RE: ** WALKERA DRAGONFLY 36 *
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Dragonfly 36
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: ** WALKERA DRAGONFLY 36 *
    Page: <<   < prev  13 14 15 16 [17] 18 19 20 21 22   next >   >>
    [Poll]
    THE WORST HELI IN THE UNIVERSE
      7% (22)
    VERY VERY VERY BAD
      4% (13)
    DOING MY HEAD IN
      7% (20)
    ACCEPTABLE
      12% (36)
    OK
      9% (28)
    OK
      5% (15)
    GOOD COULD BE BETTER
      23% (65)
    GREAT HELI
      17% (50)
    ABSOLUTLEY LOVE THIS HELI
      8% (25)
    THE BEST HELI IN THE UNIVERSE
      2% (7)
    Total Votes : 281
    (last vote on : 9/29/2008 2:19:50 AM)
    (Poll will run till: -- )
    Login
    RE: ** WALKERA DRAGONFLY 36 * - 12/7/2005 1:51:02 AM
    jaywatts
    Status: offline
    can anyone tell me what the three wires on the li-po battery are for? And if only two wires need to be connected to an align cell balancing charger? Thank you, Jay!
    (in reply to sdub5045)
           Post #: 401
    RE: ** WALKERA DRAGONFLY 36 * - 12/7/2005 2:02:28 AM
    buzzpop
    Status: offline
    If you have a battery that can be connected to the Align balance charger it needs to have the small additional connector on the battery for balance charging. (seperate to the main leads) Its usually 3-4 pins. It can do series charging too but I think it needs an adaptor.
    (in reply to jaywatts)
           Post #: 402
    RE: ** WALKERA DRAGONFLY 36 * - 12/7/2005 2:09:00 AM
    jaywatts
    Status: offline
    The battery i have is the walkera li-po 1500mah battery, it has 3 wires coming out of it. A black, white and a red. i was wondering if all these should connect to the charger or whether just the black and red? The 11.1V charging adaptor it came with has only one black and one red. Do i just connect these two to the black and red on the battery?
    (in reply to buzzpop)
           Post #: 403
    RE: ** WALKERA DRAGONFLY 36 * - 12/7/2005 2:26:31 AM
    buzzpop
    Status: offline
    Yup, that's the way to do it.
           Post #: 404
    RE: ** WALKERA DRAGONFLY 36 * - 12/7/2005 2:39:06 AM
    jaywatts
    Status: offline
    Sorry, What you say thats the way to do it, do you mean to just connect the black and red?. Do you know what the white is for?.
           Post #: 405
    RE: ** WALKERA DRAGONFLY 36 * - 12/7/2005 5:41:41 AM
    buzzpop
    Status: offline
    Actually, I read this on another post. Seems if you got the Walkera one its non-standard:::
    If you got a BRUSHLESS model or got the 1500 mAh LI-Poly - ****DO NOT CHARGE YOUR LI-POLY with the charger from WALKERA under any circumstances - You will need to get a dedicated LI-POLY charger and change the power connectors again. I repeat - DO NOT CHARGE YOUR LI_POLY with the CHARGER SHIPPED WITH YOUR HELI - Walkera are now aware of the problem and are addressing it. THEY DO NOT DO THIS ON PURPOSE - Its a misunderstanding they had.
    The Batteries unusually have 3 leads coming from them - 1 Red - 1 White - 1 - black.
    Red and black supply power out while running the Heli - HOWEVER ON CHARGING the BLACK wire IS - NEGATIVE and the WHITE wire is + POSITIVE IN to the battery from the charger. We have tested these thoroughly and that's how it is, We have had no problem with them charging with the CORRECT - LI-POLY charger and they are very good reliable batteries.
           Post #: 406
    RE: ** WALKERA DRAGONFLY 36 * - 12/7/2005 8:15:23 AM
    Pubhi
    Status: offline
    quote:
    ORIGINAL: buzzpop
    I can attest to that. I have been using two of the walkera/ebay lipos on my T-rex and they have both worked wonderfully. Unfortunately, I damaged one of them and have had to turn it into a 2s pack but now I can use that for other things.
           Post #: 407
    RE: ** WALKERA DRAGONFLY 36 * - 12/7/2005 5:18:25 PM
    edzinator
    Status: offline
    OK guy's and gall's, this just in from Walkera! Open my gallery to find english instructions for the walkera gyro. Yes I said english. Well as close to english as it gets. I'll post a photo in the forum as well.
    edz
    (in reply to thecheatscalc)
           Post #: 408
    RE: ** WALKERA DRAGONFLY 36 * - 12/7/2005 5:19:30 PM
    edzinator
    Status: offline
    this looks like good data...
    Click to see fullsize image.
    Click for fullsize
    (in reply to edzinator)
           Post #: 409
    RE: ** WALKERA DRAGONFLY 36 * - 12/8/2005 3:41:20 AM
    ewr101
    Status: offline
    quote:
    ORIGINAL: thecheatscalc
    these are 3x3mm METRIC screw, I know, I replaced one once, but found the propper one again, good luck on finding a set screw that small, I couldn't find one at ace hardware, but maybe you'll be lucky, I had to use a headed screw (it was on the flybar, luckily)
    i searched everywhere i could think of with no luck.i didn't want to pay $5 bucks for a 20 cent screw but i buckled and went to the lhs and du-bro has 4 of these screws for only $1.30 . what a bargain. anyway just wanted to pass that on and maybe save someone else some time. peace.
    _____________________________
    Helicopters on the ground and revos on thier lid suck!
           Post #: 410
    RE: ** WALKERA DRAGONFLY 36 * - 12/8/2005 3:42:38 AM
    ewr101
    Status: offline
    hope that helps. peace.
    (in reply to ewr101)
           Post #: 411
    RE: ** WALKERA DRAGONFLY 36 * - 12/8/2005 10:23:48 AM
    mmffdvrr
    Status: offline
    i bought my 36 about a month ago. it came with the 1100 mah batt, walkera 3200 brushless motor w/18a speed controller. i also have had a good experience with my bird. no rx/tx problems, honestly i was impressed( i have a dragonfly 4 and wow what i difference between the two. i have also crashed my heli although nothing too major. i am currently waiting on an all aluminum rotorhead to install. let you know haw it does. what i need to know is if any of the zoom/shogun alum tail pieces will work on a 36?
    also it seems to me that who you bought your heli from makes a big impact on whether or not you like/dislike the 36 all in all i think it is a good heli for the money!!!!
    (in reply to NOZZARCHELI)
           Post #: 412
    RE: ** WALKERA DRAGONFLY 36 * - 12/8/2005 12:31:12 PM
    borisboy
    Status: offline
    HI ALL
    Can anyone tell me if any of the JR PROPO tx and rx are good to use or not.Asi have seen some on ebay for sale.Also can i use them with my 36 or not,also the ones I have seen are 72mhz can i change this to my 36 frequency or not as i am still abit new to some of this.
    cheers guys
    (in reply to mmffdvrr)
