William Robison
Joined: 11/10/2002 From: Mary Esther, Florida, FL, USA Status: offline
Brian: I've been told ethanol will work, but you'll find it harder to get a good grade, and it will be more expensive than methanol. Mixed with a Coke, ethanol makes a good drink. Use methanol the same way and you'll go blind. Problem is the ATF considers ethanol (grain alcohol) to be a regulated substance, and it's taxed highly. You can get a good grade of methanol at your local hardware store, for ethanol you go to the liquor store. Additionally, in many states and counties sales of pure grain aclohol is illegal. Bill.
_____________________________
Real Airplanes have Two Engines AMA 25139 - More than 40 years.
