RE: Club FOX!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Club FOX!
Page: <<   < prev  98 99 [100] 101 102 103 104 105 106 107   next >   >>
Login
RE: Club FOX! - 4/9/2012 11:26 PM
Scirocco14
Score: 114
Last Login: 6/19/2013
Status: offline
Earlwb, what is that sport plane?  Looks like a fun one.
And I'd love to get my hands on a Birdy 10 and build it w/ a Fox .15 on it!
Mark
_____________________________
Mark C.
Etowah RC Flying Club, Etowah, NC
Hide Signatures
(in reply to earlwb)
       Post #: 2476
RE: Club FOX! - 4/9/2012 11:37 PM
earlwb
Score: 599
Status: offline
I think it is more or less a copy of the Herr Mini_Sport RC plane. It was supposed to be electric powered. But I stuck on a glow engine of course.
Someone sells them on Ebay as a ARF Mini Sportster.
Like this one for example http://www.ebay.com/itm/New-Electric-Mini-Sportster-Airplane-RC-Sports-Plane-ARF-Kit-/110857830344?pt=Radio_Control_Vehicles&hash=item19cfa43fc8
It won't taxi at our grass flying field but with larger diameter wheels it will ROG no problem.
It does great four point rolls and knife edges too.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to Scirocco14)
       Post #: 2477
RE: Club FOX! - 4/10/2012 12:21 AM
turbo.gst
Score: 115
Status: offline
The Fox .15 is a jewel! I have both the bushed and BB versions.
Hide Signatures
       Post #: 2478
RE: Club FOX! - 4/10/2012 3:30 AM  1 votes
earlwb
Score: 599
Status: offline
Cougar429,
   Another idea...
   I forgot about it but some guys actually mounted the VP30 fuel pump inside of the backplate. You drill a hole just big enough for a screw to screwed into the threaded hole after you remove the pressure fitting for the pump. the screw keeps the hole open when you glue it in place (lightly oil the screw to ensure the epoxy won't stick to it). You then glue the pump in with JB Weld or Machinist's epoxy. You can put down some epoxy and then insert the pump and screw it down with the screw. After the epoxy has cured you remove the screw and now you are in business. Oh yeah point the adjusting screw and the inlet and outlet lines like you want too.  Now with the newer Eagle IV engines that pressure fitting boss on the backplate is likely in the way, so you would have to remove it, if you go this route.
AMA # 928076
Hide Signatures
       Post #: 2479
RE: Club FOX! - 4/10/2012 4:38 AM
Cougar429
Score: 128
Last Login: 6/18/2013
Status: offline
Found out the only spare fuel fitting was M4 X 0.7, so drilled it out part way with a #30 drill and tapped it. The raised boss has more than enough meat for that. Final drill through was a 1/64, so the hole into the case is relatively small. Did the Loctite and letting it sit till tomorrow. Don't have a test stand, so will have to wait till at least this weekend to fire it up again. With the work shifts this would likely happen anyway.
You guys seem to have lots of fun with those smaller engines and love the tales of difficulty identifying make and size. I've always said Fox was underrated.
Club Saito Member # 787
FA91, 100, 2 X 125a, 150
Hide Signatures
       Post #: 2480
RE: Club FOX! - 4/11/2012 2:29 AM
earlwb
Score: 599
Status: offline
Sounds good. But I think the hole needs to be larger than 1/64 of a inch or .015 inches. You want a good strong pulse going to and from the pump diaphragm in order to get it to flex in and out. The small hole would tend to act more restrictive and prevent the pulses from flowing easily.
AMA # 928076
Hide Signatures
(in reply to Cougar429)
       Post #: 2481
RE: Club FOX! - 4/11/2012 4:03 AM
Cougar429
Score: 128
Status: offline
Well, no problem to drill it out larger. I can run the same I.D. as the fitting.
Hide Signatures
       Post #: 2482
RE: Club FOX! - 4/12/2012 2:38 PM
hsukaria
Score: 185
Last Login: 6/14/2013
Status: offline
quote:
ORIGINAL: Scirocco14
Mark
http://www.valuehobby.com/airplanes.html?cat=185
Content, but not Complacent.
Saito Club Member #765
Hide Signatures
       Post #: 2483
RE: Club FOX! - 4/12/2012 3:46 PM
codycarlisle25
Score: 100
Last Login: 4/23/2013
Status: offline
Ok guys we all like our Fox Engines, but which one is your favorite?
