RE: NEW OS MAX-120AX RING !!!
Tower Hobbies
Logged in as Guest
  Printable Version
Touchstart Remote Controlled Autostart Engine .61 ASP COLLECTORS !!!!!!!!!!!!!!
Seller:  vidal_felipe
Details:   $499.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: NEW OS MAX-120AX RING !!!
Page: <<   < prev  3 4 5 6 7 8 9 10 11 [12]
Login
RE: NEW OS MAX-120AX RING !!! - 10/27/2007 10:03:26 PM
Planeclothes
Status: offline
I had been running my 120 AX for more than a year. First it was mounted on a Seagull Laser and lately on a FuntanaX100. These past few months the engine became erratic and nothing I tried seemed to work (changed fuel brand, tried different glow plugs, adjusted needles, etc.), and just when I thought I had it right, problems would come right back. I was lucky I didn't lose my Funtana with so many dead stick landings. Most of the times the engine would just die when going full throttle after a few seconds running at midrange. Well fortunately, it was still under warranty and I sent it to Hobby Services. They said the cylinder liner and piston had scoring, the rear bearing was "rough", and the carb was no good, so they sent me a brand new engine (That's first class service). Apparently, there was evidence of corrosion inside the engine causing all these problems. I guess I will become a little more anal about burning out all the excess fuel and using after-run from now on.
< Message edited by Planeclothes -- 10/27/2007 10:05:23 PM >
_____________________________
I'm only in it for the money...
(in reply to kochj)
       Post #: 276
RE: NEW OS MAX-120AX RING !!! - 10/28/2007 8:16:41 AM
ggroyal1
Status: offline
Marvel air tool oil is the best after run and use plenty of it. I have lots of OS engines from .46 to 120. No problems over two years. Don't skimp on the after run and use it after each flying session. Marvel air tool oil is only $1.99 a bottle, I get mine at Pep Boys. MARVEL AIR TOOL OIL
George G. Royal
(in reply to Planeclothes)
       Post #: 277
RE: NEW OS MAX-120AX RING !!! - 11/1/2007 8:24:22 PM
planeblahblah
Status: offline
How many rpms did you gain from just switching to ys 20/20. I been flying my p-40 around and its great i think i might be faster than the ys 110 4 storke guys . Also what header are you using for that tuned pipe ?
< Message edited by planeblahblah -- 11/1/2007 10:04:02 PM >
(in reply to kochj)
       Post #: 278
RE: NEW OS MAX-120AX RING !!! - 11/2/2007 2:22:11 AM
Planeclothes
Status: offline
quote:
ORIGINAL: ggroyal1
George G. Royal
Thanks George. I have I used a 50/50 mix of Marvel Mystery Oil and Transmission fluid as after run. Do you think this Marvel air tool oil is better?
(in reply to ggroyal1)
       Post #: 279
RE: NEW OS MAX-120AX RING !!! - 11/2/2007 4:41:26 AM
ggroyal1
Status: offline
Yes, the Marvel air tool oil is the best for glow engines. It lubricates, protects, and removes moisture. This info has been backed up by several bearing and air tool companies. I have nothing to do with Marvel oil company, I just use it and recommend it.
George G. Royal
Click to see fullsize image.
Click for fullsize
< Message edited by ggroyal1 -- 11/2/2007 4:43:27 AM >
       Post #: 280
RE: NEW OS MAX-120AX RING !!! - 11/3/2007 6:27:42 PM
Planeclothes
Status: offline
Thanks. I think I'm going to give it a try. I just ran my new 120AX for the first time. Just filled the tank, opened the needle valve 3 turns, primed the engine, connected the igniter, gently turned the spinner clockwise, and the engine starts running in "4 cycle" operation. It's amazing, I had already forgotten how good this engine runs. This also clearly shows the old one had some real serious issues.
       Post #: 281
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.672RCU1
