RE: P-6E Curtis hawk (build thread)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: P-6E Curtis hawk (build thread)
Page: <<   < prev  44 45 [46] 47 48 49 50 51 52 53   next >   >>
Login
RE: P-6E Curtis hawk (build thread) - 3/5/2007 11:31:45 PM
metaldriver
Status: offline
Just a quick question fellows, has anyone tried this plane with the st .90 or something similiar as all I can see is 120 4s or better?
(in reply to Skinny Bob)
       Post #: 1126
RE: P-6E Curtis hawk (build thread) - 3/5/2007 11:38:34 PM
mass balance
Status: offline
Great information, thanks guys! Last time I looked, Adam was recommending that people call Brillelli for a muffler so I will go that route and give Scott a call. It's no hurry since another plane is in the assembly line ahead of the Hawk. I'll check the choke lever also as thevirginian suggests. If I could remove the choke altogether I might consider it - the BCMA 40 with the Zama carb does great w/o a choke and I am using an RCATs relay for a remote kill switch. My Sport 26 has a Walbro carb though, so I'll have to look at it.
mass balance
       Post #: 1127
RE: P-6E Curtis hawk (build thread) - 3/6/2007 12:17:40 AM
Skinny Bob
Status: online
mass balance, by all means call Scott. A great guy that will help you all he can. I forgot to mention the choke, I cut the lever off of mine and hacksawed a screw driver slot in the head of the shaft. I then cut a small hole in the bottom of the cowl under the carb for choke access. I also cut an elongated hole under the carb needle valves for easy access to them with a small screw driver. Has worked out very well for me. I suggest you keep the choke, especially if you want to flip start your engine. If you think about it most gasoline engines have a choke, 2 and 4 cyl. Guys who don't have a choked engine are always talking about various methods of choking the engine, I am sure you have heard them all. My Brillelli didn't have a choke when I bought it, I later replaced it with a carb that does. I believe Scott has choked carbs on all his engines now. I may be wrong about that. Ask Scott. Enough of my rambling.
Regards
_____________________________
Skinny Bob - AMA 713081
WACO Brotherhood #10
(in reply to mass balance)
       Post #: 1128
RE: P-6E Curtis hawk (build thread) - 3/6/2007 12:38:02 AM
Skinny Bob
Status: online
Yes, somewhere in this thread someone talked about running a 90. Not sure how it worked out. Great Planes says 90 - 120 four stroke, why wouldn't it be ok? I'm sure they tested it.
Have fun
(in reply to metaldriver)
       Post #: 1129
RE: P-6E Curtis hawk (build thread) - 3/6/2007 2:30:00 AM
thevirginian
Status: offline
metaldriver,
A 90 in the Hawk is like a Ford Pinto with a banana in its tail pipe. Forget it . The minimum engine is a 120.
skinny Bob, I certainly will post pictures of the new muffler, once I have receive it.
mass balance, I will keep my choke for sure. I just had to cut the shaft off to the minimum. That's the only thing I dislike on this motor: the choke ass'ly is on a plastic shaft and I don't know how to take it apart. There is no screw to hold the butterfly on to the shaft.
       Post #: 1130
RE: P-6E Curtis hawk (build thread) - 3/7/2007 5:30:55 AM
metaldriver
Status: offline
I was talking .90 2 stroke and as for it not being enough to fly the plane I have to disagree as mine flys quite well with it. Not unlimited on the verticals but neither was the full scale one.
(in reply to thevirginian)
       Post #: 1131
RE: P-6E Curtis hawk (build thread) - 3/8/2007 2:00:12 AM
GaGeeBees
Status: online
quote:
ORIGINAL: thevirginian
metaldriver,
It'll fly with a .90 four stroke too. It just flies better with a 1.20. I think a .90 RCV would be an interesting experiment. It would swing a large prop.
...and then the unthinkable happened!
       Post #: 1132
RE: P-6E Curtis hawk (build thread) - 4/9/2007 1:34:01 AM
thevirginian
Status: offline
Well, I finally received my rear dumb muffler for my Brillelli 26SS. As ususal Scott did a great job. The muffler fit perfectly although it's quite large for this small gasser. Since the muffler was the only thing I was missing for my "second" maiden flight, she was ready for it the next day. Although the wind was howling from the west with 15-20 I had to fly her. I waited for this flight 'til later in the afternoon and was lucky as the wind eased off. Upon take off I instantly felt the extra power of the Brillelli compared to my other motor, the FPE 1.3 I had installed before. I also switched from a two bladed prop (16x8) to a three bladed prop with 15x7 just for the scale looks. I have not tached the motor yet, but I can tell from the sound it's turning well over 7K. So far I am very happy with this engine choice, since this motor is a featherweight for its diplacement. Whatever Scott does to these engines, it seems to be the proper tuning. I certainly will purchase more motors from him for my future projects. The Hawk flew nicely before, but now I can feel its real value.
(in reply to GaGeeBees)
       Post #: 1133
RE: P-6E Curtis hawk (build thread) - 4/9/2007 2:00:23 AM
flyfisher431
Status: offline
Congratulations Virginian,
Sounds like the hawk is doing you proud. I' Figure It wioll be mid May when I start work on mine.
Ben
       Post #: 1134
RE: P-6E Curtis hawk (build thread) - 4/9/2007 2:29:32 AM
thevirginian
Status: offline
As usual I forgot to attach the promised picture of my new muffler. Here it is now.
Click to see fullsize image.
Click for fullsize
       Post #: 1135
RE: P-6E Curtis hawk (build thread) - 4/9/2007 6:23:07 PM
jcw111
Status: offline
While on the subject of Exhausts again I would like to offer assistance to anyone considering rtro fitting a Kelio exhaust to a HAWK. I did mine a few months ago and could have used a few suggestions other than those offered by Kelvin in his instructions. While it is pretty straight forward Getting the alignment of the stacks to a cowl that has already been mounted can be a real challenge. Finally got it right and it sure makes a world of difference in the scale looks of the plane. The engine is a FS OS 120 and is plenty of power for real scale like flight speed. Kelvin did a great job with the exhaust as has been mentioned in earlier posts.
So if anyone is considering the above rather than re-inventing the wheel----I would be happy to supply pics and comments.
Jim Whitney
       Post #: 1136
RE: P-6E Curtis hawk (build thread) - 4/9/2007 6:46:50 PM
jcw111
Status: offline
Forgot to mention in the above post----------I am using the Spectrum DX 7 radio with no problems at all. Solid as a rock.
Jim Whitney
(in reply to jcw111)
       Post #: 1137
RE: P-6E Curtis hawk (build thread) - 4/9/2007 10:16:16 PM
flyfisher431
Status: offline
Jim
By all means I am a fan of not reinventing the wheel. My Hawk exhaust should be here in the next few weeks so if you have pictures and words of wisdom by all means please post them. BTW I'll be using a Evoulution 26GT for my engine.
Ben
       Post #: 1138
RE: P-6E Curtis hawk (build thread) - 4/10/2007 1:02:57 PM
thevirginian
Status: offline
flyfisher,
you may want to check for any interference of the carboretor with the cowl, before you mount the motor. As far as I know the Evo 26GT has its carb situated like a two stroke glow engine, up front. But since the carb is quite bigger than a glow engine carb, you may check for proper clearence.
(in reply to flyfisher431)
