Club FOX!    Gallery
Logged in as Guest
Users viewing this topic: RknRusty
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Club FOX!
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Club FOX! - 9/13/2005 4:52 PM
RaceCity
Score: 100
Last Login: 10/13/2007
Status: offline
Enough ranting about this foreign stuff...
Let's talk about real AMERICAN IRON!!
There's nothing like the smell of Hot Mehanite and Castor in the morning....
.15BB, .25BB, .40BB and a slew of bushing .25's .29's and .36s.....all IRON PISTON.
DUKE DUKE DUKE!!!!!!!
_____________________________
AMA 63990
Hide Signatures
       Post #: 1
RE: Club FOX! - 9/13/2005 5:03 PM
Hobbsy
Score: 650
Last Login: 5/20/2013
Status: offline
An old .15 with a baffle in the exhaust, a modern .15, a .25, two .46s, four .50s, three .60s and three .74s. The .15, 2 of the .50s, 2 of the .60s and 1 of the .74s are converted to Diesel.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to RaceCity)
       Post #: 2
RE: Club FOX! - 9/13/2005 5:54 PM
simark
Score: 100
Last Login: 2/25/2013
Status: offline
I only have two, the .15 schneurle and the .25BB.
Sent the .15 to Fox for a carb problem, sent back the next week with a new carb! Terrific people there!
Iron ghaH QaQ vaD lIj pistons
Klingon for " Iron is good for pistons" There is no Klingon word for pistons and iron.
"Beware the man who doesn't make time for oo-mox."
Ferengi Rule of Acquisition #223
Hide Signatures
(in reply to Hobbsy)
       Post #: 3
RE: Club FOX! - 9/13/2005 7:31 PM
seanychen
Score: 105
Last Login: 2/23/2008
Status: offline
I would love to chime in, but the only Fox I've owned was the 74 Eagle. It was a powerhouse, but running it reliably was a different story...
E_Total = M*G*H + 1/2 M*V^2
When H=0, all of airplane's velocity becomes crash energy!
Hide Signatures
(in reply to simark)
       Post #: 4
RE: Club FOX! - 9/14/2005 2:05 AM
badger5964
Score: 110
Status: offline
Well have just run Fox eagle IV 74 and 60 ring. But also have a contender on the table destined for a Fox 46 ABC.
Love my Foxes!
Recently ordered a part from Fox and they sent a sales brochure. Back cover was a Fox Stunt 60. It looked a lot like an Eagle I. It was promised to be released soon and more to follow. Any one with a heads up on what this new stuff could be?
Hide Signatures
(in reply to seanychen)
       Post #: 5
RE: Club FOX! - 9/14/2005 3:10 AM
SST
Score: 100
Last Login: 11/30/2008
Status: offline
1 Deluxe .40, 3 BB Schneurle (1 used) (2 new), 1 Eagle .60. & 1 Eagle .74. BTW, those 2 new ones don't have mufflers, and I'd like to get MACs mufflers for 'em, but there's no direct application. Anyone know if I can modify pipes for something else to work?
Rule #1: Always know when to get out of Dodge.
Rule #2: Always know HOW to get out of Dodge.
Hide Signatures
(in reply to badger5964)
       Post #: 6
RE: Club FOX! - 9/14/2005 5:53 AM
AMB
Score: 110
Status: offline
So far only have one YUP a new fox 50 ringed they made one up took about a month, worth the wait , It has a davis diesel head. Just
an other example of their great service. Bring on the cheeseburgers not the Chinese takeout martin
Hide Signatures
(in reply to SST)
       Post #: 7
RE: Club FOX! - 9/14/2005 11:35 AM
NM2K
Score: 161
Last Login: 5/18/2013
Status: offline
I have two 1962 era Fox .15X control line engines and two seventies era Fox Eagle .60s (R/C). There may be more, but I'd have to look in the engine closet, which is unreachable at the moment. Yes, the wife and I are packrats. <G>
Ed Cregger
"Practice makes prefect"
Hide Signatures
       Post #: 8
RE: Club FOX! - 9/14/2005 4:32 PM
Rupurt
Score: 100
Last Login: 8/24/2011
Status: offline
I have a 20 year old bushed .25 which I havent managed to get running, It was given to me buy a guy at work. I think it would run If it had a new carb, Just don't know if its worth it really(what would you guys say?)
