RE: Club FOX!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Club FOX!
Page: <<   < prev  107 108 [109] 110 111 112 113 114 115 116   next >   >>
Login
RE: Club FOX! - 6/23/2012 10:03 PM
Cougar429
Score: 128
Last Login: 6/19/2013
Status: offline
No way to know the condition of the liner and other ferrous bits, but try soaking it in a mix of alcohol and ATF fluid. If you can find a crock pot to warm things up for a day or so it would also work to free things up and penetrate everything with lube. Obviously, pull the glow plug.
_____________________________
Club Saito Member # 787
FA91, 100, 2 X 125a, 150
Hide Signatures
(in reply to rrengineer)
       Post #: 2701
RE: Club FOX! - 6/23/2012 11:29 PM
earlwb
Score: 599
Last Login: 6/20/2013
Status: offline
It is congealed castor oil that has gummed it up. We ran all castor oil in the fuel back then.
The .29 was sort of a hop up performance mod for .20 to .25 size planes. You can run a 9x4, 9x5, or maybe a 9x6 on the engine.
Fox test ran all their engines before boxing and shipping. So it is simply stuck from the old castor oil drying out. No rust.
Some heat and soaking in raw fuel or liberal use of WD-40 and heat will have it loosened up good.
The engines do take some time to break them in good. You can break it in quicker, if you heat cycle it. That is where you run the engine for a few minutes to heat it up good. Then stop it and let it cool off. Then repeat. The alternate hot and cold will break in the engine faster, than just hooking up a fuel jug to it and letting it run the gallon down.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 2702
RE: Club FOX! - 6/23/2012 11:51 PM
rrengineer
Score: 100
Last Login: 6/11/2013
Status: offline
I am aware of heat cycling and will break it in this way. I used Dawn Power Dissolver to loosen it up just now. I sprayed some down on the piston and inside on the con rod crank pin. After opening the back, I could see it was just old castor oil. After sitting for 15 minutes or so, I washed it out with hot water, then baked it for a while in the oven to dry it out. I put after run oil all through it and the crank is turning fine now. This engine has an idle bar glow plug from the factory. Will it run OK with any modern plugs? What kind of mufflers will fit this engine?
Mike MacLean
Hide Signatures
(in reply to earlwb)
       Post #: 2703
RE: Club FOX! - 6/24/2012 12:11 AM
earlwb
Score: 599
Status: offline
The engine will work fine with a idle bar glow plug. The idle bar helps prevent the intake fuel charge from quenching out the coil element in the glow plug. But in a pinch a non-idle bar plug will work Ok most of the time, it depends on how much you need to have it idle and how slow to idle. I forget if it is really a problem or not at this time.
The standard medium range glow plugs work fine. Fox uses a RC long idle bar plug in the engines.
I am trying to remember which MAC's one piece muffler fits, but it literally bolts right on without any hassle.
Fox used the same Fox muffler on the .19, .25, .29, .35, and .36 engines (baffled piston types). Fox made the mufflers in a small rather crummy muffler up to a more modern looking teardrop shape muffler. They still sell the newer muffler design for the Fox .35 stunt engines too.
I just measured the muffler screw hole spacing and went to the LHS with my ruler and picked a Mac's muffler off the wall.
It is the 6200, 6300 or 6340 muffler I just forget which one. You can measure the hole spacing (center to center) and you'll see which one fits. Since several other engine's mufflers match up OK too, those become candidates for useage too.
Here is a couple of my planes with Fox engines using the Mac's one piece muffler on them.
AMA # 928076
Hide Signatures
       Post #: 2704
RE: Club FOX! - 6/24/2012 12:48 AM
rrengineer
Score: 100
Status: offline
Wow! They just line right up with the holes in the cankcase. I'll have to file down the two little raised bosses above and below the exhaust port for a flush fit. With an exhaust diverter like the one in your first picture you can keep the airplane pretty clean from the looks of it. Thanks for the info! Maybe I should read the owner's manual that came with it in any case. You can tell it's old, the paper is yellowed on one side I'm guessing where it was exposed to the light at one time. The box it came in is an off white and only has "FOX 29RC" with "22900" stamped on it. Makes me wonder when this was made.
