thecheatscalc
GA, USA Status: offline
ok ablsoute necessitys:abs blades (invencible), brushless motor. you already have one of those so you're doing fine, ok how does it fly for you? I thought it flew quite nicely, after completly dissasemling this heli my idea of it is that it's built well, my electronics are in great condition and work great. when flying it make sure you remove the screws on the servos, this will alow the horns to pop off if you crash saving your servos. as for your tail servo make sure that the gyro movment rate isn't too high, this only controls how much you can move this servo si if you turn it way down you can't spin fast. ok besides that make sure you're blades are aligned and the paddles are at the same legnth, never more than 2 degrees. The main blades should never get more than 14 degrees. and for best reception wrap the antenna around the rear servo mount and the horizontal fin taping the last cm pointing straight up. that should be it please post if you have any more problems.
_____________________________
www.ushobbysupply.com - your #4 HQ! All stock located in the U-S of A!
