Moparman1
CO, USA Status: offline
Looks like this forum has been busy in the time I was gone... "Savagecrazy", routing a line from the exhaust to the intake is the last thing you want to do. The only way the system you are describing could work is if there were a way to filter the unburned oil/fuel out of the exhaust and then recirculate it into the engine, but realistically there's no way to do this. I suppose you could cool the exhaust to the point that the oil/fuel would condense into droplets, but again the problem would be extracting the oil/fuel from the exhaust system. "Dfn doe", there's one thing you are forgetting about RC's that counteracts a pressurized intake; the pressure line that runs from the tuned pipe to the fuel tank. Although I'm not sure if all 2-stroke powered RC's have this system, I know that most cars and boats do. Obviously an increase in air/fuel being combusted would lead to an increase in exhaust pressure, and inturn increased pressure in the fuel tank. This alone will not compensate for the additional fuel needed, especially when trying to counteract a pressurized carb, but I will include a section of larger diameter fuel tubing in the kits that will help increase pressure in the tank. Unfortunately this would mean that the fuel tank would need a latch or something to hold it closed under the additional pressure. I'd like to understand your thinking behind your idea to move the exhaust port up in the cylinder, because doing this would make the exhaust open earlier in the cycle, reducing power output. If your idea was to increase the amount of time it would be open to aid in scavenging, a simpler solution would be to widen the exhaust, which would allow more exhaus gas out without affecting timing. I understand that valve overlap must be reduced on a 4-stroke to minimize pressure losses through the exhaust when super/turbocharging, but a 2-stroke is an entirely different machine. No matter how it's designed there will always be port timing overlap. Honestly I don't see the need to change the exhaust timing on these engines, especially since they consume fuel as quickly as they do. Finally, "popadel", as I said before my turbo's bearings are oiled by the unburned oil in the exhaust, so oil entering the turbo (whether from the exhaust or intake) is nessisary. A spinning turbine acts just like a centrifuge, it flings anything in contact with it outward. When oil comes in contact with the turbine it is flung against the walls adjacent to the travel of the turbine, and on my design, onto the bearings. This provides the bearings with a constant supply of oil. I'm quite aware of the dynamics of a running engine and the effects of the sonic waves in a tuned pipe contacting a solid object, which is to bounce back. "Dfn doe" I don't know if you were trying to explain how a tuned pipe works to me or to "Savagecrazy" (or both), but what I was saying on the other forum was that the explosion that's created in the combustion chamber traveling into the exhaust port and a portion of header is what causes this pressure wave. All waves traveling through a gas are technically sound waves, what we refer to as the speed of sound is actually the lowest audiable sound we hear. I'm not trying to be rude, I'm just showing that I am prepared for the many hurdles involved with designing a fully functional turbo. By the way, does ANYONE have suggestions on how to strengthen my turbine castings?
