MBX5T Maniac
Joined: 12/21/2004 From: none, TX, USA Status: offline
turns out the filter actually isn't a filter. mine's just a shiny blue cylinder. the filter part is missing. ohh, and when i was priming the engine, there where some bubbles in the line after is sucked up some fuel. engrose, the engine is in good shape before i took it apart. it still has very good compression, so i know the engine has quite a bit of life in it. it seems that the new fuel tubing i got is too wide in interior diameter, and it wouldn't work with that fuel line. so i went back to the included tubing, and it can run, but if i let it idle for more than a few seconds, it stalls.
_____________________________
My toys: LST, Mini Inferno, XX-CR, GrassHopper, RC10, Rustler, MBX5T Prospec, Mugen MST-1
