GTX SlotCar
ME, USA Status: offline
quote:
ORIGINAL: thecheatscalc ....before you dump the stock though make sure the belt tension isn't too high. ... OK, I've read some previous posts and figured out how to loosen the belt tension. It was as tight as a drum and if I tried to spin the main rotor (power off) it would just stop when I let go of it. Now that it's looser, the rotor will continue to spin for 2 or 3 revolutions. I don't know how loose or tight it should be, though. I don't want it so loose that I end up with other problems. It would be helpful if someone would give their rotor a spin and let me know how many revolutions or how freely it spins, so I could have some kind of a guide to go by. The battery wasn't fully charged, but I still couldn't get it off the ground. The ESC and motor are cool, but the battery gets hot. I've tried playing with the pitch, zero at full throttle and then start increasing it, but it just won't leave the ground. Nothing is shaking and the blades and flybar seem to be tracking perfectly. I'll fully charge the battery tomorrow morning and give it another try. In the meantime, someone, please spin your rotor and let me know how freely it spins. The Align 420LF and ESC seems to be the way to go, especially since the Walkera doesn't have a working soft start, but I'd like to get this thing off the ground with the stock motor. At the very least, it would mean I'm not covering up a problem just by throwing more power at it. To end things on a positive note, I held my #4 in a good hover for around 20 seconds at my office today, and didn't get into trouble.
_____________________________
Gary SuperSkids® www.super-skids.com
