RE: 40% Carden Extra 260 - My 1st Carden Build
Tower Hobbies
Logged in as Guest
  Printable Version
Universal Cradle System
Seller:  flyn4wrd
Details:   $175.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: 40% Carden Extra 260 - My 1st Carden Build
Page: <<   < prev  1 2 [3] 4 5 6 7   next >   >>
Login
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/17/2005 11:53:13 PM
as722
Status: offline
Hi, Kregg.
Looking good, You might want to consider making a bottom removable hatch on the bottom rear of the fusealage, it will make life easy if you ever have to get back there. I'll post a picture of mine later.
Albert Santiago
_____________________________
Carden Aircraft
(in reply to Kregg)
       Post #: 51
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/18/2005 1:46:56 AM
jjamesrb
Status: offline
Hi Kregg,
You made the same mistake on your hatch bottom as i did, the strips don't go all the way back, if you look on the print (which i thought it was built the same way the 330 was but its not) the 1/8 sheeting starts in the foam area, i had to cut the small strips back,no big deal.Other than that everything is looking great.All i got left to sheet is the wings.
(in reply to as722)
       Post #: 52
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/18/2005 9:30:33 PM
Kregg
Status: offline
James, Do you mean the 1/2 inch wide strips under the top hatch? The top hatch being the part in front of the clear canopy. I'm not following you on your point. I will look at the plans closer this evening.
Alberto, I would love to see pix of your hatch. Please shoot away.
Thx,
Kregg
Virtual Cockpit Kits (www.wrightrc.com)
They look like the real thing and only weigh a couple ounces!
(in reply to jjamesrb)
       Post #: 53
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/18/2005 9:58:28 PM
jjamesrb
Status: offline
Hi Kregg, yea the 1/2 wide strips under the top hatch ( and make sure you use 1/8 for stripping not 1/16). Look at the blueprint and you can see where the strips end and the 1/8th inch balsa sheeting begins for the flooring under the canopy.The 1/8th inch balsa sheeting glues to part of the top hatch under the canopy.
(in reply to Kregg)
       Post #: 54
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/18/2005 10:00:31 PM
as722
Status: offline
As promised.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Carden Aircraft
(in reply to Kregg)
       Post #: 55
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/18/2005 10:05:03 PM
as722
Status: offline
If you decide to go with the removable hatch make sure you install gussets on the 3/8" square cross and diagonal members. I know a few guys that didn't do this and later whished they did. ( where are you Rob T.) LOL.
Albert Santiago
Carden Aircraft
(in reply to as722)
       Post #: 56
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/18/2005 10:06:12 PM
jjamesrb
Status: offline
You definitely want the removeable hatch underneath.Getting to the servo connections otherwise would be very difficult and if you need to add weight you can add it to the bottom hatch.
(in reply to as722)
       Post #: 57
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/18/2005 11:27:46 PM
Kregg
Status: offline
James, Thanks for the detailed description. Now I understand. I already used 1/16 for the strips. I guess I will just double them up where needed and remove for the floor.
Alberto, Thanks! Those pix are perfect. That is a very nice mod and I will do the same. Makes perfect sense.
       Post #: 58
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/21/2005 1:31:14 PM
PJFaller
Status: offline
Kregg,
Hows it coming...Keep this thread alive!!! Im just finishing my 40% Carden 330...hope to fly it soon.
Pete
(in reply to Kregg)
       Post #: 59
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/21/2005 6:30:51 PM
Kregg
Status: offline
Updates are going a bit slower. Here are a few.
These pix show the installation of the servo wire tube and the twin antenna tubes. I stole a clever idea from a friend. Look closely at the antenna tube. A thin thread has been preinstalled in these tubes to make the RX installation nice and smooth. After it is installed the thread will remain attached to the antenna end and the extra thread will be wrapped around something for use later. When you need to remove the RX, just slide it out and the thread is back in place.
Not quite genius, but simple and effective.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to PJFaller)
       Post #: 60
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/21/2005 6:36:21 PM
Kregg
Status: offline
Next I have started gluing on the large fuse pieces. I used Ultimate glue on the large bottom panel since it is foam to wood. I used wood glue for the turtle deck since it is wood to wood. The fuse is starting to take shape. Another pic shows the rear ply plate for the beginning of my rear bottom hatch like someone showed above. Lastly, I have glued in the stab tube of my horiz stab cores. waiting for the Ultimate glue to expand and dry.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Kregg)
       Post #: 61
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/22/2005 1:18:29 AM
btomlinson
Status: offline
Lookin good Kregg... how much time would you estimate spent so far ??
Brian
Brian Tomlinson
www.tomlinsonmachineandtool.com
(in reply to Kregg)
       Post #: 62
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/22/2005 1:01:21 PM
Kregg
Status: offline
If I had worked straight through to this point and not had to wait for glue to dry. I would say 25 hours??? Maybe. That would not include the 20 hours standing around looking at what I have done and what I need to do next. I often grab a beer or two and just look & think. Planning and anticipating is half the fun of building. Sometimes I almost feel let down when a project is finished. Then I start flying and forget about it.
< Message edited by Kregg -- 10/22/2005 1:04:35 PM >
(in reply to btomlinson)
       Post #: 63
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/22/2005 1:06:52 PM
cbk07
Status: offline
Kregg, it looks like your moving right along. I know a weak point on these is where the Rudder counterbalance meets the rudder (at the 90 deg cut). The guys up here have been boring a hole from the top of the counterbalance back at a 45 deg angle towards the trailing edge of the rudder. It passes right near the cutout. Then polyurethane in a small carbon rod. It eliminates the small crack that always seems to start there. I can forward a pic if it will help as my description is a little weak. Talk to you soon, Craig
       Post #: 64
RE: 40% Carden Extra 260 - My 1st Carden Build - 10/22/2005 3:06:51 PM
btomlinson
Status: offline
cbk07... please post a pic of this coutnerbalance modd
< Message edited by btomlinson -- 10/22/2005 3:07:30 PM >
Brian Tomlinson
