GTX SlotCar
ME, USA Status: offline
I'm still having power problems. When I got my 36 it had the stock motor and battery and wouldn't lift off. Gear mesh was good but I took a little tension off the tail belt. It didn't help. I bought one of the blue $29.95 2200Mah LiPo battery/charger combos. With that, I could hop quite high, but the battery didn't last long and I couldn't really hover, just hop several times. Now I've got the Align 420LF and 25A ESC. It will fly, but only for a couple minutes (and that's being generous). At full throttle, the rotors actually seem to slow down even if I take the pitch out of the blades. After my initial 2 minutes I can hover a bit in ground effects (a foot or so off the ground), but the heli goes up and down. I can actually hear the motor going fast then slow then fast then slow (you know BBRRRbbrrrrBBRRRbbrrr). It also seems to squeak while it's doing this. After that, it goes back to the hopping I had before. I can hop it high or low, but it doen't have power to hover. After a hop, I turn my throttle down to zero for a couple seconds and I can hop again. I can do this several times until I eventually get bored. At first I thought the up and down motion might be caused the the up/down play in the main gear, but now I don't think so. It seems more like the battery is just loosing power. I charge it until the green LED comes on and the voltage is up there. Others have this battery and it works for them. Could it be a thing of chance, though? Has anyone else had one that didn't work well? Maybe I should set the ESC battery discharge protection to 60% (high discharge rate) and see what happens. Maybe I should just get a good 16C battery, but I'm not even sure what that means. I'd appreciate any help or comments.
_____________________________
Gary SuperSkids® www.super-skids.com
