RE: Smokin USS
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> RE: Smokin USS
Page: <<   < prev  1 [2]
Login
RE: Smokin USS - 5/1/2006 4:14:05 AM
flybug
Status: offline
Gravityisnotmyfriend, thanks for the tip. I am planning on a .46 in the spadet. Guess I will take your advise and just wait on the smoke for a bigger plane
_____________________________
My grandfather always said that living is like licking honey off a thorn. - Louis Adamic
(in reply to Gravityisnotmyfriend)
       Post #: 26
RE: Smokin USS - 5/1/2006 2:12:42 PM
Omaha_RC_Flyer
Status: offline
flybug,
If you ever get ambitious, and build a USS or Chris' 25cc UStick, you can find Ryobi engines on ebay brand new, for less than what you would pay for a O.S. .46AX. I bought mine for around $100.00 and it was already converted. It was a factory reconditioned one, but it must have had very little time on it prior to reconditioning, because it is still breaking in. If you like tinkering and want to convert it yourself, check out wackerengines.com they sell all you need to convert one.
A friend gave me a Ryboi a few days ago that had very little time on it, before the shaft broke. Check this out, a week earlier I had a different friend over with his son showing them my weed wacker plane (USS), and he said I have a Ryobi weed eater you can have, since I'm going to get a new weedeater this year. CAN ANYONE SAY TWIN!!
Later,
Omaha
< Message edited by Omaha_RC_Flyer -- 5/1/2006 2:13:27 PM >
Team Spadworld
www.spadworld.net
(in reply to flybug)
       Post #: 27
RE: Smokin USS - 5/1/2006 2:16:37 PM
flybug
Status: offline
Good point there Omaha_RC_Flyer I'll have to build one of these birds... it is definately on my to-do list I will hunt the bay for these ryobi engines.
(in reply to Omaha_RC_Flyer)
       Post #: 28
RE: Smokin USS - 7/19/2006 1:11:22 PM
cpki
Status: offline
LOOK...simplest set up for a small plane all you need is a estes model starter thingy (igniter) and a extra channel with a battery and a switch..heck you could even hook up two!!! http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFT71&P=7
       Post #: 29
RE: Smokin USS - 8/3/2006 3:13:37 AM
Stubshaft
Status: offline
I also remember running pressure from the crankcase to the tank. But this looks like a great setup.
If the Professor can make a battery out of a coconut. Why can''t he fix a hole in the boat?
       Post #: 30
RE: Smokin USS - 6/28/2007 2:54:31 PM
Omaha_RC_Flyer
Status: offline
Here are a few pictures of the my USS at Spadfest 07 pouring the smoke on.
Later,
Omaha
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Omaha_RC_Flyer -- 7/12/2007 7:23:08 PM >
Team Spadworld
www.spadworld.net
(in reply to Stubshaft)
       Post #: 31
RE: Smokin USS - 7/12/2007 4:09:40 PM
coolbean
Status: offline
@#$%@%&@#$%^@#^@^@%^#$%&@^@$%^@@#^@#$^WE$%^@$%^$%^@$%^@........
As if I didn't have enough to worry about on the spad spitfire... now I've got to add a smoke pump... Thanks a lot Omaha, if your USS didn't look so good with the smoke pouring out of it, I wouldn't be in this situation...
"Some people without brains do an awful lot of talking, don't they?" -- Scarecrow, Wizard of Oz
       Post #: 32
RE: Smokin USS - 7/18/2007 12:26:03 AM
3g_kite
Status: offline
tele ho!
Since I am from Slovenia (Europe) and we do not have such fancy packed smoking oils around here, and i am just about to install some smokewriter to my Giles 202 with 26ccm MVVS gas engine - what would be the best fluid to try smokin? I have read some threads about using Diesel Gasoline and such, but i found that bit dangerous (or not?)?
Omaha - great thread, and cool effects with your plane!!
Best regards from the sunny side of the Alps!
3g
(in reply to coolbean)
       Post #: 33
RE: Smokin USS - 7/18/2007 3:10:23 AM
Omaha_RC_Flyer
Status: offline
3g,
Here are some links that might help you decide what to use. If I can find the others links in my bookmarks, I'll post them as well.
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=455
http://soldcentralfl.com/flyingpenguin/smoke.htm
Later,
Omaha
Team Spadworld
www.spadworld.net
(in reply to 3g_kite)
       Post #: 34
RE: Smokin USS - 7/18/2007 2:39:53 PM
Clean
Status: offline
You MIGHT want to rethink the smoke system Bean, let Mike show you a picture of his Horizontal.
Some strange reason, the smoke oil he uses messes with the Coroplast.
From Somewhere near Parkville, Mo.
William Crane (aka Mr Clean) Rever Brother #168 Time Man of the Year
       Post #: 35
RE: Smokin USS - 7/18/2007 3:22:03 PM
Omaha_RC_Flyer
Status: offline
quote:
ORIGINAL: Clean
He is right, there is something in the Super-Dri oil, that distorts and warps the coro. I'm going to try an replace the Stab on my USS with white coro, and see if it has the same effect. If it does, then I need to start looking for a good smoke oil recipe, that will not distort the coro.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team Spadworld
www.spadworld.net
(in reply to Clean)
       Post #: 36
RE: Smokin USS - 7/19/2007 3:39:51 PM
coolbean
Status: offline
Yeah..... ok... no smoke...
       Post #: 37
RE: Smokin USS - 3/19/2008 11:48:31 PM
Johnny C!
Status: offline
Thanks Omaha!
Johnny C!
I think I might know somebody that
has a low time Homelite 25 that runs
real good for sale...
Let me know...
< Message edited by Johnny C! -- 3/20/2008 12:37:01 AM >
"...and once man has tasted flight, he will walk the earth
with his eyes turned skyward... L. DaVinci.
       Post #: 38
RE: Smokin USS - 3/25/2008 7:16:06 PM
mustangman177
Status: offline
If you use crankcase pressure to pump smoke from the tank to the muffler, where would you "Tap" into a Ryobi 31 engine for this ?
Would this be as effective in providing smoke to the muffler than a pump would ? This would also do away with the battery pack needed to run the pump-a large savings on weight.
What kind of "On-Off" switch would this system have, since there is not pump to turn on and off ?
*Found this answer from MinnFlyer's article "Got Smoke ?" Where it says it requires an extra servo to actuate a valve.
Would like to hear from anyone using this method.
Cary
< Message edited by mustangman177 -- 3/25/2008 7:21:50 PM >
(in reply to Johnny C!)
       Post #: 39
RE: Smokin USS - 3/27/2008 5:09:21 PM
mustangman177
Status: offline
Update !!!
After researching and reading "More Smoke! I Wand To Die!" by the flyingpenguin (Thanks Omaha RC Flyer for the link), I've decided to go the pumped smoke route instead of tapping the crankcase of the engine. Not that crankcase pressure wouldn't work, For my first attempt at this I want to go with a true an tried version.
Drilled and JB welded a 1/8" copper tube to the exhaust port of the Ryobi 31 engine I'm using in my USS. Positioned the end of the copper tube so that the smoke oil will exit where the exhaust exits the engine (Hottest area ?).
Looking at using a windshield washer pump from Autozone. The one I'm looking at (On internet) doesn't say if it is self priming or not. Called the
store and they didn't know either. Cost around $17.99. Have to read the instructions with the pump to find out I guess.
What micro-switch are you using to activate the pump ? RadioShack's web site didn't show one like in your picture Omaha RC Flyer. Could you tell me where your's came from ?
Would Dubro's Kwik Fuel fuel pump that is rated for bot
