RE: Club Enya    Gallery
Logged in as Guest
Users viewing this topic: Ram Jet, steve111, NM2K
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Club Enya
Page: <<   < prev  52 53 [54] 55 56 57 58 59 60 61   next >   >>
Login
RE: Club Enya - 4/22/2012 3:30 PM
1QwkSport2.5r
Score: 155
Last Login: 5/26/2013
Status: offline
quote:
ORIGINAL: earlwb
quote:
ORIGINAL: NM2K
quote:
ORIGINAL: DaveR
I was checking out an Enya 50 CX, but I don't know Enyas all that well. Is it a screamer or torquer type of engine? What use is it best suited for?
The Enya 50 CX is a screamer that will swing larger lumber if the need be, but you will be wasting its power doing so. Unfortunately, Enya dropped the AAC piston/liner of previous (smaller) CX engines and reverted to the older ABC type of piston/liner setup. Still, it is a great engine and a winner in my eyes.
Ed Cregger
AAC is pretty good, but if you have a AAC engine overheat from a lean run too much, the aluminum cylinder sleeve won't shrink back and you lose the pinch at TDC. ABC on the other hand, the brass sleeve will still try to shrink back and you get the pinch back at TDC (at least most of the time). Aluminum has that characteristic of expansion when heated, but heated beyond a certain temperature, it tends to stay expanded more after cooling off. You sometimes see the effect when someone overheated a crankcase to replace the bearings and the discover the new bearings are a bit loose now.
Anyway that is probably why the discontinued the AAC piston and liners. Also ABC cylinder/pistons seem to produce a bit more power than the AAC ones do in some engine designs. Interesting paradox.
You know, its odd.. I've talked to a number of folks that say AAC and ABC are pretty equal in power production, whereas the ringed, bushed, and lapped engines tend to turn a few less rpm which drops power somewhat. It would make sense since a ringless engine will get a better piston seal at TDC/combustion than a typical ringed engine will. Lapped engines are kind-of on their own in that respect since they aren't a tapered bore, and aren't ringed.
I suppose it comes down to port timing, fuel, plug choice, and prop choice as the main variables influencing power production for a given engine.
_____________________________
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to earlwb)
       Post #: 1326
RE: Club Enya - 4/22/2012 4:10 PM
Ram Jet
Score: 100
Status: online
quote:
ORIGINAL: 1QwkSport2.5r
quote:
ORIGINAL: Ram Jet
So you like airboats. Here's one for you. I have a new Enya 1.55 4C. How large a hull would I build to accomodate this baby? I'm serious. I bought the engine because I couldn't pass it up for the price and it's a beautiful engine and , of course, I love Enyas.
Cheers,
Bill
The hull will need to be good size to accommodate the huge props that engine will turn. My big boat has an ST .90 on it using 12-13'' props; the hull size is 38''x18''x3.5''. I'm guessing the 1.55 will be running maybe a 16'' prop? I'd plan on 40-44'' length, 22-24'' width, and depth/draft will depend on the weight of the engine and all of the components you will need to put on the hull to run it. My above mentioned boat is about 7.5lbs RTR, you'll want to expect 10-14lbs or so for a faster hull and 20lbs for a slow stable hull.
These are guidelines. If you want other information, I can point you to an Airboat resource that has a lot of Gasser folks building big hulls for converted weedie and chainsaw engines. Just PM me.
Tim
p.s. Here are two of my 4 airboats. All scratchbuilt by me using balsa, liteply, birch ply, and lots of epoxy. These two are both SuperTigre powered, small one is 14''x26''x2.5'' and has a S.29 on it turning 9x4-9x6APC props. The big one with the S.90K is running either 12x5, 13x4W, or 13x5-6 props.
Beautiful hulls. I like the fact that you used epoxy. I've hear of guys usung CA glue on their hulls which I think is too brittle to withstand the beating a powerboat hull can take on choppy water. Since you offered I will PM you. I would like to learn more about airboats, some call them "Swamp Gliders". I was going to scale down plans from Glen-L whos sells boat plans for full scale hulls. They have a really nice airboat plan in their line. Well, better get off this boat stuff the Sky Pilots will get ticked off. PM coming.
Thank you,
Bill
If it ain''''t broke, don''''t fix it.
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 1327
RE: Club Enya - 4/22/2012 4:44 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Ram Jet
Beautiful hulls. I like the fact that you used epoxy. I've hear of guys usung CA glue on their hulls which I think is too brittle to withstand the beating a powerboat hull can take on choppy water. Since you offered I will PM you. I would like to learn more about airboats, some call them ''Swamp Gliders''. I was going to scale down plans from Glen-L whos sells boat plans for full scale hulls. They have a really nice airboat plan in their line. Well, better get off this boat stuff the Sky Pilots will get ticked off. PM coming.
