inline2542 -> RE: ** WALKERA DRAGONFLY 36 * (10/25/2005 5:07:25 AM)
thecheatscalc, Hi again, I just got my align 420lf and esc 25a with pinions from grand rc. This may be a dumb question, but do I still need to connect the white wire and the pink wire coming from the receiver that used to be directly connected to the stock motor to the black wire and red wire coming from the esc on the side toward the receiver. I assume I do. If so, which one to which, to make sure i get it right. I did connect them and it seemed to work ok but the motor starts hard and fast, (around mid throttle). I am guessing it's set on airplane mode and not heli mode? I don't know, I'm new to the hobby. Like everyone else my stock motor would barely lift it off the ground and wouldn't hold for long and got really hot, so I'm hoping this motor will help. Also can you give me a little insight on how to program it, the instructions are kind of unclear. And what settings do you have yours set on. What do you reccomend? Thanks, us newbies sure appreciate your expertise.
