APC.....   Must borrow a tach !
As a side note, even after a new front housing, and bearings, the old girl still leaks oil from the front bearing, and I think there is some fuel splashing out of the carb..... messy, but oh what a lovely engine note!
Hide Signatures
       Post #: 1290
RE: Club Enya - 1/13/2012 12:34 PM
earlwb
Score: 584
Status: online
Yes the engine is supposed to ooze oil out of the front bearing. That was what kept the front bearing lubricated and helped to cool it too.
At that time era all the engines oozed oil out of the front too.
Yes they can spit fuel out of the carb. It is a interesting reversion effect on the air fuel flow through the engines.
Glad to help you get it running good again.
AMA # 928076
Hide Signatures
       Post #: 1291
RE: Club Enya - 1/13/2012 8:05 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: rrengineer
Mike MacLean
PM me your email and I'll send you scans of the original literature. I have an SS30 I got NIB with all paperwork.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to rrengineer)
       Post #: 1292
RE: Club Enya - 1/13/2012 10:01 PM
rrengineer
Score: 100
Status: offline
Thanks for the offer, but since no one has answered until now, I finally emailed Ken and he sent a PDF for the .25-.30 engines. Glad to know someone will always come through on this forum though.
Mike
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 1293
RE: Club Enya - 2/24/2012 8:24 PM
dauntlessuk
Score: 100
Last Login: 5/19/2013
Status: offline
I have a late 70's Enya 35-III BB special with r/c carb. It's in pretty good condition for its age. Any one able to tell me what performance I should expect on a 10x6 prop and 10%nitro fuel?
Hide Signatures
       Post #: 1294
RE: Club Enya - 2/25/2012 2:32 AM
downunder
Score: 123
Last Login: 5/20/2013
Status: offline
Enya rates the RC version at .65HP with a rev range of 2000-13000. With a 10x6 prop I'd expect you'd get around 12000 revs. If you've still got both the high and low compression heads then it's worth checking the revs with each of them.
Hide Signatures
(in reply to dauntlessuk)
       Post #: 1295
RE: Club Enya - 2/26/2012 2:37 PM
dauntlessuk
Score: 100
Status: offline
Hi,
Tried the Enya 35 today and was getting 11,500 max on a Bolly 10-1/2" x 5" prop (couldn't find a 10x6!) I guess that's not too bad for a 40 yr old engine. Will try different plugs next. I'm not sure what works best on these old non-scheurle ported engines. Any suggestions?
Hide Signatures
(in reply to downunder)
       Post #: 1296
RE: Club Enya - 2/26/2012 6:33 PM
landeck
Score: 137
Last Login: 5/22/2013
Status: online
A Fox idle bar plug works well with the hold cross flow engines because of the baffle on the piston.
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
       Post #: 1297
RE: Club Enya - 3/26/2012 5:57 AM
DaveR
Score: 100
Last Login: 5/17/2013
Status: offline
I was checking out an Enya 50 CX, but I don't know Enyas all that well. Is it a screamer or torquer type of engine? What use is it best suited for?
Hide Signatures
(in reply to landeck)
       Post #: 1298
RE: Club Enya - 4/20/2012 3:41 PM
1QwkSport2.5r
Score: 155
Status: offline
I had a spontaneous buying decision and picked up a low time/possibly new Enya .60 4 stroke. Looks like a 13x6 is a good prop from what I read. I'm not sure what I'm going to put it on, but probably a .40 size sport plane. Any suggestions on a plane, and a break-in regime in case it is new? Are these ringed engines (I assume so)?
I've wanted an Enya 4-stroke for awhile but didn't find the right deal. I hope I didn't pay too much at $120.
Hide Signatures
(in reply to DaveR)
       Post #: 1299
RE: Club Enya - 4/20/2012 4:09 PM
earlwb
Score: 584
Status: online
Except for a major mishap the Enya engines tend to last seemingly forever, plus they command decent prices when resold too.
Sounds like a good deal to me.
Since there are so many 40 size planes out there, just about any of them would work. It really depends on your skill level for flying as to what plane to choose. Plus what you like too.
AMA # 928076
Hide Signatures
       Post #: 1300
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Club Enya
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.859RCU1
