Beaver Fever
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Seaplanes >> Beaver Fever Page: <<   < prev  1 [2]
Login
Beaver Fever - 11/1/2002 12:38 AM
Blackhawk RCU
Score: 100
Last Login: 10/1/2009
Status: offline
I was given the following advise which I shall pass on. I had a plane that had been flown exclusively off floats for two years and never dunked. On the advice of a friend I pulled the receiver deck and found it had a coating of corrosion all over it. I bought some spray cleaner from a marine supply house This is used for cleaning and protecting radios and radar from corrosion. I loaned the can out and didn't get it back so I don't recall the name but this product is in a spray can and dissolved the corrosion instantly. It drys very fast and will not harm your gear. This is now part of my preventative maintenance.
Hide Signatures
(in reply to Shawnusa)
       Post #: 26
deHaviland beavers - 11/1/2002 12:50 AM
TurboOtter
Score: 100
Last Login: 8/31/2003
Status: offline
ACF 50... We use it on our fullsize seaplanes which live in saltwater. It is expensive, but nothing is better http://www.learchem.com/Aviation.htm I have used it on recievers and servos which have been in saltwater(don't ask) and salvaged them.Great stuff
_____________________________
"Any Landing you can walk away from is a good one"
Wilbur Wright December 17, 1903
Hide Signatures
       Post #: 27
Beavers - 11/1/2002 2:35 AM
Blackhawk RCU
Score: 100
Status: offline
That's the stuff I was talking about, lasts forever if you can just remember who you loaned it to.
Hide Signatures
       Post #: 28
deHaviland beavers - 11/1/2002 2:45 AM
JimCasey
Score: 100
Last Login: 3/19/2010
Status: offline
That sounds like a product I have used called Corrosion-X.
It prevents nasty mung from attacking your circuit boards, and is a pretty good penetrating lubricant, too. I wonder if it would be good as an after-run oil......
http://www.corrosionx.com
Jim Casey/Seaplane Nerd
http://www.smilesandwags.com/Floats.html
Hide Signatures
       Post #: 29
Zimpro Beaver - 11/5/2002 12:21 AM
Blackhawk RCU
Score: 100
Status: offline
I got a PM from someone about this Beaver and am working on one now. Does any one know its all up weight? I am thinking about using a gas engine instead of my OS 3500. Thinking about a BME 50. Overkill or good ballast for a short nose moment?
Hide Signatures
       Post #: 30
16 lbs and 21 lbs - 11/5/2002 3:05 AM
tonyc
Score: 100
Last Login: 1/2/2010
Status: offline
When I called Dennis to ask about this kit he said the proto type came in at 16 lbs without floats and 21 lbs with floats. He said that you need at least the Moki 180 if you intend to fly off water.
tonyc
Hide Signatures
       Post #: 31
1/3 scale Beaver - 11/5/2002 5:37 AM
Forgues Research
Score: 100
Last Login: 3/14/2010
Status: offline
Here is a large scale Beaver as a school project.
http://www.geocities.com/roger_forgues/Works.html
http://www.rcxmachines-na.com
Hide Signatures
       Post #: 32
Clarifications - 11/15/2002 9:01 AM
Sea Commander
Score: 100
Last Login: 2/2/2010
Status: offline
I would like to clarify two items on these posts.
#1--- In post #2 by scale_only_4_me. In the picture of the Ikon Northwest Beaver the model is mounted on Seacommander fiberglass scale Beaver floats, not the Ikon built up floats. The model was built by a customer from Montana who did a beautiful job on this model. He also sent me the same photos.
#2 --- In post #24 by n64uw, The message states that Commander Floats is another business of Murray Marley, of Coastline R/C. Not so. Commander R/C Models builds the fiberglass fuselages, floats and other glass components of Murray's Beaver kit but it is not one of Murray's businesses. Murray is a good friend of ours and he puts a lot of care and attention into his kit. It is a beautiful and exact scale model.
Commander R/C Models is owned and operated by Gord Whitney and Linda Kolke.
Check us out at http://www.seacommander.com
Gord Whitney
The bitterness of poor quality remains long after the sweetness of low price is forgotten
Hide Signatures
       Post #: 33
deHaviland beavers - 11/15/2002 11:09 AM
Bud Faulkner
Score: 105
Last Login: 7/28/2008
Status: offline
Gord, your floats are great and I wish I had one of Murrays beavers...one beautiful kit. Here's a picture of a set of sea commander 46" floats i'm working on right now. Great product.
Bud
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 34
deHaviland beavers - 11/15/2002 11:16 AM
Bud Faulkner
Score: 105
Status: offline
Here's another view with my own custom brackets I made.
Click for fullsize
Hide Signatures
       Post #: 35
deHaviland beavers - 11/17/2002 7:08 AM
seaplane
Score: 100
Last Login: 3/18/2010
Status: offline
I just ordered a fiberglass cowl from Unionville Hobbies and they gave me a web site for Beaver documentation. It's dhc-2.com. Hundreds of pictures! I guess this guy is trying to document every Beaver ever built. I found the one I flew in this last June in Fairbanks, Alaska. Great site.
Hide Signatures
       Post #: 36
deHaviland beavers - 11/17/2002 7:48 AM
kevin mcgrath
Score: 100
Last Login: 3/10/2010
Status: offline
That site is [url]www.dhc-2.com[/url] superb!
Kevin
MAAC 6401L,CD.
Hide Signatures
       Post #: 37
RE: Beaver Fever - 9/9/2009 1:44 PM
wstafford
Score: 100
Last Login: 2/3/2010
Status: offline
Can anyone give me the completed weight of the 1/4 scale Unionville Hobbies Beaver without the engine?
Hide Signatures
(in reply to kevin mcgrath)
       Post #: 38
RE: Beaver Fever - 9/10/2009 1:37 AM
Crash-RCU
Score: 100
Status: offline
Dont,t know the exact weight but seen one fly with floats a little over a week ago that was powered by a Saito 100, they said it weighed about 10lb.
Garry J
Hide Signatures
(in reply to wstafford)
       Post #: 39
RE: Beaver Fever - 9/10/2009 2:55 AM
wstafford
Score: 100
Status: offline
That weight doesn't sound right. Unionville say's 30+ pounds on wheels and 40+ with floats.
Wes
Hide Signatures
(in reply to Crash-RCU)
       Post #: 40
RE: Beaver Fever - 9/10/2009 5:36 PM
Crash-RCU
Score: 100
Status: offline
Wes, My mistake sorry, that weight was for the 8' Beaver and not the 1/4 scale.
Garry J
Hide Signatures
       Post #: 41
RE: Beaver Fever - 9/10/2009 7:28 PM
wstafford
Score: 100
Status: offline
No problem. I do appreciate your effort. Friend of mine has a 14 pounder 8' with a Satio 180 on it.
Wes
Hide Signatures
       Post #: 42
RE: Beaver Fever - 9/11/2009 3:09 PM
Baldeagle
Score: 100
Status: offline
Here is some pic of my Unionville Turbo Beaver. 16 lbs, Saito 150. Floats made from foam shaped to plans . Easy flyer. Rich
Click for fullsize
Click for fullsize
Click for fullsize
Rich
Hide Signatures
       Post #: 43
RE: Beaver Fever - 9/11/2009 3:15 PM
Baldeagle
Score: 100
Status: offline
Also here is a thread you might want to check out. http://www.rcuniverse.com/forum/m_1304564/anchors_1304564/mpage_1/key_/anchor/tm.htm#1304564
Rich
Hide Signatures
(in reply to Baldeagle)
       Post #: 44
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
