crasharama
Joined: 3/18/2005 From: Mt Coolum QLD, AUSTRALIA Status: offline
I was looking through the Gallery search here on RCU last night & came across another F20 in OZ. The guy lives in Tamworth, & sure enough it had the same tail set up as ours. There was a few weird bits in our destructions, & 1 was to put in the hinges for the rudder & elevator, but they were already done & pinned... I don't want to start the great Monocote VS everything else debate, but that Oracover is great stuff to work with, & I can see why ours were so smooth. I bought some Profilm (Oracover) last week to cover the wing & tail on my S1d Pylon model, & it turned out super smooth, like Kmot said, it needs the heat to work. I have only used an iron on mine & it worked well. I wouldn't bother with the nylon bits, I would just upgrade them straight away, once bitten twice shy. My Jett wouldn't come close to fitting in that engine mount, so like Blue's I had to widen the mount out around the rear bearing. I was a bit worried about doing that, but it was one of the few things that stayed together when it hit the ground Flip on ours that little red covered square bit of wood was to fill the gap in the tail when you fitted the Hoizontal stab in place. Tony.
_____________________________
www.coolumflyers.com Revver Brother 116