Somethings are stranger than fishin
Hide Signatures
(in reply to NM2K)
       Post #: 9
RE: Club FOX! - 9/14/2005 7:50 PM
NM2K
Score: 161
Status: offline
They do not need new carbs, if not broken.
Some of Duke's carbs required a special set up in order to run properly. Once figured out, they worked really well.
Ed Cregger
Hide Signatures
(in reply to Rupurt)
       Post #: 10
RE: Club FOX! - 9/14/2005 8:06 PM
Hobbsy
Score: 650
Status: offline
Rupert, it doesn't need a new carb, the .25 is a set and forget engine once the initial set is achieved.
Hide Signatures
(in reply to NM2K)
       Post #: 11
RE: Club FOX! - 9/14/2005 8:57 PM
Rupurt
Score: 100
Status: offline
I think the carb is actually damaged, I will get it out and post some pics, If you guys could help out that would be cool. It has a baffle on the exhaust if that helps identify it.
Hide Signatures
       Post #: 12
RE: Club FOX! - 9/14/2005 9:52 PM
NM2K
Score: 161
Status: offline
Damage is another matter entirely.
It sounds like the Fox .25 R/C (assuming it is R/C) that I bought for the wife's Falcon 56 in 1972.
It had an unusual low speed set up in that you had to rotate the fuel inlet nipple in order to adjust the low end. But it worked just fine.
Ed Cregger
Hide Signatures
       Post #: 13
RE: Club FOX! - 9/14/2005 10:39 PM
Rupurt
Score: 100
Status: offline
Thats the one. It will run of its prime but dies quickley.
Hide Signatures
(in reply to NM2K)
       Post #: 14
RE: Club FOX! - 9/14/2005 11:08 PM
RaceCity
Score: 100
Status: offline
If you're running off the prime then dying...either the needles are closed down, or something's clogged.
Open those needles a bit and run some fuel through the carb to flush it out. If it had been sitting a long time, some oil likely congealed in there and gummed things up a bit.
You can download a reprint of the original instruction manual for that motor from www.flitelinesolutions.com
Great site.
'Race
AMA 63990
Hide Signatures
       Post #: 15
RE: Club FOX! - 9/14/2005 11:24 PM
Rupurt
Score: 100
Status: offline
"If you're running off the prime then dying...either the needles are closed down, or something's clogged. " Thats what I suspected but couldn't get it right. Is the baffle necassery if you use an exhaust the linkage that connects the throttle to the baffle was missing, i had to make one and it wasn't quiet right. I would be keen to use this engine on a spad or something but it would definitly need a muffler.
Hide Signatures
       Post #: 16
RE: Club FOX! - 9/14/2005 11:54 PM
RaceCity
Score: 100
Status: offline
The butterfly valve on the exhaust was used as a means of retaining heat at idle so the motor would run better. It was a pretty common item on r/c motors in the days before people started complaining about noise, and we all had to go out and pop for a muffler.
(Actually...they complained before then, but nobody cared)
We'd need to see a pic of your motor to tell you what muffler you need. If it's a 70's vintage motor...they used a Fox "B" muffler, and those occasionally turn up on the internet auction sites.
Later versions of this motor used a muffler similar to that of today.
Worse comes to worse...there's always the strap-on mufflers. (cringe)
'Race
AMA 63990
Hide Signatures
       Post #: 17
RE: Club FOX! - 9/15/2005 12:02 AM
Rupurt
Score: 100
Status: offline
I will make one if I can get it to run. It has two threaded holes in the middle one above and the other below the port. So you are saying the baffle can be removed if I make a muffler?
Otherwise what sort of performance could I expect(the plane the engine was meant for never flew, apparantly the kit radio was never assembled so I guess it hasn't run much), will it be as powerful as my new tt25gp?
Here's the carb (from the link you posted)
Click to see fullsize image.
