Matt Merciez
VA, USA Status: offline
Ryan, I wrote up my own word document for the Sportsman sequence #2 since that is the sequence I like the most. No guarantees for the accuracy of the text, maybe someone with more experience can validate its accuracy or correct the errors. Sportsman Known with Right-to-Left Wind 1. Inverted figure 9 with a 1 ½ positive spin on entry, (pull on the loop) exit inverted. 2. Pull to a 45° downline with a 2 pt. roll on the 45° downline, exit upright. 3. Positive vertical upline with 2 of 4 pt. roll on the upline, push on exit. 4. Inverted, reverse shark’s tooth with 1 positive snap roll on the 45° downline, exit upright. 5. Vertical downline with a half roll on the downline, exit upright. 6. Hammerhead with a ¾ roll on the upline (roll to the right and stop with the canopy facing), 2 of 4 pt. roll on the downline (roll to the right), exit upright crossbox. 7. Humpty-Bump, 2 of 8 pt. roll on the downline (roll to the left to setup next figure), exit upright. 8. Half-Cuban-Eight with 2 of 4 on the 45° downline, exit upright. 9. Inside loop, full roll at apex. 10. Reverse teardrop. Half roll on the vertical upline, (pull for 5/8 loop) , 1 positive snap roll on the 45° downline, exit upright Sportsman Known with Left-to-Right Wind 1. Inverted figure 9 with a 1 ½ positive spin on entry, (pull on the loop) exit inverted. 2. Pull to a 45° downline with a 2 pt. roll on the 45° downline, exit upright. 3. Positive vertical upline with 2 of 4 pt. roll on the upline, push on exit. 4. Inverted, reverse shark’s tooth with 1 positive snap roll on the 45° downline, exit upright. 5. Vertical downline with a half roll on the downline, exit upright. 6. Hammerhead with a ¾ roll on the upline (roll to the left and stop with the canopy facing), 2 of 4 pt. roll on the downline (roll to the left), exit upright crossbox. 7. Humpty-Bump, 2 of 8 pt. roll on the downline (roll to the right to setup next figure), exit upright. 8. Half-Cuban-Eight with 2 of 4 on the 45° downline, exit upright. 9. Inside loop, full roll at apex. 10. Reverse teardrop. Half roll on the vertical upline, (pull for 5/8 loop) , 1 positive snap roll on the 45° downline, exit upright
_____________________________
Matt Merciez
