RE: Club FOX!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Club FOX!
Page: <<   < prev  113 114 115 116 117 [118] 119 120 121 122   next >   >>
Login
RE: Club FOX! - 12/22/2012 11:14 PM
hsukaria
Score: 185
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: SRQFlyer
Cougar,
I have one in my hand - 1/4x28x1/2'' NIP (old stock). PM me your address and it's yours for Christmas.
Regards,
Jim
Well! If you want to be Santa, I have this whole list of things I need...
Actually, I have a similar need to space out the spinner backplate 1/8 inch. But I was worried about putting a spacer between the engine and spinner backplate. Does anybody know how to handle that? As it is, the spinner backplate rubs against the engine cowl. I bought this plane used and the engine mount holes came predrilled for some other engine.
_____________________________
Content, but not Complacent.
Saito Club Member #765
Hide Signatures
(in reply to SRQFlyer)
       Post #: 2926
RE: Club FOX! - 12/22/2012 11:54 PM
Cougar429
Score: 128
Last Login: 5/17/2013
Status: offline
Sent. Thanks a lot.
hsukaria, in cases like yours I find it a lot easier simply to replace the engine mount. You retain the full strength and unless other openings don't restrict engine shift this may be the best option.
Another thing I've found is the plastic spinners usually are countersunk, meaning the thrust washer is recessed forward into the spinner back plate. Alloy spinners are usually flush so give you a bit of leeway.
Club Saito Member # 787
FA91, 100, 2 X 125a, 150
Hide Signatures
       Post #: 2927
RE: Club FOX! - 12/23/2012 12:15 AM
SRQFlyer
Score: 100
Last Login: 5/22/2013
Status: offline
Santa here -
Try a piece of thick leather as a spacer. An added bonus is that the prop will never slip!
Happy Holidays!
Jim
AMA 106594, CG Ult 10-300 Bro #38, Club Saito #699 (45, 50, 56, 2x72, 82, 91, 120, 2x 150)
Hide Signatures
(in reply to hsukaria)
       Post #: 2928
RE: Club FOX! - 12/23/2012 4:23 AM
hsukaria
Score: 185
Status: offline
I am using an aluminum spinner, so, the backplate is flat. I thought about adding a plywood piece between the firewall and the engine mount. But that is a lot more work than a piece of leather. I now have an extra spinner backplate between the engine and the spinner backplate. But have not run the engine with that setup fearing that it will slip and loose up during flight.
Hide Signatures
       Post #: 2929
RE: Club FOX! - 12/23/2012 5:00 AM
Cougar429
Score: 128
Status: offline
I found the original mount on Rare Bear was far too flexible. Although it kept quite a bit of the engine pulses out of the airframe, it allowed so much movement throttle was affected. The only real option with what I had available was to fab a spacer such as hsukaria mentioned. In this case the engine ended up in the same place so there was no need to redo the cowl. Just the mount was altered, but the theory should be the same.
Here are pics of the original mount and the new setup. In this case I turned the spacer out of a spare block of 1/2" Delrin.
I'm always reluctant to add anything other than a spinner backplate between the prop and drive washer as that is the fixed surface the prop aligns to. Personally, although I agree the leather would provide a good power path to transfer output to the prop, IMO working on the assumption the center hole will keep the prop true is asking too much. Any hard material could damage the legacy drive face and not provide good contact. Perhaps soft alloy, composite or even a plastic washer would be better? As long as the crush is uniform it should work.
I would also hope there are at least two threads showing beyond the front of the prop nut, from what I remember what we consider "Safety" in maintenance, (AC4313). Been a while. I would have to pull the book out to confirm.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2930
RE: Club FOX! - 12/23/2012 4:21 PM
hsukaria
Score: 185
Status: offline
Well, flying season is over in these parts. So, I will have some time to fix this by redoing the engine mount. It's better to make sure I got it 100% right now in preparation for flying season. I will try a spacer between firewall and engine mount or new mount.
Nice engine by the way.
Hide Signatures
(in reply to Cougar429)
       Post #: 2931
RE: Club FOX! - 12/28/2012 10:38 AM
koastrc
Score: 137
Status: offline
This is the only forum I follow. I do not have a FOX in my hanger, but have owned many. Lost them all in Katrina. I enjoy this section so much. Not only is it full of good tech insight , but some real nice people. I figured I knew about as much as anyone about FOX engines. You folks have taught me I still have much to learn. Happy New Year and keep the post coming.
