Score: 100 Joined: 3/11/2005 Last Login: 4/5/2008 From: , HI, USA Status: offline
quote:
ORIGINAL: stevenchao
Hi Everyone,
My name is Steven Chao (with AON Electric). I have not gotten my hands on the MLST as of yet, so now I need a couple drivers who has or will have the MLST to help with testing. Give me a shout on my email (schao@aonelectric.com).
Score: 100 Joined: 12/10/2005 Last Login: 11/6/2006 From: , AZ, USA Status: offline
I Just got mine yesterday. Great looking truck, and very nice design features. This is going to be the next small thing in RC, I'm sure there will be alot sold once the pics come out of actual use.
Score: 103 Joined: 6/29/2004 Last Login: 9/23/2009 From: Loomis,
CA, USA Status: offline
AON you wanna strat moving up in scale like 1/10 TC and ST? I'll be glad to test a few of those for you =)
_____________________________
Racing Cars: FT 18T with Mamba 8000kv system, XXX-S with 24T Birdman Pro Pro motor and Novak GTB, FT RC10T4 with Chamelion and GTB Sponsored by: Driven Pro Performance Devices BoomBoomBatteries
Score: 100 Joined: 9/18/2003 Last Login: 3/19/2010 From: Santa Fe Springs,
quote:
ORIGINAL: Doahh
AON you wanna strat moving up in scale like 1/10 TC and ST?...
It is not that we don't have AON motors for them (K2815-5800). We actually designed that brushless motor approx 2.5 years ago. Unfortunately, there isn't any reasonably priced ESC in the USA market for bashers. I believe it is not reasonable to ask users to pay $300 for a sensorless controller to mate with our 1/10 scale motor... I wouldn't pay for it:O I don't expect other either. It just doesn't make any economical sense.
Some lower priced 1/10 car controllers are coming out at the end of this year and at the beginning of next year.
Score: 100 Joined: 1/2/2004 Last Login: 2/23/2010 From: KLN, HONG KONG Status: offline
quote:
ORIGINAL: Doahh
Peace, Steven Chao AON Electric
Sky & Technology in Korea just released 3 models of the big sensorless controllers as additional models for QUARK brushless system. QUARK-65A ROADSTER QUARK-80B Competition QUARK-125B Monster Pro
Score: 100 Joined: 12/23/2002 Last Login: 3/19/2010 From: Lakeside,
The first Mini LST with a Mamba 6800Kv in it! Haven't ran it outside yet since its 3:30am right now, but I'll post updates as to how the Mamba 6800Kv holds up. I know everyone is dying to know.
< Message edited by Tigger N. Bennie -- 12/22/2005 6:46 AM >
Score: 100 Joined: 10/22/2002 Last Login: 5/30/2008 From: Renton,
WA, USA Status: offline
First Impressions:
Shock that my local HobbyTown actually had them in stock; they had several in different colors. ($199.99)
Very well made, yes sir it was an LST, just a wee bit smaller and kind of like an E-Maxx as far as the twin motors go.
All my R/C gear, batteries, chargers, motor connection, ESC have been converted to Deans Ultra plugs so I soldered one on for the battery connector and connected a freshly charged battery I have for my Mini-T. Next, batteries in the Transmitter Tx and application of the frequency/LED decoder sticker to the back of the Tx, check the trim centering.
Turned on the Tx, turned on the Receiver, the steering servos centered themselves. I gave the throttle a small amount of pressure and all four wheels spun. This is where I noticed a problem. The right rear tire had a severe wobble, almost like the wheel nut was loose, it wasn’t. I removed the wheel nut and looked at the wheel hub mount; the drive pin was not centered in the hub drive and was bent from the wheel being tightened with the pin not centered in the indent in the drive mount. This left the wheel at an angle which when run slowly wobbled like mad, at full speed it would have eventually broken something and handled poorly all the time. I am glad I did a slow wheel spin test prior to running. I straightened the pin and remounted the wheel.
The next real and quick test was steering throw. The steering from end to end is fast, real fast (with D/R at max). One thing I noticed was that when turning the Tx wheel all the way left or right it seemed that the servos were at their end point and using some of their servo savers range. I have to say the steering is excellent. I will very soon swap the Rx with a spare I have for my LST and use its computer controller to set the steering End Points so as not to tax the servos and also to provide other nice features/adjustments. If I did not have this option I would be very happy with the Tx supplied, it is synthesized (and so is the receiver Rx), no crystals.
