RE: PHOENIX MODELS F-20 TIGERSHARK ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: PHOENIX MODELS F-20 TIGERSHARK ?
Page: <<   < prev  13 14 [15] 16 17 18 19 20 21 22   next >   >>
Login
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/8/2006 3:30:36 AM
Kmot
Status: offline
The prop I am using right now for break in is a Top Flite Power Point 10x6. Turns out, it was almost in balance. Not enough to worry about anyway. But the Dave Brown spinner was the problem. I ended up drilling the backplate to get it balanced, and then the cone made the assembly out of balance again. I just kept rotating the cone a few degrees at a time until I found the 'least' OOB condition and made a reference mark for assembly. And I did a few extra props.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
DRILL BABY DRILL!!!
(in reply to Kmot)
       Post #: 351
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/8/2006 5:33:34 AM
Flyboy Dave
Status: online
....good job, Tom....
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to Kmot)
       Post #: 352
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/9/2006 9:11:18 PM
mlitt12345
Status: offline
After 7 flights the F20 tiger shark is toothpicks, elevator fludder got it, I've been hearing a fluddering sound but could not see any control surfaces moving thought it was landing gear (I should've replaced the stock horn) I lost elevator control and went nose in at high speed.....ripped the jett muffler off the os50sx, one of the muffler ears broke completely off so it is no good the engine might be ok(just got dirt in it and broke where the muffler mounts on the forward end) , i wonder if I can get a new front housing for the jett muffler, oh well....gravity happens sometimes......live and learn.... mlitt12345
(in reply to Kmot)
       Post #: 353
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/9/2006 9:38:45 PM
bob27s
Status: offline
mlitt,
sorry to hear that. Hopefully folks pay heed to the linkage on thei Phx F-20, and your sacrafice does not go to waste.
The muffler usually can be repaired. Email Dub jettengr@sbcglobal.net
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to mlitt12345)
       Post #: 354
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/9/2006 11:31:40 PM
crasharama
Status: offline
Hi mlitt12345,
Sorry to hear yours is gone too, that is the 2nd of these to succome to elevator horn failure. Did it have those soft horns in the kit, as mine did, as well as that bizarre linkage system that I talked about before.
Tony
This is what I have done to my F20 since this happend
Click for fullsize
Click for fullsize
www.coolumflyers.com
Revver Brother 116
       Post #: 355
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/10/2006 1:22:15 AM
mlitt12345
Status: offline
crasharama my elevator horn looks like yours (white-plastic) in fact it separated at the same spot, So any one else flying with the stock elev. horns (change-them) I wish I would've seen the elevator control surface fluddering, kept hearing a fludder but could not see it....those stock white plastic elev. horns will not hold up to much fludder for sure, I will use HD robarts or equivelant from now on....mlitt12345
(in reply to crasharama)
       Post #: 356
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/10/2006 1:24:11 AM
TOFAST4U2C
Status: offline
Was the hinge gap sealed on the other side?
Born to CRUISE, Forced to Work!
       Post #: 357
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/10/2006 1:29:19 AM
mlitt12345
Status: offline
here are a few pics, I believe the engine and jett muffler our salvageable will have to use nuts to hold the muffler on.......you can also see where the muffler broke away from the engine......mlitt12345
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Kmot)
       Post #: 358
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/10/2006 1:37:44 AM
mlitt12345
Status: offline
The hinge gaps were not sealed on mine..........sorry for the large pics......Dont know how to shrink them down.....mlitt12345
       Post #: 359
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/10/2006 2:05:23 AM
vicman
Status: online
Broken Tiger Sharks are always a painfull sight.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
       Post #: 360
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/10/2006 2:46:22 AM
Cyclic Hardover
Status: offline
quote:
ORIGINAL: bob27s
mlitt,
Well this just wants to make me run and finish this tomorrow? You guys think this is a "horn" failure? If it makes ya feel any better. When my cermark f20 went in on flutter a coupl e years ago, my Jett 90 muffler broke in the same spot. Sent it in to dub and fixed it right up--at a reasonable fee of course
< Message edited by Cyclic Hardover -- 10/10/2006 2:54:22 AM >
Retired Army Aviator - Excuse Me! You sold me a hair with a cake around it!
(in reply to bob27s)
       Post #: 361
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/10/2006 3:56:12 AM
Flyboy Dave
Status: online
I doubt that it was the control horns fault....the elevator fluttered, and the horn
broke....as a result. The straight hinge on the F-20 is the culprit....poor
design. The angled hinge lines, like on the Patriot is the correct answer.
FBD.
Revver Bro #4.
(in reply to Cyclic Hardover)
       Post #: 362
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/10/2006 4:44:43 AM
Kmot
Status: offline
I am wondering if I should put some clear tape over my hinge lines? I have hatch tape that I use on my boats.........
DRILL BABY DRILL!!!
(in reply to Flyboy Dave)
       Post #: 363
RE: PHOENIX MODELS F-20 TIGERSHARK ? - 10/10/2006 4:53:02 AM
Flyboy Dave
Status: online
....yup....
....anything over 100 mph needs to be sealed on the hinge line.
Revver Bro #4.
(in reply to Kmot)
