Heli_Flight -> RE: ** WALKERA DRAGONFLY 36 * (10/23/2006 10:17:16 PM)
I have the 180L Brushless, 30A ESC from Walkera on my 36 Heli. Before I upgraded to the metal rotor, everything was fine. When I was trimming the rotorblade pitch I then disconnected the motor form the ESC and had the stick and trim at half throttle. After the adjustments awhile later, I turn off the electronics and I pluged the motor back in, turned the TX on with throttle and trim down, then I plug in the battery. Now I hear all the sounds and actions of the heli like I usually do. Everything recaliberates and the motor even makes it's usual beep and small movement. As I go to power up the heli, bringing the trim up first to make that really soft start nothing happens where it would usually begin to turn. Then I increase the throttle stick and still nothing. Ok, no problem I think. I switch the wires on the motor to the esc. Nothing still. I try every wire variable, still no motor motion. What could it be? Regards, Heli_Flight
