thecheatscalc
GA, USA Status: offline
1. the motor is not engaged with the gear, move it back on (1mm clearance) and tighen, don't use locktite 2. the motor has broken teeth on gear and it is disengaged, buy new gear and replace 3. pinnion is slipping on motor, use locktite on it to fix 4. oneway bearing has failed, it is now slipping, replace that should fix it, oh and make sure to take a look at the bottom link in my sig to tune this machine.
_____________________________
www.ushobbysupply.com - your #4 HQ! All stock located in the U-S of A!
