Cyberwolf
ID, USA Status: offline
If the antenna is ok, I would disconnect each servo one at a time and recheck, Also your servo extensions can cause a person grief at times, Thats another thing to check. If that doesn't show up anything then I would change the receiver and try it. Glitches can be a real bear to find but we both know its better to take home a plane that glitches than one in a sack. If you can do as Ken said and show us your set up. I had some problems also, But mine was only while running. I had the batterys to close to each other. also the charge leads needs to be seperated for each switch, Ign& receiver.
< Message edited by Cyberwolf -- 5/6/2007 7:15:15 AM >
_____________________________
I've learned that you cannot compare yourself to others -they are more screwed up than you think.
