YS110 regulator issues    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> YS110 regulator issues
Page: [1]
Login
YS110 regulator issues - 9/20/2005 6:04 PM
flynandfixnrick
Score: 100
Last Login: 2/10/2010
Status: offline
Hi Dave, This forum has been a very useful tool thanks to you. I have a newly broken in engine that appears to be problematic. The top end RPM and idle at or below 2000 RPM appears good. The transition between just above idle on up to almost full RPM is extremely rich to the point of erratic to dying. Turning in the regulator adjustment makes no effect. I have followed the YS performance recommended procedure too the tee several attempts. no help. I purchased this engine last year here in the USA.
Should I send it in to you? Thanks in advance...
Hide Signatures
       Post #: 1
RE: YS110 regulator issues - 9/20/2005 7:08 PM
Dave Shadel
Score: 100
Last Login: 4/16/2009
Status: offline
Send it. Reg is sticking.
Hide Signatures
(in reply to flynandfixnrick)
       Post #: 2
RE: YS110 regulator issues - 9/20/2005 7:31 PM
bubbagates
Score: 121
Last Login: 5/17/2013
Status: offline
Hi Dave,
I had the exact same problem and pulled the reg off and found it to be sticking. I worked it loose and replaced the gasket but now it allows allot of fuel to come out of the carb when not running. I do not mean a drip every so often but anywhere from a steady stream to a fast drip which all depends if I turn the prop up to compression or not. After getting the plunger to work freely my transition improved a great deal.
Should I also consider sending mine in or are there certain part numbers I need to know about replacing the plunger. I read somewhere in this forum that there is a plunger available that is a tad bit shorter that seems to work well. If there is do you have the part number? I can do the work myself.
_____________________________
Bill James
Hide Signatures
(in reply to Dave Shadel)
       Post #: 3
RE: YS110 regulator issues - 9/20/2005 8:51 PM
Dave Shadel
Score: 100
Status: offline
Call Richard at service-775-782-4562. He can send the necessary pieces.
Good Luck.
Hide Signatures
(in reply to bubbagates)
       Post #: 4
RE: YS110 regulator issues - 9/20/2005 9:24 PM
flynandfixnrick
Score: 100
Status: offline
OK Dave, Thanks for your rapid response. I'm taking it out of the plane now and plan to have it sent today.
Thank you very much!
Hide Signatures
       Post #: 5
RE: YS110 regulator issues - 9/20/2005 11:50 PM
Dave Shadel
Score: 100
Status: offline
We will get it fixed
Hide Signatures
       Post #: 6
RE: YS110 regulator issues - 10/7/2005 9:02 AM
flynandfixnrick
Score: 100
Status: offline
Hi Dave, I received my engine in the mail today. Thanks! It's back in the plane tonight with plans to fire it up tomorrow. I feel like a kid. The guys at the field can't believe this online support you have provided. I got a real chuckle out of the 100% discount on the receipt for services rendered. One of the club members has a new 110 still in the box 2 month old. Should I tell him to get in touch with you?
Thanks again for all your help.
Hide Signatures
       Post #: 7
RE: YS110 regulator issues - 10/7/2005 6:23 PM
Dave Shadel
Score: 100
Status: offline
Tell him to run it first.
Hide Signatures
       Post #: 8
RE: YS110 regulator issues - 10/8/2005 7:30 AM
flynandfixnrick
Score: 100
Status: offline
Hi Dave, My engine is running excellent thanks to you. If I have any other issues, I will definitely look to you and this RC forum. As for the other YS110 in the box that I mentioned, I will work with him on that.
P.S. Thanks a million for your expedient time and attention to YS engine owners in the world of Product Support. You have proven to be first rate, with this particular example, full circle, once again.
Sincerely Yours.
Hide Signatures
       Post #: 9
RE: YS110 regulator issues - 10/8/2005 6:00 PM
Dave Shadel
Score: 100
Status: offline
My pleasure, good flying!
Dave
Hide Signatures
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> YS110 regulator issues
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.437RCU1
