LuvBipes
Joined: 12/29/2001 From: Luxembourg City, LUXEMBOURG Status: offline
Ed, you're on to something regarding proportionally decreasing fuel consumption as displacement of big 2-stroke glow engines increases. I regularly run 3 Moki 2.10, a Moki 1.80 and a Saito 1.50. Believe it or not, but the 2.10 Moki uses LESS fuel than the Saito 150 - and it's cheaper (5% Nitro) fuel at that! My usual flight envolves a fairly rigorous 10 min IMAC-style airobatic routine. With a 24oz tank, I have +/- 11 oz LEFT in the tank w/ the Mokis (14 lbs plane), but only 3 oz left after the same type of flight (also 24 oz tank) with the Saito on a 11lbs plane. And no, I'm not runing the Saito too rich . Staying on topic, I finally test ran my new OS 120 AX this weekend. Did a quick 10 mn run on the ground alternating between slobbering rich and fast 4 stroking then flew it fairly rich for 2 flights. The engine started all times on the first or second back flip if well primed and was totally reliable. I had to close low speed NV 1/8 turn to get good transition. I fed it the 5% Omega I usually use w/ my Mokis and it liked it fine. Even running fairly rich in the air (just breaking into 2 stroking), it pulled ny 10.5 lbs 68" WS Extra with great authority. I think I'm gonna like this engine. Oh, It also sound great w/ the new factory pitts-style muffler.
< Message edited by LuvBipes -- 5/22/2007 3:23:16 PM >
_____________________________
Keep your eyes in the skies and your future should follow.
