IronicRcAv8r
Joined: 5/25/2002 From: Fenton, MO, USA Status: offline
quote:
ORIGINAL: sseward GeeBees....Already hit the Lowes, Home Depot and even an Auto parts store. The problem is, the longest thing they had in M4 (Metric) was 20mm. With the spacer required, and the thickness of the firewall I'm needing about a 50mm long bolt. That would be about 2" in an 8-32. Anyway, problem is solved, although it will delay me a bit. I order 50 and 60mm M4 socket bolts from MicroFasteners tonight. I'll just skp ahead to the wing mounting and radio install. Tomorrow I'm building the test stand for the RCV, so I'm hoping I'll have the engine run in before I get the bolts, that way I'll be ready to go! Steve Steve I found M4 X 50mm at my local hobby shop in the car section (don't tell my friends I was in the car isle). They were the perfect size with my standoff's
