Digger44
GA, USA Status: offline
Cyberwolf, The covering is sharp, nice job. That G-62 will pull it right. I'll be at 3.2 lbs for the Brison without the muffler. I hope to weigh in less than 16 lbs. as well. I guess that depends on the build now. My canopy was crushed a little in shipment as well. I havn't called MW yet and have been meaning to do so. Glad to hear you didn't have any trouble. I am just about at the engine mounting prep and don't know for sure if I will need standoffs or not. I need to do some measuring when I get there and hopefully I will have the cowl by then. Keep posting your build updates if you will, especially when you start setting up the motor, fuel tank,lines, and radio gear. These are the areas I will be for sure scratching my head a little.
_____________________________
"For those that believe, no explanation is necessary; for those that don't, none will suffice"
