Landing gear size
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Landing gear size
Page: [1]
Login
Landing gear size - 1/12/2002 12:07 AM
AV8TOR
Score: 100
Last Login: 7/26/2008
Status: offline
Without being to thick and end up heavy, how thin of aluminum can be used for a 9 pound plane? I have seen some 3/16" but that just seems to stiff.
Hide Signatures
       Post #: 1
Aluminum L.G. - 1/12/2002 4:27 AM
Ed Smith
Score: 100
Last Login: 11/26/2009
Status: offline
To some extent the thickness would depend on how long the legs are.
Generally, for a nine pound airplane 1/8 aluminium would be adequate. The grade of aluminium should be 6061-T6. This spec gives a material that has a certain hardness and therefore springback. Any softer material than this is not suitable.
Ed S
Hide Signatures
(in reply to AV8TOR)
       Post #: 2
Re: Aluminum L.G. - 1/12/2002 4:49 AM
AV8TOR
Score: 100
Status: offline
[QUOTE]Originally posted by Ed Smith
Ed S
[/QUOTE]
Thanks Ed, From the axle center to the top flat of the gear is 4.5", 7.5" across the top flat, and 16.250" wide at the axles.
Ray
Hide Signatures
       Post #: 3
Landing Gear - 1/12/2002 5:56 PM
Ed Smith
Score: 100
Status: offline
Ray,
!/8 thick aluminium will be suitable for a LG the size you indicated. I have a LG slightly smaller than yours. It was used on a model that weighed just over nine pounds. It is solid.
Ed S
Hide Signatures
       Post #: 4
Landing gear size - 1/13/2002 4:14 AM
AV8TOR
Score: 100
Status: offline
Thanks Ed, I was hoping it would . I will give it a go.
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
