RE: Midwest Extra 300xs Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Beginners >> RE: Midwest Extra 300xs Build
Page: <<   < prev  10 11 12 13 [14] 15 16 17 18 19   next >   >>
Login
RE: Midwest Extra 300xs Build - 11/13/2006 5:46 AM
jlezana
Score: 100
Last Login: 5/14/2007
Status: offline
Hi Digger44, Today I flew the airplane he is very stable and it maneuvers well, I did not want to demand much the model until this installed yet to correct tendencies, but in torque roll is very quiet, to approximately 1/2 gas, I must increase some controls for better answer, but already I have time.
Greetings
Jorge Lezana
Valdivia
Chile
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Digger44)
       Post #: 326
RE: Midwest Extra 300xs Build - 11/13/2006 11:15 PM
jlezana
Score: 100
Status: offline
More Pictures
Bye
J.L
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jlezana)
       Post #: 327
RE: Midwest Extra 300xs Build - 11/14/2006 1:20 AM
Digger44
Score: 105
Last Login: 9/23/2012
Status: offline
Very nice J.L
_____________________________
"For those that believe, no explanation is necessary; for those that don't, none will suffice"
Hide Signatures
       Post #: 328
RE: Midwest Extra 300xs Build - 11/14/2006 6:56 AM
-EXTRA-
Score: 100
Last Login: 12/3/2009
Status: offline
Nice lookin plane
Hide Signatures
       Post #: 329
RE: Midwest Extra 300xs Build - 11/14/2006 7:13 AM
Cyberwolf
Score: 655
Last Login: 5/21/2013
Status: offline
Very nice plane and they fly good as well.
If you can''t fix it with a hammer, you''ve got an electrical problem.
Hide Signatures
(in reply to -EXTRA-)
       Post #: 330
RE: Midwest Extra 300xs Build - 11/14/2006 2:28 PM
EL TEMUCANO
Score: 100
Last Login: 1/18/2012
Status: offline
J L ,
VERY NICE PLANE, CONGRATULATIONS,
BIEN H.... PRESIDENTE DE LOS R. Q. TE QUEDO MUY BONITO, PERO SERÍA INTERESANTE QUE NOS CONTARAS DE LAS CONDICIONES DE VUELO, YA QUE EL DOMINGO, FUE UN DÍA DE MUCHO VIENTO, "TIO PEPE" PARTICIPO?, LO VOLO F3A CUENTA MÁS AUNQUE SEA EN CASTELLANO.
SERGIO
I said to my fingers, ! YOU CRASH MY MODEL !
Hide Signatures
(in reply to Cyberwolf)
       Post #: 331
RE: Midwest Extra 300xs Build - 11/14/2006 2:35 PM
jlezana
Score: 100
Status: offline
JAJA si Tio pepe fue pero no lo quiso volar, me dejo todo el peso a mi, solo me carburo el motor y para arriba jajaj
el vuelo del avión es muy pero muy estable con decirte que trate de hacer un spin y nunca logre hacer que entrara en el, tuve que ponerle timón, vuela muy suave y es muy estable, pero no logre hacer vuelo de cuchillo tendré que ver los recorridos del timón y ponerle su capota al motor ya que eso según pepe me cambiaba todo el sistema de vuelo, la inclinación del motor quedo perfecta y su CG igual, torque roll a 1/2 Gas sin problemas, cuando lo tenga con todo comenzare con los ajustes de vuelo final y mezclas.
Tratare de publicar un video en algun sitio del Primer Vuelo para que veas de que hablamos.
Saludos
Jorge Lezana
Valdivia
Chile
Hide Signatures
(in reply to EL TEMUCANO)
       Post #: 332
RE: Midwest Extra 300xs Build - 11/14/2006 3:17 PM
EL TEMUCANO
Score: 100
Status: offline
ok
cuentame cuando publiques el video, espero nos veamos el sabado, por o menos el clima estará bueno
Sergio
Hide Signatures
       Post #: 333
RE: Midwest Extra 300xs Build - 11/14/2006 4:21 PM
jlezana
Score: 100
Status: offline
Video the First Fly
http://www.****/gallery/showphoto.php?photo=16931&cat=504
Atte.