Thank you,
Bill
Some call them "swamp buggies", "fan boats", "blow boats", etc. Airboats aren't speed demons, but they are fun. I've seen a custom built Hydrofoil airboat go 80mph with a Jett .90LX FIRE. 7lbs, 48" long x 24" total width. Pretty crazy.
AFAIC, this is an engine forum.. I don't see where anyone should have a "problem" with going off the airplane subject. 90% of my posts in the Glow Engines forum is related to airboating and not airplanes. I'm just now finally getting off my duff to get an airplane and get out flying.
Would the Enya 60-4C fly the Goldberg Mig-27 worth a snot? I think they run 7-9lbs RTF. I know the Sportster .65 they came with turn a 13x6 around 10,600rpm. I assume the Enya will be turning a little slower.. probably closer to 8500rpm or so? This is just a thought out-loud. I doubt the Enya 60 would have enough oomph.
Hide Signatures
(in reply to Ram Jet)
       Post #: 1328
RE: Club Enya - 4/22/2012 7:11 PM
ryanbrown1
Score: 100
Last Login: 3/25/2013
Status: offline
Normal 0 false false false ontGrowAutofit/> MicrosoftInternetExplorer4
Hello All,
 I am relatively new to the hobby and have come into an old HiroboShuttle helicopter which has an Enya SS 30 engine. The engine was totally lockedup but I have managed to free it up and disassemble most of it. Are there anygood sites that sell parts for this older engine or gives repair info? I knowthat I will have to have to at least have new bearings and rings for thepiston. Is there any way to find out the specs of the two sets of bearings sothat I can explore aftermarket options?  Anyinfo would be most appreciated.
Hide Signatures
       Post #: 1329
RE: Club Enya - 4/22/2012 7:24 PM
Ram Jet
Score: 100
Status: online
quote:
ORIGINAL: ryanbrown1
Hello All,
www.rcbearings.com the guys are great to work with and the prices are very reasonable. Frank Bowman for rings at ringmaster46@msn.com. There are no better rings anywhere in the world. You can buy them gapped by Frank or oversize and gap them yourself.
Cheers,
Bill
Hide Signatures
(in reply to ryanbrown1)
       Post #: 1330
RE: Club Enya - 4/22/2012 7:26 PM
rrengineer
Score: 100
Status: offline
RCBearings.com, Bocabearings.com, Ebay or even Enyaengine.com. Email Ken Enya at info@enya-engine.com, Mr Enya will be able to supply every part of that engine including an instruction sheet in PDF form. He send out the instructions via email for free. You can even get a better ring (enya rings are pretty hard and take a long time to break in) from Frank Bowman. See below:
Frank Bowman
1211 N. Allen Ave.
Farmington, N.M. 87401-3568
Email: ringmaster46@msn.com
Just email him with your request. I had him send me a ring for a O.S. 45FSR and it was perfect.
Good Luck.
Hide Signatures
       Post #: 1331
RE: Club Enya - 4/22/2012 10:58 PM
buzzard bait
Score: 115
Status: offline
An Enya 30SS with rings? Well, the heli version must be different. Those SS models have had a lot of variants.
Are you sure the bearings are actually rusted and not just gunked up with old castor? If they really are, then yes, go with rcbearings.com for sure.
Jim
Hide Signatures
(in reply to rrengineer)
       Post #: 1332
RE: Club Enya - 4/23/2012 12:16 AM
ryanbrown1
Score: 100
Status: offline
Im thinking they are rusted...what do you think?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ryanbrown1 -- 4/23/2012 12:47 AM >
Hide Signatures
(in reply to buzzard bait)
       Post #: 1333
RE: Club Enya - 4/23/2012 12:53 AM
Ram Jet
Score: 100
Status: online
Yep, they look like paper weights to me. I enlarged your pictures and my guess is rust. You could be sure it's not old castor gunk by washing them in lacquer thinner. Replace them. RC Bearings won't hurt you a-bit ($) and it's peace of mind. You have here a good example of why it's important to use an after-run lube in your engine if you're going to store them for a-while.
Cheers,
Bill
Hide Signatures
       Post #: 1334
RE: Club Enya - 4/23/2012 1:52 AM
NM2K
Score: 161
Status: online
quote:
ORIGINAL: earlwb
quote:
ORIGINAL: NM2K
quote:
ORIGINAL: DaveR
Ed Cregger
You can't realize all the power of an Enya CX with AAC if you don't tune it for max power, unlike any other style of piston/liner engine. Learning that "just right" setting is tough, but doable. The AAC versions produce much more power than the ABC types. Ask Dubb Jett.