Hide Signatures
       Post #: 2932
RE: Club FOX! - 12/28/2012 2:16 PM
Cougar429
Score: 128
Status: offline
I would imagine a "Welcome" is in order. Hopefully your hangar will be infested with Foxes again soon.
This confirms a tenet I live by, basically that if you do not learn something new every day, or take knowledge with you without imparting it to others is a waste of effort, ("taking up room in the food chain" is my more colloquial term).
Hide Signatures
(in reply to koastrc)
       Post #: 2933
RE: Club FOX! - 12/28/2012 3:59 PM
earlwb
Score: 584
Status: offline
quote:
ORIGINAL: hsukaria
I don't know, I still see lots of folks flying in the winter. Some sea plane like aircraft do well for taking off and landing in the snow too.
Then there are the guys with ski's on their planes as well.  Besides there is always the little hand launch planes also.
I remember using a large transmitter cover to help keep my hands a little warmer in the past. I have had to use a heat shrink tubing gun to warm up engines before.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 2934
RE: Club FOX! - 12/28/2012 4:28 PM
aspeed
Score: 105
Status: offline
Indoor flying is better.  Lots of micro planes to choose from.  Driving to Florida or Texas to fly is good too.
Hide Signatures
(in reply to earlwb)
       Post #: 2935
RE: Club FOX! - 12/28/2012 4:34 PM
Cougar429
Score: 128
Status: offline
Other than the float equipped craft, these are my most versatile. The Seamaster 40 in the foreground sported a Fox 50 for over 20 years.
All can fly from water, snow or land, (with the gear reinstalled) while the Polaris is RTF from any surface as soon as the battery is connected.
Click for fullsize
< Message edited by Cougar429 -- 12/28/2012 10:07 PM >
Hide Signatures
(in reply to aspeed)
       Post #: 2936
RE: Club FOX! - 12/28/2012 6:32 PM
aspeed
Score: 105
Status: offline
My seamaster has a ST .51. I should get it going. I have a couple of Aquastars, one was brushed electric with nicads and another was a Norvel .049. Neither one would take off water.
Hide Signatures
       Post #: 2937
RE: Club FOX! - 1/5/2013 5:38 AM
hsukaria
Score: 185
Status: offline
quote:
ORIGINAL: earlwb
quote:
ORIGINAL: hsukaria
If it were dry snow, I can put skis or floats on my Sig Rascal 40. I will have to work out the logistics of warmer clothes and transmitter cover. The plane has plenty of power for floats or skis.
Hide Signatures
       Post #: 2938
RE: Club FOX! - 1/5/2013 3:42 PM
aspeed
Score: 105
Status: offline
I think skis take less power than wheels.  The old Zippo type fluid is good for priming in cold weather.  I think a couple of spare batteries that are warm and flying electric is the best for winter flying without a heated clubhouse.  It is just too hard to position tubing for fueling and putting in screws etc when it is real cold.  A trip to Florida or indoor flying is the best solution IMHO.
Hide Signatures
       Post #: 2939
RE: Club FOX! - 1/22/2013 6:34 AM
50+AirYears
Score: 120
Last Login: 2/9/2013
Status: offline
Maybe the thing I like best about flying in the winter here on the Sunny South Shore of Lake Erie is not having to contend for flight stations and frequency clips. Haven't missed a month flying since 1990.
Fox engines seem to not notice the cold. One fine February day, I got in a few flights with my Scnuerle .25 while other club members were going nuts trying to keep their ST and OS running.
A couple years ago, I got a Flite Streak ARF at a low price. I put out a couple posts on CL sites about which engine I should use on it, one of my Veco, Johnson, or Fox .35s, or my Fox .25 Schnuerles. Nearly all of the respondents said to get an LA .25, everything else I named was too hot for the fuse.
Hide Signatures
       Post #: 2940
RE: Club FOX! - 1/22/2013 2:39 PM
aspeed
Score: 105
Status: offline
We used to race the Fox .35 motors in Flight Streak type planes, and then the rules were changed to only allow the LA .25, which meant I was stuck with a bunch of Fox .35's.  Nevertheless, the LA .25 is actually faster than the old Foxes, but they shake and vibrate much less so it is easier on the fuselage.  I am on the north shore of the same lake pretty much, it is pretty windy most of the time here for comfortable winter flying.  I think the Fox has a tamer bowl type head with a smaller squish band and lower compression to make it start better and take bigger props.(and save on plug elements)  At least on my .15 schneurle motor.  I made a higher compression head for it and it went a fair bit faster, but changed the characteristics that foxes are 'loved' for.
