RE: New ZDZ-80
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: New ZDZ-80
Page: <<   < prev  23 24 25 26 27 28 29 30 31 [32]
Login
RE: New ZDZ-80 - 3/2/2008 3:29:37 AM
gooseF22
Status: offline
keep going until you run 2-3 gallons through it, then you can switch to synthetic and it will spit all thatr crap out and chocolate coat.
it will spit and spit for awhile, but it will pull like a horse
_____________________________
Goose
Team Fromeco
(in reply to bmadden)
       Post #: 776
RE: New ZDZ-80 - 3/2/2008 3:31:51 AM
gooseF22
Status: offline
you will be able to lean it down to 1.5 turns pretty soon
Goose
Team Fromeco
(in reply to gooseF22)
       Post #: 777
RE: New ZDZ-80 - 3/4/2008 8:31:03 AM
Gus155
Status: offline
Swiched over to Castrol Racing Synthetic this week end and what a difference from the sooty mineral crap.
Got about 10liters through it with mineral 2stroke.
could still probably lean it out a touch.
Oh if the 5-5-1 dosnt work, there is either no fuel or no spark,
Thanks to all for the good tips and advice on this superb motor.
FLY IT LIKE ITS RENTED
Putting the FUN in FUNctional since 1976
       Post #: 778
RE: New ZDZ-80 - 3/4/2008 10:13:20 PM
bmadden
Status: offline
Hi,
I just wanted to share a little factoid with you guys. My ZDZ Tach. will not work with my ignition setup. I have a Smart-Fly fiber optic ignition cutoff that goes between the ignition and the switch. The problem is that it interrupts the signal wire. With out a signal from the ignition to the switch, the Tach. reading stays at 0. I am going to try a jumper signal wire across the ignition cutoff with the permission of RC Showcase and Smart-Fly. No one is sure that it will work, including my self, but all seem to think it will not hurt anything or void any warranties. I’ll post again when I complete the job.
Brian
Look man, I’m not necessarily smart; I just hang around smart people!
(in reply to Gus155)
       Post #: 779
RE: New ZDZ-80 - 3/5/2008 12:12:16 AM
bmadden
Status: offline
quote:
ORIGINAL: bmadden
Hi,
Brian
It Worked!!
       Post #: 780
RE: New ZDZ-80 - 6/12/2008 9:09:20 AM
tuavp
Status: offline
I have zdz 80RVJ and I would like to install on my Comp-Arf extra 330L airplane. Anyone has the tamplate of the engine installation onto engine doom??? for 2.3m carf extra
Thks
(in reply to dick Hanson)
       Post #: 781
RE: New ZDZ-80 - 6/12/2008 8:26:02 PM
gooseF22
Status: offline
I dont know of one. start from the other templates and draw an X on the motor box. the measure the zdz corner to corner and place the holes along that line equal distant from the old holes. It may fall off the line but you will be able to place it equa distant from the x. see my pic.
As far as the cutout, it took alot of trial fit with a paper template for the carb cutout.
Click to see fullsize image.
Click for fullsize
Goose
Team Fromeco
(in reply to tuavp)
       Post #: 782
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU1