Ed Cregger
"Practice makes prefect"
Hide Signatures
       Post #: 1335
RE: Club Enya - 4/23/2012 3:11 AM
2walla
Score: 100
Last Login: 5/23/2013
Status: offline
I loved my cx40 and cx50 They would scream.. I used to run the 50 an a morris profile with a 12x4 apc and it would scream..Shame they both were ruined by a batch of bad glo fuel.. I still have a 45, a couple of 35's and a 25x laying around.. They are the best you can get for longevity and good running.. Shame altech marketing screwed up their marketing back in the day..
Hide Signatures
(in reply to NM2K)
       Post #: 1336
RE: Club Enya - 4/23/2012 3:32 AM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: buzzard bait
Jim
The SS30 is a lapped iron/steel engine. The only ringed SS engine is the SS50 Heli. The 35 Heli is lapped iron/steel too I think, or AAC.
The bearing in the front housing looks like castor crud, but I cant tell about the rear bearing. The whole picture looks orange..
Hide Signatures
       Post #: 1337
RE: Club Enya - 4/23/2012 5:38 AM
ryanbrown1
Score: 100
Status: offline
i am not sure what a lapped iron/steel or AAC engine is but my Enya SS30 BB has (well had, it broke into peices as soon as the piston was removed) a little ring around the piston just under the top of it, where rings on regular sized engines would normaly go. There was just one ring.
I have already ordered new bearings.
Hide Signatures
       Post #: 1338
RE: Club Enya - 4/23/2012 5:55 AM
Ram Jet
Score: 100
Status: online
Two cycle engines commonly only have one ring. Two cycles don't have to worry about oil control so they usually don't, if ever, have a second or third oil scraper ring. Some two cycle motorcycles use one very thin steel ring.
Cheers,
Bill
Hide Signatures
       Post #: 1339
RE: Club Enya - 4/23/2012 6:23 AM
ryanbrown1
Score: 100
Status: offline
Hide Signatures
       Post #: 1340
RE: Club Enya - 4/23/2012 1:10 PM
buzzard bait
Score: 115
Status: offline
For some reason Enya really played around with the SS series, though a ringed version is a new one on me.
The old 0.45 6001 had two rings, but all the others I know of only had one.
Jim
Hide Signatures
       Post #: 1341
RE: Club Enya - 4/23/2012 2:18 PM
steve111
Score: 100
Status: online
SS35, SS45 and SS50 are all ringed.
Hide Signatures
       Post #: 1342
RE: Club Enya - 4/23/2012 2:26 PM
buzzard bait
Score: 115
Status: offline
Yes, I was thinking of the .25 and .30.
Hide Signatures
(in reply to steve111)
       Post #: 1343
RE: Club Enya - 4/27/2012 6:22 PM
1QwkSport2.5r
Score: 155
Status: offline
I got my Enya 60-4C in the mail yesterday.... She's quite the brute! It appears to be un-run, but its dirty and the bearings are "gritty". Someone put an Idlebar Fox glow plug in it which I will switch out for a normal glow plug. Compression is very good. I'll clean it up and open it up to see if there is any rust inside or not. The bearings have me leary, so if after looking it over I find the bearings to be sketchy, I'll order some new ones. The "muffler" doesnt look to be much of a muffler. It looks homemade from what I can tell. I doubt it will be more offensive noise-wise than any 2-stroke I have so I'll try it out as-is. If its too noisy, I'll find a muffler for it.
I'm not sure what I'll put it on just yet, I just wanted one for my collection. Its a very handsome engine. It'll keep my SS30BB company for now.
Hide Signatures
       Post #: 1344
RE: Club Enya - 4/27/2012 6:32 PM
JPMacG
Score: 123
Last Login: 5/25/2013
Status: offline
My 45SS and 50SS are ringed, yet I have heard others speak of a lapped 45SS. Maybe Enya produced both a ringed 45SS and a lapped 45SS?
The 50CX and 50SS are both great on a 46-sized 3D profile, like a Burrito or Mojo. I have found these engines do best if I don't back them off from the HS needle peak as much as I would back off other engines. The throttle reponse gets really good, and so far they are hodling up just fine.
Hide Signatures
       Post #: 1345
RE: Club Enya - 4/27/2012 6:38 PM
Ram Jet
Score: 100
Status: online
I don't have a use for my Enya 1.55 4C either and I too bought it just becaue it's beautiful. I have a stock Enya muffler on my 1.55 and .46 and they really are just "show" pipes as they are simply straight-thru cans. You won't want to muffle your 60 anyway as it makes music. Go find a video on You Tube of one running. I would suggest you use an Enya #3 plug. I've read nothing but good things about them. The muffler does look home made and it appears to be somewhat restrictive. I guess you'll know when you fire it up. RC Bearings.com will fix you right up. While you are pokeing around inside the engine you might want to consider re-reinging her with a nice set of Frank Bowman rings. Nice engine - have fun.
