Desertrat
Joined: 11/6/2002 From: Boerne, TX, USA Status: offline
quote:
ORIGINAL: Diablo-RCU If IMAC participation is down, there are more than a few reasons why. Extraordinary gasoline prices last Summer made traveling to a contest very expensive. If you're hauling a trailer for a 40% plane or two, even more expensive. A tank of gas for a 40% plane costs about $2. It's about the same cost as flying something with a Moki 2.10. The trailering I'll buy into. $2 for a 40% tank of gas - thats an exaggeration. Even worse comparing $2.50-$3.00/gal pump gas to $10.00-$18.00/gal alcohol/nitro. C'mon man, when you exaggerate that bad you lose credibility. Now to your point: IMAC participation was not down. However, most people just went to one contest. I personally only made 3 last year, biggest reason I didnt make more is the time factor involved. It hurts to leave work on friday, hook up and drive all night, get up early to fly on Saturday, have a small amount of fun while sweating and studying unknowns sat night, fly a little on sunday, smile and clap then haul butt home so you can be dog dead tired at work monday morning, wondering how bad your wife is going to yell at you about not mowing the grass! And this is when it goes smooth. I know there are folks here who have gotten up to really bad weather on saturday after driving all night and asked yourself the question - "Is it really worth it?" Size matters. Nobody can truely argue that small airplanes are competetive. If you are serious about IMAC, you will have to get a big airplane eventually if you want to be competetive. Dick I agree with everything you say, but the reality is the general majority of the membership really does not want to change the format. And I understand to a degree because IMAC was founded on that principle that there would be no restrictions on the aircraft size. As long as folks continue to show up to enough contests, there will be no format change. Here in South Central, the trend has been more and bigger contests. The good news is Pattern offers a format with size restrictions - Interestingly, the cost is very similar when you get to the upper more competetive classes - hmm. Roger