Click for fullsize
< Message edited by Rupurt -- 9/15/2005 12:08 AM >
Hide Signatures
       Post #: 18
RE: Club FOX! - 9/15/2005 12:16 AM
PlaneKrazee
Score: 205
Last Login: 6/21/2012
Status: offline
I would like to see them bring back the needle bearing crank/con rod for lower oil content fuel that thry used in the 60 and 74.
a never-ending battle for truth, justice and the American way
Hide Signatures
       Post #: 19
RE: Club FOX! - 9/15/2005 5:48 AM
Fuelman
Score: 100
Last Login: 9/27/2012
Status: offline
I guess I'll join this club too.
Have two 74's, run like a dream, never a deadstick. They do have Charles Thacker's modified head button which works great.
Couple old big frame 40's, couple small frame 40's, a 45 or two, a matched pair of brand new 50's.
I never owned a Fox that did not need a little of fiddling to get acquainted, then thay ran great. Most newer flyers can not handle a Fox since they require a proper break for the type of engine metalurgy they have (ABC or Lapped Iron or the ringed engines), certainly not a a box to flight engine.
I like them, light and powerful.
Fuelman
Cooper Fuels LLC
Hide Signatures
(in reply to PlaneKrazee)
       Post #: 20
RE: Club FOX! - 9/15/2005 6:25 AM
proptop
Score: 130
Last Login: 5/9/2013
Status: offline
Let's see...mine are mostly c/l engines.
I have a sand cast .29 w/ 4 head bolts...late 40's vintage maybe?
3, .35 stunt
2, .29's (newer ones )
and R/C I have a .15 sch. and old .25
Some of my most cherished memories are flyin' controlliners with my nephew when we were teens...
Most of it was w/ Fox power
< Message edited by proptop -- 9/15/2005 6:28 AM >
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
(in reply to Fuelman)
       Post #: 21
RE: Club FOX! - 10/2/2005 4:40 AM
dammitman
Score: 100
Last Login: 2/18/2009
Status: offline
i just got home from the field and had to change out my fox eagle 3 to a fox eagle 74. i burned up the eagle 3 due to a wrong size pipe i think. anyways,,,the eagle 74 i bought used with a pipe runs so good,,its unreal,,,,,,,,
Hide Signatures
       Post #: 22
RE: Club FOX! - 10/2/2005 4:44 AM
dammitman
Score: 100
Status: offline
if there was a fox club,,i know i would be in it. i am a big fox engine fan,,,,i know the problems and like to deal with them. i am sure you have all heard of flitelinesolutions.com it is a very good place to get info on fox engines. i tried to run a fox quickee 500 on a plane today but i have figured out what my problem is,,,fuel tank too low. dammitman!!!!,,,maybe a pump will fix that,,,,gonna see tomorrow.
Hide Signatures
(in reply to dammitman)
       Post #: 23
RE: Club FOX! - 10/2/2005 5:49 AM
RaceCity
Score: 100
Status: offline
What kind of problems are you having with the Quickee motor that makes you think the tank is too low?
Best solution is "raise the tank". These motors don't need pumps to run.
'Race
AMA 63990
Hide Signatures
       Post #: 24
RE: Club FOX! - 10/2/2005 7:45 AM
glowplugboy
Score: 115
Last Login: 4/7/2013
Status: offline
I have regained my respect for the Fox engine name in the last year or so. The little Fox .15 is a powerhouse and I use it week end, week out flying combat, which is the toughest form of r/c flying there is on an engine with all the dirt naps. Takes a lickin' and keeps on tickin'. Believe it or not, I am running it on 25% nitro with lots of castor oil in the mix. Runs hot as a firecracker but cranks out the power nevertheless
I have been bench running an ABC .46 with an APC 12 3/4" X 3.5 degree pitch fun fly prop, and within only 18 oz. of fuel, I am getting a steady 12.4K out of the engine. It goes through that six oz. tank in a hurry though, whewww!
The fact that Fox now has CNC machines along with their hand set up machines says to me they are trying to compete with the imports. I just wish they made a straight muffler, not a tilt up or down!!!
Representative of<br>
GCBM R/C Enterprises
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Club FOX!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