Mike MacLean
Hide Signatures
       Post #: 2705
RE: Club FOX! - 6/24/2012 1:04 AM
earlwb
Score: 599
Status: offline
Sorry about that, I forgot that they miht have two raised center bosses on some of the engines. Yeah you have to carefully file them down a little.
But yeah the mufflers just bolt right on with little or no effort.
The original mufflers had a flange that wrapped around the engine exhaust outlet. There was also the earlier engines that had a rotating exhaust baffle coupled to the carburetor. The first type had no flange and used the center holes to mount the muffler and allowed the exhaust baffle to stay in place. Later they used the center two holes for those engines and a flange wrapped around covering the holes that was left over after you removed the baffle. Then they had just the flange and the two center holes. Later they made the engines with the outer two mounting tabs and no exhaust baffle and you could use either the center or the outer tabs to mount the mufflers.
The .29's were made almost from the beginning of the first stunt .35 engines back circa 1948 or so. The RC versions came out in the 1970's. They still made and sold the engines up until the early 1980's. Nowadays only the stunt .35 survives in a lapped piston and a ceramic cylinder version.
The .29X RC with a guillotine exhaust baffle couple to the throttle first appeared in 1970. The .29 RC with the rotating exhaust baffle coupled to the throttle and two screw holes in the center for the muffler first came out in 1972. If I remember right around 75 or so, Fox came out with the side mounting tabs and dispensed with the exhaust baffle. The Fox .36RC came out then and they still had some .29RC versions too. I forget when but Fox started bead blasting the crankcases to give them the dull gray color look instead of the shiny polished aluminum color look.
AMA # 928076
Hide Signatures
       Post #: 2706
RE: Club FOX! - 6/24/2012 1:20 AM
rrengineer
Score: 100
Status: offline
Well, aren't you the wealth of Fox information! ;^) Mine is the bead blasted crankcase, it's the carb and backplate that is shiny. I went digging through my parts boxes and found a brand new Mac's muffler that looks to be a perfect fit! I just need to ream the two through holes in the crankcase tabs for the slightly larger mounting screws on the muffler. Now that the engine is loose and lubed well, it really pops when you turn over the prop. Great compression! This should be fun! Thanks Earl.
Mike MacLean
Hide Signatures
       Post #: 2707
RE: Club FOX! - 7/1/2012 1:36 AM
SRQFlyer
Score: 100
Status: offline
Need some advice from the Fox experts. I have a .25 BB Schnuerle that appears to have a slightly bent (don't ask) crankshaft stud. An email to Fox on how to remove it got no answer so, please help! Are the threads right handed? (I would guess so). Is some heat in order? Any help would be appreciated.
Jim
AMA 106594, CG Ult 10-300 Bro #38, Club Saito #699 (45, 50, 56, 2x72, 82, 91, 120, 2x 150)
Hide Signatures
       Post #: 2708
RE: Club FOX! - 7/1/2012 3:36 AM
earlwb
Score: 599
Status: offline
They just unscrew like normal, they aren't reverse threaded. You might have to double nut it to get off, but if it is bent, just latch onto it with a pair of vice-grips  and unscrew it. of course you need to hold the crank still somehow so it'll unscrew. The stud is not normally in there all that tight, it should come out without a lot of effort.  They can't use a reverse thread on it as it'll loosen up on you when the engine is running.
AMA # 928076
Hide Signatures
(in reply to SRQFlyer)
       Post #: 2709
RE: Club FOX! - 7/1/2012 3:51 AM
SRQFlyer
Score: 100
Status: offline
Thanks -
It's late I realized (after posting) that it MUST be RH threads. I'll try vise-grips with the crank in vise with padded jaws, but not until tomorrow when I'm awake.
Thanks again,
Jim
Hide Signatures
       Post #: 2710
RE: Club FOX! - 7/3/2012 2:35 AM
Cougar429
Score: 128
Status: offline
Along with Rare Bear I maidened the F-15 today. Both times the Eagle IV died in flight and I had to set it down in the beans alongside the field. Both times the glow plug had failed. There were hints of black on the leading edge of the wing, but I would have thought by now the motor would have worn in enough to get past that.
