Smokin USS
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Smokin USS Page: [1] 2   next >   >>
Login
Smokin USS - 9/13/2005 3:59:07 PM
Omaha_RC_Flyer
Status: offline
Here are a few shots of my Smokin USS. I followed the How to article by MinnFlyer Total cost about $30.00! I'm using a windshield washer fluid pump, and MDW Super Dri smoke oil. I was able to get some video of it with my standard 8mm Camcorder. Once I get the video transferred to a CD/DVD, I'll try to post it.
Later,
Omaha
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Omaha_RC_Flyer -- 9/13/2005 4:00:31 PM >
_____________________________
Team Spadworld
www.spadworld.net
       Post #: 1
RE: Smokin USS - 9/14/2005 3:05:46 AM
acam37
Status: offline
I think smoke is awesome. When you post the video can you show us the interior layout? Also I would really like to see that coro field box that is in the 3rd pic.
(in reply to Omaha_RC_Flyer)
       Post #: 2
RE: Smokin USS - 9/14/2005 6:17:45 AM
Omaha_RC_Flyer
Status: offline
Got you covered on the Coro field box. See the thread I started on it. You may want to play around with the measurements to get the size you would like. I'll try to get a photo of the interior layout posted for you later on.
Later,
Omaha
Team Spadworld
www.spadworld.net
(in reply to acam37)
       Post #: 3
RE: Smokin USS - 9/14/2005 8:57:12 PM
Omaha_RC_Flyer
Status: offline
Acam,
Attached are a few photos of my smoke system layout. I have to use hemostats to clamp the line on the outside of the fuse (muffler line) when I fill the tank or part of the oil will exit out through the pump to the muffler line, which in turn, wastes oil. Once clamped, the oil will only go so far, while the remainder of the oil fills the tank, until it empties out the vent line.
The smoke pump is powered by a 4.8 volt pack, while the RX is powered by a 6.0 volt pack. If you use a windshield washer pump, make sure to run a tank full of oil through it before you install it, using a 12 Volt power source. Just pump it back through the vent line like a closed loop system. It really gets everything seated and working, before dropping the power to the lower 4.8 volt pack.
Hope this helps,
Omaha
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Omaha_RC_Flyer -- 9/14/2005 9:28:30 PM >
Team Spadworld
www.spadworld.net
       Post #: 4
RE: Smokin USS - 9/14/2005 9:10:55 PM
Omaha_RC_Flyer
Status: offline
A few more photos!
Later,
Omaha
Click for fullsize
Click for fullsize
Click for fullsize
Team Spadworld
www.spadworld.net
       Post #: 5
RE: Smokin USS - 9/14/2005 10:05:14 PM
ChrisSpad
Status: offline
i'll tell you a secret about smoke - but, use it at your own risk. You can install a line from the crankcase into a one way valve - pointed so that the "out" side is pointed to the smoke tank (just like the exhaust setup on your glow engines), and then out of the tank, into a dubro cutoff valve, and elliminate the pump altogether - however, if you don't use a very high quality tank, the pressure gets super high, and they've been known to explode, and coat the inside of your fuse with smoke oil - with a coro plane, its not really a big deal, but with wood- yuck.
At any rate, your setup looks great - what'd you use for a power supply and cutoff switch? I had a TME smoke pump setup once upon a time - ended up replacing their pump with a windshield washer pump - but using their electronic switch setup. I had more problems with that darned pump than i care to remember. I think i actually got it to smoke a grand total of 3 or 4 times in the air.
Hopefully, you'll have better luck than i did.
No matter how many planes i plant, they just won't grow.
[link]http://www.chrisspad.com/planes/[/link]
       Post #: 6
RE: Smokin USS - 9/15/2005 5:54:43 AM
Omaha_RC_Flyer
Status: offline
Chris,
I'm using a standard 4.8 volt rx battery pack for power. I connected it to a contact type Micro switch. When I flip a switch on my Tx, the servo horn presses on the micro switch, and the pump starts. When I flip the Tx switch back the micro switch is released, breaking the circuit. (See attached photo for close up view)
As far as wiring it. I soldered the positve motor wire and the positve battery wire to the micro switch. Then I soldered the negative battery wire to the negative pump wire and covered it with heat shrink. (See attached drawing)
Later,
Omaha
Click for fullsize
Click for fullsize
< Message edited by Omaha_RC_Flyer -- 9/15/2005 2:33:08 PM >
Team Spadworld
www.spadworld.net
(in reply to ChrisSpad)
       Post #: 7
RE: Smokin USS - 10/20/2005 3:25:55 AM
Omaha_RC_Flyer
Status: offline
Here is a link to some video I got today of the USS smokin in flight.
http://media.putfile.com/SmokinUSS_0002
Later,
Omaha
< Message edited by Omaha_RC_Flyer -- 10/24/2005 3:55:26 AM >
Team Spadworld
www.spadworld.net
       Post #: 8
RE: Smokin USS - 11/5/2005 3:41:18 PM
WILDCRASHWILLY
Status: offline
What did you use for a check valve between the muffler and the tank, and where did you purchase the valve?
< Message edited by WILDCRASHWILLY -- 11/5/2005 3:42:02 PM >
Bill
       Post #: 9
RE: Smokin USS - 11/5/2005 11:45:08 PM
Omaha_RC_Flyer
Status: offline
I purchased this check valve at my local hobby shop. Make sure to get the one for Gasoline if you are using it for a smoke system. Fourmost also makes a glow version check valve, that is red/white.
Later,
Omaha
Click for fullsize
Team Spadworld
www.spadworld.net
(in reply to WILDCRASHWILLY)
       Post #: 10
RE: Smokin USS - 11/8/2005 9:06:11 PM
WILDCRASHWILLY
Status: offline
Thanks Omaha,
I'm going to try to build one of these.
Bill
       Post #: 11
RE: Smokin USS - 4/24/2006 12:55:49 AM
Gravityisnotmyfriend
Status: offline
OK, so this plane isn't a SPAD, but the smoke setup was taken from this thread. The pump is a windshield fluid pump out of a junked car and is actuated with a micro-switch from radioshack. I used the same method for a regulating valve as what MinnFlyer suggested. Total money invested is about $8 for the switch and one way valve. I haven't tried it in the air yet as I just got everything plumbed and I just had to try it out in the backyard. I'm really looking forward to seeing this in the air. Thanks to Omaha and MinnFlyer for the plans.
Click for fullsize
The mathematician sees the glass as twice as big as it needs to be. The engineer sees it as full with a Safety Factor of 2.
       Post #: 12
RE: Smokin USS - 4/24/2006 3:02:25 AM
Omaha_RC_Flyer
Status: offline
Gravityisnotmyfriend,
You can regulate the oil flow by running the oil clunk line, after it leaves the tank, through an electrical lug (see photos), before it enters the pump. Mount the lug in a way you can have access to the screw from the out side of the fuse. Turn the screw in, to pinch the line and reduce the oil flow, or turn it out to increase the oil flow. This is what I used at first, but I found that using a 4.8 volt pack delivers the right amount of smoke oil without the need for a lug (to reduce the flow) on my USS smoke set-up.
Later,
Omaha
Click for fullsize
Click for fullsize
Click for fullsize
Team Spadworld
www.spadworld.net
(in reply to Gravityisnotmyfriend)
       Post #: 13
RE: Smokin USS - 4/24/2006 4:07:49 AM
