RE: Air Hogs Aero Ace!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Indoor & Micro RC Flight >> RE: Air Hogs Aero Ace! Page: <<   < prev  265 266 267 268 269 [270] 271 272 273 274   next >   >>
Login
RE: Air Hogs Aero Ace! - 7/30/2008 12:59:36 AM
FERNDALE AIR FORCE
Status: offline
I found this one, http://www.amazon.com/Yellow-Double-Wing-Aero-flyer/dp/B001154R3Y/ref=sr_1_1?ie=UTF8&s=toys-and-games&qid=1217375749&sr=1-1 . This is the toy that should be ruling the roost but they can't seem to keep a decent supply out there.
Kevin, whenever you have the option channel c has always lasted the longest and flew the best.
Tim
_____________________________
"...never stop flying the airplane..."
(in reply to ahaacobbler)
       Post #: 6726
RE: Air Hogs Aero Ace! - 7/30/2008 4:52:59 PM
micro_builder
Status: offline
to whom ever was interested, here's a .pdf of the parts for my glider. since i just free handed the fuselage, there's no plans for that, but all i used was a block of balsa and started carving with an xacto. the total leangth should be around 13-14 inches from tip to tail. the tail boom is 3mm OD CF rod. these are the 2nd version of the plans, with a new wing rib shape for a differant airfoil. there's no instructions, so nothings concrete, change whatever you want along the way...just start sticking wood together, it'll look like a plane eventually
i'm heading to washington on the 1st for a couple weeks, hopefully i can build the new wing before i leave. i already have the electronics coming in the mail (parkzone cessna gear), and i'll be ordering some durobatics foam for the outer skin. when i get back i'll get it all together and get it in the air, i'll start a new thread for it.
nick
Click to see the file in new window.Attachment.pdf
(in reply to FERNDALE AIR FORCE)
       Post #: 6727
RE: Air Hogs Aero Ace! - 7/30/2008 5:23:45 PM
trroadster
Status: offline
durobatics foam???
(in reply to micro_builder)
       Post #: 6728
RE: Air Hogs Aero Ace! - 7/30/2008 5:50:18 PM
micro_builder
Status: offline
yep, durobatics foam. its a specialty foam for us micro builders, a very good alternative for balsa. comes in .050" and .025" thicknesses, pleanty light and reasonably strong. not exactly cheap, but it works great:
http://www.durobatics.com/
http://www.bsdmicrorc.com/index.php?categoryID=58
a good thread with lots of durobatics made planes. a search for durobatics in the micro/indoor forum at RCG will give a handfull more results
http://www.rcgroups.com/forums/showthread.php?t=666072
all these are durobatics too from a member on RCG: http://picasaweb.google.com/robogeo
and below is a pic of how it stacks up against other materials (thanks to Gordon Johnson for the chart/info)
nick
edit:
added some pics of the work i got done on the new wing today with the new plans. turned out well enough i think.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by micro_builder -- 7/31/2008 1:49:10 AM >
(in reply to trroadster)
       Post #: 6729
RE: Air Hogs Aero Ace! - 8/1/2008 3:21:22 PM
RedTwilight
Status: offline
Thought I'd post a couple of pics of a flying wing that I made. The electronics were pirated from an AA AcroJet. The wing is made from 1/8" cellfoam 88. This plane is simply amazing. Flys around at only 1/4 throttle and is very, very manueverable. At 1/3 throttle it is twice as fast as a Standard Aero Ace bipe with the lower wings removed. I love flying it in ground effect just inches off the ground and taking it up high then full turn as it spirals (almost a flat spin) fast towards the ground. It is the best mod I have ever done to these little planes and gear.
Sorry if it's hard to see the pics. I'll try and get some close up shots soon.
Click for fullsize
Click for fullsize
< Message edited by RedTwilight -- 8/1/2008 3:23:02 PM >
Parkzone P-51, Hangar 9 P-51 PTS
'96 Mustang Cobra 330hp
       Post #: 6730
RE: Air Hogs Aero Ace! - 8/1/2008 4:47:32 PM
trroadster
Status: offline
Got a plan you can post?
(in reply to RedTwilight)
       Post #: 6731
RE: Air Hogs Aero Ace! - 8/1/2008 6:37:14 PM
RedTwilight
Status: offline
quote:
ORIGINAL: trroadster
It's based off the Z surfer wing. I'll see if I can find the link. The only plan is in word format right now. I'll see if I can switch over to a different format.
       Post #: 6732
RE: Air Hogs Aero Ace! - 8/1/2008 8:10:04 PM
RedTwilight
Status: offline
It did take me a couple of flights (crashes) to get the trim, balance, and thrust angles correct.
Found the plans here. I just printed it out on 8 1/2 X 11 paper with no scaling.
http://www.geocities.com/x_surfer2004/zsurfer1.html
http://geocities.com/x_surfer2004/
A link to the original thread that led me to the design!
http://www.rcgroups.com/forums/showthread.php?t=65870
       Post #: 6733
RE: Air Hogs Aero Ace! - 8/1/2008 11:46:45 PM
chris1379
Status: offline
I saw the AA Bipes at Target when I bought my Rolling Fury a few months ago. I also thought you guys might be interested in this RC Pterodactyl at TRU. I bet the birds would love it.
Chris
       Post #: 6734
RE: Air Hogs Aero Ace! - 8/2/2008 12:48:25 AM
FERNDALE AIR FORCE
Status: offline
Wow a peter ducktail in 2 channel that flies! And given that the stay at home mom couldn't get the wing to glue on, but made no mention of melting foam, it sounds like it might be made of epp.
Tim
(in reply to chris1379)
       Post #: 6735
RE: Air Hogs Aero Ace! - 8/2/2008 9:11:44 AM
