RE: Small Pitts
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: Small Pitts Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Small Pitts - 10/5/2005 5:24:40 AM
N925WB
Status: offline
OK.
I like to mix some milled glass fibers with my epoxy when using it in areas that require more strength. I have absolutely no proof that it turns out any stronger than just regular epoxy, but it sounds like a good idea!
-Wayne
_____________________________
Tricycles are for babies.
www.taildraggersinc.com
(in reply to Bipe Flyer)
       Post #: 51
RE: Small Pitts - 10/5/2005 5:55:28 AM
Bipe Flyer
Status: offline
I do that too. I'm sure that it makes a less brittle bond.
1/2A all the way!
Club Saito #151
(in reply to N925WB)
       Post #: 52
RE: Small Pitts - 10/5/2005 6:27:22 AM
Bipe Flyer
Status: offline
I'm dry fitting everything to see how things fit. I just put a set of commercial gear on to check the stance, but I may go with it rather than making the more traditional wider Pitts gear. I haven't decided yet. Here are a couple of pics with its big brother.
Click to see fullsize image.
Click for fullsize
Click for fullsize
1/2A all the way!
Club Saito #151
       Post #: 53
RE: Small Pitts - 10/6/2005 7:22:51 AM
Bipe Flyer
Status: offline
The cabane struts are secured to 2 spruce rails.
Click for fullsize
1/2A all the way!
Club Saito #151
       Post #: 54
RE: Small Pitts - 10/7/2005 4:03:26 PM
mainegold
Status: offline
Well Bipe, how's that little bipe coming? We haven't heard anything in a whole 24 hours!
Are you going to match the BullDog for colors or maybe something completely off the wall?
Your wings are not tapered, right? Can we (sometime, not right now) get a cross section drawing of the wing so we can 'build-up' the wings? I don't have a foam cutter.
Jack
       Post #: 55
RE: Small Pitts - 10/7/2005 9:21:52 PM
Bipe Flyer
Status: offline
I didn't get anything done yesterday other than check where the components will fit and take an inventory of servos.
See the first post in this thread for the colour scheme.
The wings are constand chord with an NACA 0015 airfoil. I've attached a cross section.
Click for fullsize
1/2A all the way!
Club Saito #151
(in reply to mainegold)
       Post #: 56
RE: Small Pitts - 10/7/2005 10:07:18 PM
dieFluggeister
Status: offline
Hey Bipe I love your cowl. Do you plan to epoxy the inside and then just 'kote the outside? How does a guy keep a balsa cowl from going to heck so quickly?
       Post #: 57
RE: Small Pitts - 10/7/2005 11:23:22 PM
Bipe Flyer
Status: offline
DF,
Yes I cover the cowl with Ultracote and then epoxy the inside for fuel proofing. Here are a couple of pics of the cowl for my .40 size Pitts before fuel proofing and covering. I fuel proofed it with polyester resin and it is still fine after almost 5 years. I will be using 24 hour cold cure on this one.
Click for fullsize
Click for fullsize
< Message edited by Bipe Flyer -- 10/11/2005 8:02:26 AM >
1/2A all the way!
Club Saito #151
(in reply to dieFluggeister)
       Post #: 58
RE: Small Pitts - 10/10/2005 10:35:22 PM
Bipe Flyer
Status: offline
I've been doing little things for the past few days. Plumbing the fuel tank, sanding the interplane struts, setting up the tailwheel etc.
I really like the Sullivan tailwheel bracket, but it's too large for this plane, so this is what I came up with.
Click for fullsize
1/2A all the way!
Club Saito #151
       Post #: 59
RE: Small Pitts - 10/10/2005 11:08:33 PM
Bipe Flyer
Status: offline
I made the brass piece on the tailwheel bracket too tall, so I trimmed it down a bit. Boy a lathe sure comes in handy. Even when it's a cheap one operated by someone who barely knows what he's doing.
Click for fullsize
1/2A all the way!
Club Saito #151
       Post #: 60
RE: Small Pitts - 10/12/2005 10:38:20 AM
mainegold
Status: offline
TTT
Hey Bipe, we haven't lost interest...just waiting to hear more about your build. I hope everything is working out for you.
Jack
       Post #: 61
RE: Small Pitts - 10/12/2005 11:40:57 AM
Bipe Flyer
Status: offline
I'm glad that you're findng it worth reading, Jack.
Well, I'm just calling it a night. Just a bunch of little things today. Sanding, polishing aluminum parts etc. I've given up on finding a paint that matches the Ultracote Light Grey, so I'm not going to make wheel pants and the aluminum parts will be polished instead of painted.
1/2A all the way!
Club Saito #151
       Post #: 62
RE: Small Pitts - 10/12/2005 2:03:31 PM
fliing1beaver
Status: offline
Hey Bipe, You're a great job !!! Nothing like the smaller biplanes. I looking for the smaller golden age bipes myself. Like the sportsman aviation waco 30. I cann't wait to see your bipe done. keep up the good work.
       Post #: 63
RE: Small Pitts - 10/13/2005 8:08:40 AM
futaba_pilot45
Status: offline
i love this plane.. looks at balsa box and desided that time to got to the LHS.. this plane seems awsume... i like the gear look on you bigger bipe tho... more scale... also in you pic i see you have the model-tech extra 300... dandy little plane 'specially with the controls maxed out.. and a mvvs .26 w/ pipe... lol ... anyway love the plane, will follow you till the end
- Lower! Lower! (SMACK) .... Hey i CAN fix it!
(in reply to fliing1beaver)
