RE: PHOENIX MODELS F-20 TIGERSHARK ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: PHOENIX MODELS F-20 TIGERSHARK ?
Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/3/2006 9:46:05 AM
uav-oscar
Status: offline
Bigger prop + more h.p. = more speed ?? + I also have an OS 91 fx engine = cheaper then buy a new 50 or 60 size
only question if the airframe strong enough or not???
thnx
Oscar
(in reply to nitro-pilot)
       Post #: 276
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/3/2006 2:07:47 PM
nitro-pilot
Status: offline
I didn't realize bigger prop provided more speed, I thought rpm and pitch were the idea? I'm sure you pick up some speed, but weight and high rev engines were the real advantage. Any engineers online to help out further?
(in reply to uav-oscar)
       Post #: 277
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/5/2006 4:37:19 PM
nchrome
Status: offline
Okay you speedfreaks gots a question for you all to possibly answer. Do any of you guys have a photo of the tail cones or exhaust of a F-20 Tigershark. I'm doing a little more stand off scale and don't have any photos to try to duplicate it. Don't know for sure how fast mine will be cause I'm going to use a Fox 75 on mine with a 13/8 prop.
       Post #: 278
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/5/2006 10:28:21 PM
Cyclic Hardover
Status: offline
YOu may know this already but in case you don't. Do you mean the actual F-20 or the F-5? I think Kangke and Cermark F20 are actual F 20 backends where as their is only one single tail cone. All the others that have like a flat back end represent the F-5 series which was a twin engine.
_____________________________
Retired Army Aviator - Excuse Me! You sold me a hair with a cake around it!
(in reply to nchrome)
       Post #: 279
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/6/2006 11:03:19 AM
hummingbird111
Status: offline
here's a shot of the Sportsman Aviation version... i added the two tail cones...
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to Cyclic Hardover)
       Post #: 280
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/6/2006 2:12:10 PM
nchrome
Status: offline
That's what I'm looking for thanks. Just a little twerk in the back of my head that I wanted to do. This will do just fine. Mines going to be done in a gloss gray and possibly panel lines and fixed gear. Another flyer in the club has one of these and his realy burns holes in the sky. Now all we have to do is patch the sky after he flys.
(in reply to hummingbird111)
       Post #: 281
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/6/2006 9:49:25 PM
Cyclic Hardover
Status: offline
If you go to McDonalds and get those plastic Ketchup cups, they fit just right for a set of tail cones
       Post #: 282
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/7/2006 8:34:25 PM
GMoneyPit
Status: offline
Can someone post a link to where Jett engines can be purchased?
Gary
(in reply to Razor-RCU)
       Post #: 283
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/7/2006 10:26:19 PM
bob27s
Status: offline
quote:
ORIGINAL: GMoneyPit
Gary
www.jettengineering.com
Bob
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to GMoneyPit)
       Post #: 284
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/7/2006 10:28:33 PM
vicman
Status: offline
I almost did that but didn't want to steal Bob's thunder.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
(in reply to bob27s)
       Post #: 285
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/8/2006 3:49:03 PM
bob27s
Status: offline
quote:
ORIGINAL: vicman
Thanks...... my thunder is my life
(sad huh.... )
Bob Brassell
(in reply to vicman)
       Post #: 286
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/8/2006 3:58:59 PM
vicman
Status: offline
Here is a neat cut-away if anyone is interested.
Click for fullsize
       Post #: 287
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/10/2006 5:06:12 PM
GMoneyPit
Status: offline
I understand that one of the best engines for this plane is one of the Jett engines. Many of you have tried running an OS 46FX before switching to the Jett or other engine. What kinds of speeds would one expect with a properly propped 46FX with no special exhaust, just a Tower tuned pipe (the $15 job)? I'm in GA at about 300' elevation.
Gary
(in reply to HaveBlue)
       Post #: 288
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 8/10/2006 5:41:14 PM
Kmot
Status: offline
quote:
ORIGINAL: vicman
Just goes to show how un-F20 like our planes are!
DRILL BABY DRILL!!!
       Post #: 289
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 9/8/2006 2:10:03 AM
mlitt12345
Status: offline
Hello all, I have a Phoenix F20 on the way from tower hobbies, I have been reading the forums and am still undecided on engine set-up, so any help-advice very much appreciated. I cant afford a Jett engine at this time but can stand adding a jett $49 muffler to a cheaper engine. So here are some of the engines I'm thinking about but need help deciding which combo works best I do want as much speed as possible and what props to use also...............thanks mlitt12345
OS50sx $159 1.8 power / 17000rpm weight 13.7oz w/o muffler
OS46ax $114 1.65 power / 16000rpm weight 13.2oz w/o muffler
OS40fx $110 1.36 power / 16000rpm weight 13.6oz w/o muffler
G51 $80 1.48 power / 15500rpm weight 12.7oz w/o muffler
TT46 $88 1.43 power / 16000rpm weight 17.1oz with muffler
< Message edited by mlitt12345 -- 9/8/2006 2:11:02 AM >
(in reply to crasharama)
       Post #: 290
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 9/8/2006 2:55:28 AM
Logan X
Status: offline
People at this model it is possible to be put retract to eliminate drag?
(in reply to mlitt12345)