I would have preferred to have Hex screw heads throughout, however the installed screws were all tight and flush where appropriate.
I looked at the parts diagram for the diffs and it did not seem that they were sealed like the big brother LST. I feel that the diffs are too loose, more slip than I would prefer, though they are smooth. It would be nice to have the option to switch to diff fluid of different grades. Again…this is a minor complaint from a guy on the internet who has run this truck for all of two hours.
This MLST is fast and powerful. I have a Mini-T and a Mini Quake. I love my Mini Quake around the house, but I was shocked at how much better in every possible way the MLST is over both. Responsive, quick, powerful, well built, nice electronics, yet easily upgradeable if desired. This puppy seems like a natural racer and will sling the dirt over its immediate competitors’.
Hmmm……
RPM A-Arms, Aluminum Diff covers, Lunsford Ti anything….
What the heck, the radio gear alone is such a value being synthesized you could justify a few hop ups.
BillA, RC ScrewZ will be releasing a stainless steel screw kit on Friday. I e-mailed Keith Bergevin (RC ScrewZ owner) asking about the possibility of an Mini LST screw kit, and he said they WILL be making a screw set. I already preordered mine. Will be shipped out on Monday. Can't wait to receive it.
Score: 100 Joined: 1/20/2005 Last Login: 10/17/2006 From: Brampton,
ON, CANADA Status: offline
quote:
ORIGINAL: SUNA
Great info in here!
Ya I agree! To bad its not Growing, Theres Too many New M-LST Threads Started everyday... I would like to find out What Works and what New Stuff is out for the M-LST, In One Spot...(But this is a Big form with aLot of Users) So it Don't seem to work that way..
Score: 100 Joined: 1/24/2006 Last Login: 2/15/2010 From: Guelph,
well i got a good story for you guys....
i go and pick up my mini lst get home pull it out of the box charge the battery once it was done i hooked it all up and tuned it on drove for about 5 miniuts and the rear diff stripped,
knowing this was a common problem i thought no worries, so i get the new pinnions and put then in.
so i charge the batt again only for an hour plug it is turn on the tx turn on the rx and drove for about 1 miniut and then it began the esc started glowing red really bright so i ran over to turn it off buy the time i had gotten there one of the servos was on fire too i was in my base ment now my whole house reaks like burning electrontics. . .
dom u guys think if i call losi tomorow they will do somethin cause now abviously i have a 200 dollar paper weight
< Message edited by STORMPULSE -- 2/18/2007 3:50 PM >
Score: 100 Joined: 1/18/2007 Last Login: 7/8/2009 From: adelaide, AUSTRALIA Status: offline
I thought I would do what a lot of other members fail to do: Post in an already existing thread rather than making another one and adding onto the hundreds of other threads all asking the same thing!!!... And revive this thread, seeing as though it hasn't been used since '07 and hopefully there will be less MLST threads!
So I just got a second hand MLST2 and it has the following: -Exotek single servo conversion chassis -Rear black wing -Vacuum black rims -Hitec steering servo -alloy body posts -buggy body -CV's all round -front and rear sway bars
BTW, dont try to persuade me to buy a different motor because the one I want is discontinued and all the others from the US are to expensive because of our dollar.
Cheers, NB.
RC''s: BL Mini B, Micro B, BL RC18T, CEN ME16MT and an LST2!!!
After some reading of horizons site http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLM1100 It looks as if everything including the motor overall diameter for the 400 is the same as the the 370. The only differenct being that the 400 is 10mm longer than the 370. But can anyone confirm if the mounting points are the same for both motors?
Score: 105 Joined: 7/17/2006 Last Login: 3/21/2010 From: Genoa,
IL, USA Status: offline
Sweet , probably has a ball diff and DD slipper also . I belive the 400 motor might fit , but all you would need is the 370 .
I have a Quark 33 Pro Car ESC and a Losi 9400Kv motor in mine and it pulls wheelies on command .
REVO , LST2 , Slash 4x4 , 8ight Te , SC10 4x4 Micro T , E-REVO , Ofna CORR Truck
looking for strong cvd, what would you advise, please? I have xray m18mt but want to use something different for it, so i thought i can use (with some modification) losi mini lst cvds + http://www.rcuniverse.com/forum/m_8964776/tm.htm
Thank you in advance
VEKAmodel ABEC35.com - Ceramic and Engine BEARINGS
