RE: ** WALKERA DRAGONFLY 36 *
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Dragonfly 36
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: ** WALKERA DRAGONFLY 36 *
    Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
    [Poll]
    THE WORST HELI IN THE UNIVERSE
      7% (22)
    VERY VERY VERY BAD
      4% (13)
    DOING MY HEAD IN
      7% (20)
    ACCEPTABLE
      12% (36)
    OK
      9% (28)
    OK
      5% (15)
    GOOD COULD BE BETTER
      23% (65)
    GREAT HELI
      17% (50)
    ABSOLUTLEY LOVE THIS HELI
      8% (25)
    THE BEST HELI IN THE UNIVERSE
      2% (7)
    Total Votes : 281
    (last vote on : 9/29/2008 2:19:50 AM)
    (Poll will run till: -- )
    Login
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 9:15:03 AM
    ronikki16
    Status: offline
    Hi I just recieved my Brushless motor and ESC ,on the forum they say to connect the ESC to the Batt and pu the reciver wire to #3, but do I have to removed any of the other wires on the reciver ie.#4 ,#6 or just leave them all plugged in??? Will the ESC do the rest..I moved my motor away from my pinion to set it up...Please let me know...
    (in reply to edzinator)
           Post #: 251
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 10:06:14 AM
    DDrogon
    Status: offline
    your brushless set up is all you need .....plug the battery and where it goes and plug the other wire from your brushless speed control into channel 3 and forget all other wires ...just plug in everything else where it goes ....get all vibration out of your heli ...all.
    Xcell123 see my post for that tip ...see my profile ...new stuff on 36
    (in reply to ronikki16)
           Post #: 252
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 10:32:54 AM
    ronikki16
    Status: offline
    Yeah so I pluged the Motor and ESC ,it comes on and the motor goes "da na da na" then its as if it wants to do something but nothing happens. I can move the props around but the motor wont turn and I cant move the main props left and right..Should I take off the gyro? Is that messing it up???Thanks
    (in reply to DDrogon)
           Post #: 253
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 1:24:20 PM
    thecheatscalc
    Status: offline
    OK I have the same ESC I think, let's begin, my esc beeps twice, once saying "power on" which is the first time. Then it beeps again saying "got signal PUNCH IT" if it doens't have signal it won't go, this sounds like the problem. I'll say that the plug is in the wrong spot, I used number four, so it should go right next to the tail servo plug in the Rx. PLEASE don't put the gyro on the motor, that's a mistake I made as both of the wires going to the two look the same. ALSO a common problem is having the plug in backwards, so flip it around and re-plug.
    PS: the power wires should be in parallel (patched directly into) the wires that go into the battery female connector.
    _____________________________
    www.ushobbysupply.com - your #4 HQ!
    All stock located in the U-S of A!
           Post #: 254
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 5:38:21 PM
    Mikey-Flies
    Status: offline
    To sum up ...
    N.A setup
    1 - aileron
    2 - elevator
    3 - throttle
    4 - tail/rudder
    5 - unused /gyro settings
    6 - collective
    Battery -> two wire side of esc
    Three wire side of esc -> Motor
    servo connection from esc -> ch# 3 on the receiver
    The existing battery plug and motor connection from the receiver and be taped to the receiver as they will no longer be used. All the other servo's are left as is. This is assuming you are using the walkera receiver. If not, there won't be extra plugs
    If by moving the main props left and right you mean the aileron/elevator functions are not working then you may not have the servo plug connected right ways around to the receiver as thecheatscalc suggested. Check the wire colors against the existing servo connections to the receiver to ensure the proper orientation. Signal = yellow/white, + power = red/orange, ground = black/brown generally. If this doesn't fix the problem, proceed to the next item.
    If the motor won't spin up at all there is a good chance the esc is not seeing 0 throttle. You made need to adjust the throttle trim downwards to enable it to spin up. If that doesn't help you could also try reversing the throttle channel (after securing the heli and being ready to unplug the battery if things go awry).
    (in reply to thecheatscalc)
           Post #: 255
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 5:52:01 PM
    GTX SlotCar
    Status: offline
    I just received my Align 420LF and 25A ESC w/governor mode. There are no battery connectors with it.
    How has everyone else connected it to the battery?
    Gary
    SuperSkids® www.super-skids.com
           Post #: 256
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 6:12:43 PM
    E_Heli
    Status: offline
    I use Deans plug.
    Click to see fullsize image.
    Click for fullsize
    (in reply to GTX SlotCar)
           Post #: 257
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 6:21:11 PM
    GTX SlotCar
    Status: offline
    quote:
    ORIGINAL: E_Heli
    I use Deans plug.
    I guess I should have ordered something when I ordered this stuff. I thought I'd have everything I needed.
    I suppose I can cut the one off the receiver and just replace it later.
    Are the Deans plug available everywhere? I'm assuming you put one on your ESC, one on the battery and one on the charger, right?
    < Message edited by GTX SlotCar -- 11/2/2005 6:22:20 PM >
    Gary
    (in reply to E_Heli)
           Post #: 258
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 6:47:16 PM
    E_Heli
    Status: offline
    I bought mine at Aeromicro, you can find it at most hobby and on line stores that carry electric stuffs.
    http://www.aeromicro.com/Catalog/deans_female_ultra_plug_bulk_pack_1719687.htm
           Post #: 259
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 7:50:06 PM
    ewr101
    Status: offline
    got a walkera brushless motor for my 36 but it is the medium size and just barely fits. the short one is 10mm less in length. i got the longer one to fit but it is very tight. will this be a problem? will it make the frame weaker or stonger in a crash? it is still a 380 brushless just longer , will performance be any different? any and all opinions are appreciated.
    also had a bad experience with hobby e-store. they are in the U.S.A. but still order their parts from asia.
    Helicopters on the ground and revos on thier lid suck!
           Post #: 260
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 8:28:25 PM
    ronikki16
    Status: offline
    Ok I'll try that ,but you said plug it into #4 on the RX there is something already pluged in there should I remove whats in #4 and plug the ESC in #4??? And what do you mean dont put the Gyro on the Motor??? THanks
           Post #: 261
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 8:32:47 PM
    Mikey-Flies
    Status: offline
    Do not put the main motor into #4. That is the rudder channel. #3 is the throttle.
           Post #: 262
    RE: ** WALKERA DRAGONFLY 36 * - 11/2/2005 9:27:21 PM
    sparkling_fist
    Status: offline
    the thing in 4 is ur servo or gyro...
    u plug ur motor to ur esc and the esc into 3
    Barbarian for life.
    Stuff happens then you die.
    (in reply to Mikey-Flies)
           Post #: 263
    RE: ** WALKERA DRAGONFLY 36 * - 11/3/2005 1:00:40 AM
    GTX SlotCar