Jorge Lezana
Valdivia
Chile
Hide Signatures
       Post #: 334
RE: Midwest Extra 300xs Build - 11/14/2006 7:26 PM
Digger44
Score: 105
Status: offline
Ok guys, Lets keep it friendly,!!!!
Hide Signatures
       Post #: 335
RE: Midwest Extra 300xs Build - 11/14/2006 8:42 PM
jlezana
Score: 100
Status: offline
Digger44
I have left the video in ****s so that you see it.
Greetings
Jorge Lezana.
Hide Signatures
       Post #: 336
RE: Midwest Extra 300xs Build - 11/15/2006 2:59 AM
Digger44
Score: 105
Status: offline
Very nice, looks like it fly's well. Did you fix the exhaust header. Looks like it almost became lost. Will start covering mine very soon.
Hide Signatures
       Post #: 337
RE: Midwest Extra 300xs Build - 11/15/2006 2:24 PM
jlezana
Score: 100
Status: offline
Digger44
Thanks, the airplane flies exelent, this week will begin to paint the cover of the motor and the skids. It will leave photos of the advance ahead but. Greetings.
< Message edited by jlezana -- 11/15/2006 2:25 PM >
Hide Signatures
       Post #: 338
RE: Midwest Extra 300xs Build - 11/20/2006 11:39 PM
jlezana
Score: 100
Status: offline
Pictures, movies and test
http://www.aeromodelistasdechile.cl/construcciones/extra300/index.htm
Greetings
Jorge Lezana.
Hide Signatures
       Post #: 339
RE: Midwest Extra 300xs Build - 11/29/2006 3:46 AM
Digger44
Score: 105
Status: offline
Took long enough but I finally got started on the covering today. Started with one of the elevators. Using Stix-it to apply the koverall went pretty well but the guys that said the Stix-it would gum up the iron were correct. The covering went on pretty smooth and the shrinkage is very good. Look out with the heat, it shrinks very quickly and could possibly warp or crush a delicate frame. I plan to spray two coats of Sig Nitrate clear over the covering and then one or two coats of butrate primer then the colors, sanding between of course. I am also taking weight measurements before each phase, ie; Koverall, nitrate, butrate, etc, on each piece. This will give me a good idea of the total weight penalty when completed and possibly application penalties. Might be interesting data. Don't have any pics yet but will post some in the next couple of days. I hope to have the plane covered and Nitrate coats on by the week before Christmas as I have vacation then and hope to be ready to do some colors during my vacation. One thing right now I need to figure out is what can I use to clean the iron. Plan to try generic thinner with the iron warm.
Hide Signatures
       Post #: 340
RE: Midwest Extra 300xs Build - 11/29/2006 3:55 PM
dmcmike
Score: 100
Last Login: 2/23/2013
Status: offline
The best thing to use to clean the iron that i've found.... go to the local paint store and get a pint of MEK. Works great!
Hide Signatures
       Post #: 341
RE: Midwest Extra 300xs Build - 11/30/2006 12:01 AM
Digger44
Score: 105
Status: offline
Thanks Mike, I'll give it a try. Tried fignernail polish remover and it worked pretty good but not great.
Hide Signatures
(in reply to dmcmike)
       Post #: 342
RE: Midwest Extra 300xs Build - 12/2/2006 4:41 AM
Digger44
Score: 105
Status: offline
Got a case of the fuzzies on the edges but overall these went well. Koverall is very easy to work with, corners perfectly with little effort, seams are easy as well, so far. Hope to get the ailerons and the wing done this weekend if the weather is not too good to fly.
Click for fullsize
Hide Signatures
       Post #: 343
RE: Midwest Extra 300xs Build - 12/2/2006 6:57 AM
Cyberwolf
Score: 655
Status: offline
Its looking good digger ,can't wait to see the finished item.