Hide Signatures
(in reply to 50+AirYears)
       Post #: 2941
RE: Club FOX! - 1/23/2013 4:21 AM
50+AirYears
Score: 120
Status: offline
I remember a couple CL Combat columns in the old Model Builder magazines.
One, flyers could buy a Fox .15 Schnuerle BB for about $35, or a Nelson for $150 for a few hundred more RPM.
Second one, the writer stated he'd practice using Fox Schnuerle 40s, and then change to a Nelson .36 for competition. Planes flew about the same.
I also remember at a February Chili fly-in at the old CL field, guy with a high tech Slow Combat plane. "That D*** Fox Combat Special. I needed two flips to get it running !" (About 10 degrees F)
Hide Signatures
       Post #: 2942
RE: Club FOX! - 1/23/2013 6:31 AM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: Cougar429
Sent. Thanks a lot.
Does it really matter?  If they extended the shaft a foot, some builders will still manage to install the cowl where it rubs the back of the spinner.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 2943
RE: Club FOX! - 1/23/2013 2:45 PM
hsukaria
Score: 185
Status: offline
quote:
ORIGINAL: Sport_Pilot
quote:
ORIGINAL: Cougar429
Sent. Thanks a lot.
True,
In the case of my plane, the cowl would have to be ripped up really bad if I move the engine forward even 1/8 inch. So, an extension of only 1/8 inch is all I need. I've seen the opposite in many planes, the gap between the spinner and cowl is vast. That looks goofy.
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 2944
RE: Club FOX! - 1/23/2013 4:43 PM
earlwb
Score: 584
Status: offline
Fox sells the 1/2 inch and 3/4 inch propeller extensions that work really well too. That is usually what folks use to mount the engine inside of a cowl on some models. For 1/8 of a inch one could likely find that some spinners without a recess work Ok in that case. But using a wide thin washer would likely work too.
AMA # 928076
Hide Signatures
       Post #: 2945
RE: Club FOX! - 1/23/2013 5:05 PM
hsukaria
Score: 185
Status: offline
I will be trying a big washer or a backplate of a smaller spinner begween the prop driver and the spinner backplate. I hope that gives enough friction.
Hide Signatures
       Post #: 2946
RE: Club FOX! - 2/5/2013 9:26 PM
LaRebel24
Score: 100
Last Login: 5/13/2013
Status: offline
Hi.....Was wondering if anyone knows if the Flight Line Solutions website is still up and running and if so what is the site address. Any info on this matter would be appreciated..
Andrew
WATCH OUT FOR THOSE PROP EATING GOPHERS!!!!! AMA 202955
Hide Signatures
(in reply to RaceCity)
       Post #: 2947
RE: Club FOX! - 2/5/2013 11:15 PM
earlwb
Score: 584
Status: offline
quote:
ORIGINAL: LaRebel24
Andrew
It was saved and archived here now http://members.shaw.ca/flitelinesolutions/manuals.html
AMA # 928076
Hide Signatures
(in reply to LaRebel24)
       Post #: 2948
RE: Club FOX! - 2/6/2013 7:57 PM
LaRebel24
Score: 100
Status: offline
Thanks for the info.
Andrew
Hide Signatures
       Post #: 2949
RE: Club FOX! - 3/9/2013 11:56 PM
Cougar429
Score: 128
Status: offline
Thought I would relay some good news. I finally sent in the Eagle IV 60 and was given the report Thursday. I posted pics of this one a while ago, but thought it may be helpful with a short review.
After only a few tankfuls it killed two plugs in a row so I pulled the head and found the entire back of the piston missing down to the ring. I thought it was perhaps the 15% fuel and fabbed some new buttons to try on the second identical engine. Found the behavior a bit dicey as it was early in break in. However, the lowest comp button seemed to generate the best numbers and behavior. Again, that will need to be tentative until it settles in.
It seems the piston was faulty as they could tell the motor had low time. Under warranty it now sports a new piston and ring and run in to set the carb. Was told my fuel should be fine, but they installed the new head button. Will be interesting to compare it to my home grown versions.
Called Friday to figure out how to get it home and found they are closed. Second US manufacturer I called within the last week to find that is their normal schedule. Interesting.
Will find out Monday if postage will be the best option or to have them bring it to Toledo and pick it up there. Great product and service and they stand behind what they make. Rarer these days.
< Message edited by Cougar429 -- 3/10/2013 3:36 PM >
Hide Signatures
       Post #: 2950
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Club FOX!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.860RCU1