Plane survived and only needs control surface tweaking. Seems more tankfuls will need to be run before trusting it in flight again.
The muffler mod does a fine job of taming the noise.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 2711
RE: Club FOX! - 7/3/2012 3:07 AM
hsukaria
Score: 185
Status: offline
quote:
ORIGINAL: Cougar429
Cougar, we (I) lost track of what you have on that F-15. Are you running the old head button, how much nitro, prop size, muffler, etc.? I went through in-flight engine stalls for a few months until changing head buttons and lowered the nitro to 5%.
Content, but not Complacent.
Saito Club Member #765
Hide Signatures
(in reply to Cougar429)
       Post #: 2712
RE: Club FOX! - 7/3/2012 3:33 AM
Cougar429
Score: 128
Status: offline
The Eagle IV 60 is stock except for the muffler and Perry pump and carb, (required since the tank was moved aft approx 12" to the CofG). It was NIB and only a couple of years old when I grabbed it and the head has never come off, so not sure which button it has. Both were idle bar style plugs.
I was running 15% with a Graupner 11/7 3 blade.
Here is a pic with the new muffler and stock carb. Perhaps that can tell what gen it is. Second pic is installed in the aircraft.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to hsukaria)
       Post #: 2713
RE: Club FOX! - 7/3/2012 3:48 AM
earlwb
Score: 599
Status: offline
Cougar429, that is a pretty awesome setup there with that engine, you might want to study those glow plugs more closely. You may be running the engine a touch too lean or have a odd vibration problem or a little detonation going on too. You might even need to run a little colder heat range glow plug too.
Here is Duke Fox's article on glow plugs.
AMA # 928076
Hide Signatures
       Post #: 2714
RE: Club FOX! - 7/3/2012 10:55 PM
hsukaria
Score: 185
Status: offline
Cougar, I agree with earlwb, that is an awesome setup.
Your pictures show the older style carb and crankcase. So, it may be possible that the head button is the older high compression version. That means that the engine has to be run with lower nitro (0-5%), extra rich, and with a medium plug, like the OS #8 or Fox #8 (from my limited experience). In any case, I found out that a lot of fuel has to be run through it for breakin, I had to go through at least 2 gallons. At least with your setup, you don't have a full cowl over the engine with baffling requirements.
By the way, how much rpms are you getting with that Graupner?
Hide Signatures
       Post #: 2715
RE: Club FOX! - 7/4/2012 12:16 AM
Sport_Pilot
Score: 233
Status: offline
I think the Fox #8 plug is a colder plug that Fox suggests for the 60 and 74 engines that have detonation problems.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 2716
RE: Club FOX! - 7/4/2012 12:53 AM
hsukaria
Score: 185
Status: offline
quote:
ORIGINAL: Sport_Pilot
That's what I use on all my 2-strokes. I use the Miracle plug on my 4-strokes.
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 2717
RE: Club FOX! - 7/4/2012 4:18 AM
Cougar429
Score: 128
Status: offline
If I get a chance I'll pull the head and take a pic of the button. Worst case I can try the same mod I made to the 50BB button to reduce the squish. Before I made the mode on the 50 detonation was audible in flight, but not on the ground, (?????). Did not hear anything like that yesterday.
I think I posted the RPM from the breakin runs. Cannot remember what it is now.
Hide Signatures
       Post #: 2718
RE: Club FOX! - 7/5/2012 1:02 PM
Cougar429
Score: 128
Status: offline
I pulled the head and button yesterday and was found the screws not very tight. That may not have helped, but the behavior Monday follows almost directly that described in the Flightline Solutions for Fox column.
I found the head button to be identical to the second from the right in the Flightline pic, the exact same style I found in my 80's gen 50BB. Sorry for the focus on mine, still figuring out the new camera and macro was impossible to find in the time I had before work.