Hide Signatures
       Post #: 344
RE: Midwest Extra 300xs Build - 12/31/2006 3:08 PM
Digger44
Score: 105
Status: offline
Well, I havn't done any covering over the vacation, weather has been great and I just couldn't pass it up. I have flown quite a bit in the last two weeks and now have to go back to "WORK" on Tuesday.. Man that just wasn't enough time. I need another vacation. Another sidetrack was the new BME extra!!! Some kind of weird sickness I have, can't stop buying airplanes?? Bought the motor (DA_50) and some of the other gear. Just couldn't resist starting on this plane as well. My god I need to finish these planes. I suspect that the weather will not be this good for long so I will have some shop time soon.
Happy New Year all!!!!
Bob
Hide Signatures
       Post #: 345
RE: Midwest Extra 300xs Build - 1/4/2007 7:04 PM
mrbassman
Score: 100
Last Login: 11/23/2011
Status: offline
Hi Digger....been following your build thread and I was just wondering how your balance came out? I just purchased the 300 already built, (just drop in my receiver and fly), But I had a very tough time getting it to balance. It was tail heavy. I moved everything as far front as possible and even moved the engine forward. I had to put the fuel tank way in front of the c/g to get it to balance. I have the older kit with the solid horizontal stab and elevators. The engine up front is a BME 44. Getting this thing to balance has been a real challenge. If you or anyone else has some input it would be greatly appreciated. It is a great flying plane. Thanks, Ken
Hide Signatures
       Post #: 346
RE: Midwest Extra 300xs Build - 1/5/2007 4:21 AM
Digger44
Score: 105
Status: offline
quote:
ORIGINAL: mrbassman
Hi mrbassman,
What I found out is that the weight of the Brison on the front made my plane nose heavy. I balance in the bones before starting the covering and all came out well but had to move the batteries back almost into the turtledeck. I won't know for sure until after the covering is done. Do you have a pull-pull on the rudder or are the servo's at the rear? The ignition battery can be moved forward on to the engine box as well if it's not already? Possibly the spinner and prop can add depending on type and size. Any pics of the setup? If I can't see or think of anything else for you to do I am sure there are others who will chime in? Pictures would be great.
Hide Signatures
(in reply to mrbassman)
       Post #: 347
RE: Midwest Extra 300xs Build - 2/7/2007 10:20 AM
KI8FR
Score: 100
Last Login: 11/22/2011
Status: offline
Digger
Did you get this plane done..? I just pick up a midwest extr 300 at a swop.. I am going to put a 3w 42i on it.. Im having a hard time with geting info on it..
I was hoping you can give me some info.. I have been looking at this post for some time now but the info I need it not there.. or I just did not see it. lol there is a lot to read here..
The one thing I need to know is were is the CG at on this plane? That would be a good place to start..
Paul
Hide Signatures
       Post #: 348
RE: Midwest Extra 300xs Build - 2/7/2007 2:33 PM
Digger44
Score: 105
Status: offline
tellspin_37
Unfortunately I have not finished the plane yet, still in the covering stage. I got detoured by another plane build but plan to get back on it after the BME is finished. The book calls for 5- 7/8" CG back from the leading edge balanced at this point (not slightly to the nose). Let me know if I can help with any other info.
Bob
Hide Signatures
(in reply to KI8FR)
       Post #: 349
RE: Midwest Extra 300xs Build - 5/6/2007 1:07 AM
bar98
Score: 100
Last Login: 1/18/2009
Status: offline
I am also trying to get the CG as per the manual 5- 7/8" back from the leading edge. I have a DA-50 on the nose and the ignition battery in the engine box and the plane is tail heavy, I tried to add weight on the nose but is too much. I am removing the elevator servos and playing with the CG but is very hard, also I moved the receiver battery forward but has to be as minimum 8" from the ignition module. I will post the results.
Hide Signatures
       Post #: 350
Jump to:
Google
SITE MAP!   : :   FORUM RULES
6.297RCU1