Mine is my Fox .50
Hide Signatures
(in reply to hsukaria)
       Post #: 2484
RE: Club FOX! - 4/12/2012 3:52 PM
fujiman
Score: 103
Status: offline
HAWK .60........I HAVE SEVERAL!!!!!!!!
Hide Signatures
(in reply to codycarlisle25)
       Post #: 2485
RE: Club FOX! - 4/12/2012 4:24 PM  1 votes
earlwb
Score: 599
Status: offline
I like the HAwk .60 too. I have a few of them too. This was my primary pattern plane engine years ago. The ones I used took seemingly forever to break in, but after that they were real powehouses. They are smaller than the big case modern .60 engines and a little taller than the bored out .50 size engines. I have seriously considered running one in a Jackal plane for the heck of it. Fox claims they can turn 22,000 RPMs all day long no problem. I never had one turn over 20,000 RPMs on the ground myself. My tach only worked up to maybe 20,000 RPMs at the time I did it. But the prop was too small for the Delta plane I had it on. If I remember correctly,  I was running a 10x8 prop when I was flying the delta plane or was it a 9x8, I forget know.
Testing out one that I rebuilt a couple of years ago.
AMA # 928076
Hide Signatures
(in reply to fujiman)
       Post #: 2486
RE: Club FOX! - 4/12/2012 4:30 PM
Cougar429
Score: 128
Status: offline
I guess it would have to be my first, the indestructible 50BB. Along with the 40's and new 60 have another 50 that needs a run up.
Hide Signatures
       Post #: 2487
RE: Club FOX! - 4/12/2012 5:27 PM
fujiman
Score: 103
Status: offline
i ran my Hawk .60 on a hobby shack pilot EZ .40 fw-190 with retracts. excellent combo, lots of vertical, very fast. as i remember my hawk run good pretty much rite from the get go. i ran a perry carb. with no problems!!!!!!! loved the plane, ran it into the ground at flat out speed flying just too low. but dang it just looked so good there, gear up and all!!!!!!
Hide Signatures
       Post #: 2488
RE: Club FOX! - 4/12/2012 5:56 PM
turbo.gst
Score: 115
Status: offline
Mine would have to be my Fox Eagle IV 74. Although the talk of the Hawk has my curiousity peaked about my NIB Hawk 60. Shoot, I can't have just one favorite engine anyway!
Hide Signatures
       Post #: 2489
RE: Club FOX! - 4/12/2012 6:18 PM
fujiman
Score: 103
Status: offline
the hawk was one of the top engines fox made. just my two cents worth!!!!!!
Hide Signatures
(in reply to turbo.gst)
       Post #: 2490
RE: Club FOX! - 4/12/2012 7:25 PM
landeck
Score: 137
Status: offline
My favorite RC engine is the Fox .74 Eagle IV with the new carb. Of course, I do love my Fox .60 Eagle I which I have been running since 1973. My favorite CL engine is the Fox .15. The two I have have run forever.
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
       Post #: 2491
RE: Club FOX! - 4/12/2012 7:31 PM  1 votes
earlwb
Score: 599
Status: offline
The Fox Hawk .60 engine used a special finned steel cylinder sleeve that was specially hardened giving it extremely long wearing characteristics. Plus there was no resistance to the heat as it was transferred out to the cooling fins, so the cylinder sleeve was quite resistant to distortion from the heat as it was running. Barring a mishap, the cylinder is usually good for two or three ring replacements and even a new piston if need be, as it wears faster than the cylinder does. The cylinder sleeve doesn't scratch easily either.  There were some numbers posted someplace about how hard the cylinder sleeve was too. But I forget where, it might be buried in this thread someplace.
Of course parts are harder to come by now. Fox has run out of the special Hawk .60 parts now. But it is easy to get bearings for them and Frank Bowman makes good piston rings for them. One could use the new Fox carb on them too.
Actually come to think of it, most all of the Fox engines run really good and are long lasting. So technically they all tend to be a favorite of mine.