Can't tell how long this motor was stored NIB, but I suspect a bit longer than I originally thought. I did some of the modding suggested by Flightline, bevelling the squish band and radiusing the inner edge. This made a huge difference on the 50. However, I only took .015 off the top. I will try it first that way and tweak it again if necessary. I'll bring both the head and button back to work today and see about the cleaning up of the inner head surfaces for better heat transfer. I'm sure that, the rather loose head screws and the 96F environment would have helped add to the heat load.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2719
RE: Club FOX! - 7/5/2012 4:12 PM
Cougar429
Score: 128
Status: offline
I found what killed the plugs. There is nothing left of the back of the piston above the ring groove, It is totally busted off approx half way round. I strongly suspect detonation caused this.
Anyone have a spare piston?
Hide Signatures
       Post #: 2720
RE: Club FOX! - 7/5/2012 4:56 PM
earlwb
Score: 599
Status: offline
Aww man, major bummer. Fortunately they sell the pistons separate. So it shouldn't be a problem to get it from Fox.
AMA # 928076
Hide Signatures
       Post #: 2721
RE: Club FOX! - 7/5/2012 5:57 PM
Cougar429
Score: 128
Status: offline
Waiting for a reply from Fox as to price and availability. Also asked for the cost of a ring as I don't know what kind of pounding it took.
I pulled the sleeve and it is unmarked. Phew! As the head button was also unmarked the piston must have burned or broken away in microscopic bits. I took a look at the glow wire as best as I could, but will remove the idle bar to have a better view. From initial inspection the wire is not deformed.
Hide Signatures
       Post #: 2722
RE: Club FOX! - 7/5/2012 7:26 PM
hsukaria
Score: 185
Status: offline
Hi Cougar,
You might want to consider a new-style head button from Fox while at it. Not very expensive and known to help with overheating, as I experienced.
Hide Signatures
       Post #: 2723
RE: Club FOX! - 7/6/2012 4:01 AM
Cougar429
Score: 128
Status: offline
Do you know if the new head button incorporates the changes suggested from Flightline? Already made them to the stock button.
Got a reply from Fox and will look into replacement parts. Never had this sort of behavior in a brand new engine. Drats!
Hide Signatures
       Post #: 2724
RE: Club FOX! - 7/6/2012 2:25 PM
earlwb
Score: 599
Status: offline
Since cougar429 has a Eagle IV engine it very likely has the current head button in it. Unless someone had done some parts mixing and matching in the past. Such as setup the engine to run zero nitro glow fuel like they do in Europe, for example. Normally I don't consider the Perry carb a problem, as I never needed to use one on a Fox engine, but I know others did though.
My first thought was that the engine needed more running in. With Fox engines you need to run them in real good before you really try to dial them in for performance. Sometimes it takes a lot of patience if the cumulative tolerances of the assembled engine leaves it extra tight.  Next it is the fuel. I normally run 5% nitro content glow fuel in my engines, I rarely need 15%. Normally I don't expect the fuel to be a problem, but it might be with the Fox engine running on a tuned pipe setup. So the higher nitro content fuel can aggravate the situation and help cause detonation. Then running a tuned pipe like setup causes the engine to step up in power as it comes onto the pipe. This leads to detonation as the tuned effect pushes more fuel back into the cylinder that would have otherwise gone on out of the exhaust. Also when the engine comes up on the pipe, the compression ratio increases and can lead to detonation too. Usually you need to run a more cold heat range glow plug when using tuned pipes in order to handle the added heat and stresses from the combustion cycle going on inside of the engine. Worst case was maybe possibly running the engine too lean which can lead to detonation as the engine heats up a lot more. Now this is not lean where the engine would sieze but on the razor edge, so to speak.
So I would try some 5% nitro glow fuel and run the engine for a while longer to help run it in. Use that with the tuned muffler setup. Then try a colder plug to see what happens.  If the engine acts like the plug is too cold (engine drops in RPM a lot with glow ignitor off or doesn't idle too well) then  try your 15% fuel and see what happens.
AMA # 928076
Hide Signatures
       Post #: 2725
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Club FOX!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.985RCU1