Cheers,
Bill
I got my Enya 60-4C in the mail yesterday.... She's quite the brute! It appears to be un-run, but its dirty and the bearings are ''gritty''. Someone put an Idlebar Fox glow plug in it which I will switch out for a normal glow plug. Compression is very good. I'll clean it up and open it up to see if there is any rust inside or not. The bearings have me leary, so if after looking it over I find the bearings to be sketchy, I'll order some new ones. The ''muffler'' doesnt look to be much of a muffler. It looks homemade from what I can tell. I doubt it will be more offensive noise-wise than any 2-stroke I have so I'll try it out as-is. If its too noisy, I'll find a muffler for it.
Hide Signatures
       Post #: 1346
RE: Club Enya - 4/27/2012 7:19 PM
earlwb
Score: 584
Status: offline
Yeah the Enya 1.55 is a brute of a engine for sure. Here is my example still NIB:
and here is my old Enya 46 too:
My old classic Enya 80:
and one of my Enya R1.20 engines too
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 1347
RE: Club Enya - 4/27/2012 7:20 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Ram Jet
I don't have a use for my Enya 1.55 4C either and I too bought it just becaue it's beautiful. I have a stock Enya muffler on my 1.55 and .46 and they really are just ''show'' pipes as they are simply straight-thru cans. You won't want to muffle your 60 anyway as it makes music. Go find a video on You Tube of one running. I would suggest you use an Enya #3 plug. I've read nothing but good things about them. The muffler does look home made and it appears to be somewhat restrictive. I guess you'll know when you fire it up. RC Bearings.com will fix you right up. While you are pokeing around inside the engine you might want to consider re-reinging her with a nice set of Frank Bowman rings. Nice engine - have fun.
Cheers,
Bill
I bought a Fox Miracle 4-stroke plug to use for now. The hobby shop had Enya #6's but obviously they are cold plugs and wont work. They also wanted $15 each on those #6's. Out of my budget to use those unless I can find them for closer to $6 that I pay for my McCoy plugs I use in everything else. I use #59's which are hot plugs and work great in my Aero engines with just 5% nitro. I'll do some looking around for some #3's when I get around to it. I have to get the engine tore down, cleaned, and reassembled before I do anything else. One thing at a time.
If it indeed hasn't been run, I'll run it with the installed ring and see how it runs. If need be, I'll get a new ring. I'm going to get a spare ring for my ST S90K so I'll order both at the same time. I'm not in a rush as I dont have anything to put it on yet. I'll probably test-run it a few times and put it up until I get out flying.
On the muffler bit - The so-called "muffler" is more-or-less a piece of aluminum tubing screwed/clamped to the exhaust header. 4 drilled holes 1/8" in dia. or so surround the tube with a pressure fitting on the very end. I doubt this will need muffler pressure, so I'll probably take the "muffler" off and run it with the open header.
Any tips on disassembling and reassembling the engine? I have the PDF of the manual, and have the specs for tappet lash. I have to find my feeler gauges. Lash is set with the engine cold as I understand. I will plan to set it to specs.
Could the bearing grittiness be from congealed oil/grease from age? It looks like the engine has been sitting some time, perhaps in a shed. It has sawdust stuck to it.
Hide Signatures
       Post #: 1348
earlwb
Score: 584
Status: offline
Here is the advertsiement that came in the box with my Enya R155 engine
AMA # 928076
Hide Signatures
       Post #: 1349
RE: Club Enya - 4/27/2012 8:47 PM
1QwkSport2.5r
Score: 155
Status: offline
I pulled my 60-4C apart and it indeed has not ever ran. The ring is stuck in the piston (still black in color, no signs of wear), and the bearings are covered in a brown sticky goo that I believe to be assembly oil that has hardened and congealed. No rust to speak of, thankfully. I will soak the oily sticky parts in glow fuel and make new gaskets and reassemble it. Looks like it will be a good runner.
Oddly enough, the bearings are gunked up and the ring is stuck but the valves aren't sticking open or closed.
Anyway. I guess it isnt a bad deal for $120. It'll look (and run) like new when I'm done cleaning it.
It is a lovely engine. I'm glad I grabbed it. You don't see Enya 4-strokes for sale on here very often.
Hide Signatures
       Post #: 1350
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Club Enya
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