AMA # 928076
Hide Signatures
(in reply to landeck)
       Post #: 2492
RE: Club FOX! - 4/12/2012 7:35 PM
Sport_Pilot
Score: 233
Status: offline
Fox .50.  I have a Fox Eagle .60 that had poor idle and transition with the Perry carb it cam with, but it runs fine on a MK-X carb, but have never flown it that way.  The Fox .50 is getting worn but still runs great.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 2493
RE: Club FOX! - 4/12/2012 11:13 PM
hsukaria
Score: 185
Status: offline
So what were the reasons for Fox to replace the Hawk with the Eagle engines? Cheaper? Easier to use/break-in? etc...?
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 2494
RE: Club FOX! - 4/13/2012 12:15 AM
carddfann
Score: 110
Last Login: 5/5/2013
Status: offline
I recently bought a brand new Hawk minus the box. Never been ran except at Fox and it has the muffler. Its their later one that has the dull colored case. I can't wait to put it in my Aeromaster Too. What a classic combo!
Hide Signatures
       Post #: 2495
RE: Club FOX! - 4/13/2012 12:47 AM
fujiman
Score: 103
Status: offline
quote:
ORIGINAL: hsukaria
I DON'T KNOW!!!!!!! but i wish they would start up product of it again!!!!!!!!!
Hide Signatures
       Post #: 2496
RE: Club FOX! - 4/13/2012 1:15 AM
hsukaria
Score: 185
Status: offline
quote:
ORIGINAL: fujiman
quote:
ORIGINAL: hsukaria
I would buy one for sure, especially with their new carb.
Hide Signatures
       Post #: 2497
RE: Club FOX! - 4/13/2012 2:08 AM
carddfann
Score: 110
Status: offline
I'm not sure why they came out with the Eagle series, but I have an old Sig catalog with the nice full color Fox section and it shows the 60 twin, hawk, old Duke 60, and Eagle. I think they said or infer that the Eagle was the start of a more powerful line of 60's, but basically said that the hawk was still powerful, debugged, and a good value compared to the more expensive eagles. I think Fox wanted a new generation to go more head to head with the Rossi's, Webra's, and forget that other imported high performance engine at the time. I think its name had only 3 letters in it but I'm drawing a blank. It sucks getting older.
Hide Signatures
       Post #: 2498
RE: Club FOX! - 4/13/2012 2:41 AM  1 votes
earlwb
Score: 599
Status: offline
As I was told Duke said that the move to the Eagle II was driven by cost. Both machine time and material cost. Duke couldn't get thick walled tubing material for the Hawk so he machined the cylinder from solid "Rod" stock, this was expensive. The Eagle's cylinder could be made from tubing this saved a lot in machine time and material costs. At this time electron beam welding had been perfected. This allowed Duke to make his crankshafts from three pieces that he was then able to electron beam weld together. Even though he had to send out the cranks to be welded the cost savings in material and even the machine time to rough out the cranks from solid bar was worth it. (I never heard of a Fox Eagle II, III or IV crank breaking at any of these welds).
Now Duke's actions weren't  totally driven by cost. The Eagle II and III were built with 3 piece cases this allowed Duke the flexibility to make his 120 twin from the same basic modules. The 3 piece case had matched front and rear housing with precision bolts bolt holes that were match machined. Once the life of the 120 had come to an end there was no need for this time consuming machining operation. This is where the 2 piece Eagle IV came from and it's great 17mm crankshaft. The 120 was a failure in the market place because of the uneven cylinder charging from the crank pin's action against the transfer ports. A rear exhaust Fox 120 is a very powerful and reliable twin!
Hey cardfan, the big time pattern .60 engines were OPS, Rossi, Webra, HP,  and OS. Fox was sort of a left out child for odd reasons. When i was pattern flying I was the only one using Fox engines everywhere I went. But earlier the Fox .60 Blue Head engines were quite popular until the planes needed retracts and more speed.
AMA # 928076
Hide Signatures
(in reply to carddfann)
       Post #: 2499
RE: Club FOX! - 4/13/2012 3:22 AM
hsukaria
Score: 185
Status: offline
So, by saying that the Eagle had more power, yet the Hawk could turn a lot higher RPM's, would that mean that the Eagle can turn a bigger prop due to higher torque?
Anyway, the Eagles are good about being able to set them as rear exhaust. But how much power, if any, is lost if the exhaust is set to the rear?
Hide Signatures
       Post #: 2500
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Club FOX!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.655RCU1
