Kmot
CA, USA Status: offline
Thanks for the comps', B'buster! I got the Rx; switch; and battery installed today and tucked in nicely with foam. I ran my Rx antenna forward, then through the top of the fuselage, and back to the horizontal fin. Need to get a hook. I need to seal up the fuel tank opening but first I need to do a CG test. If all is well, I can seal up the fuel tank area and the plane will truly be finished. Except for breaking in the engine. Still need to pull it off the plane and do that. Sorry I do things so slow. I spent most of my energy today building a buffing motor stand........
_____________________________
DRILL BABY DRILL!!!
