Kregg
KY, USA Status: offline
Tony: Thanks for the header comments. I spoke with Brian @ DA and he indicated about the same as you have. He said if they were a bit longer I would loose a small amount of power but have better transition. He also recommended that I buy new KS headers that will fix my alignment problem. I ordered them from DA. Jim: Thanks for looking out for me and please keep that up! I want a extra set of eyes on my build, just in case I screw something up. However, in this case I'm OK. I have not glued in stab tube or wing tube. The stab tube is just in place loose. I understand the wing alignment issue. I will be starting on the wings soon. I'm working on the 4 large sheeting pieces. Dave: Please talk with your friend and post pix of the diet if you can. I have been Conservative so far, but I'm going to step up that issue. When speaking with Brian Huffmeier he told me about some areas to lighten as well. He is going to give me pix and I will share them here. Brian has more experience with the 260 than about anyone, so I trust him. I was nervous about the big lightening holes I added to the gear plate (per the plans), but Brian is doing lots more with no problems. We will see. I will be getting my Dremel busy with more holes very soon as well. Thx, Kregg
_____________________________
Virtual Cockpit Kits (www.wrightrc.com) They look like the real thing and only weigh a couple ounces!
