g-202 engine installation help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> g-202 engine installation help
Page: [1]
Login
g-202 engine installation help - 10/1/2005 11:51:36 PM
zach123
Status: offline
I HAVE JUST BOUGHT A GILES G -202 FROM WILD HARE - MY FIRST GIANT SCALE PLANE - . I AM HAVING TROUBLE MOUNTING THE ENGINE , ITS A ZDZ 80 CC SINGLE - I GOT MY STANDOFFS FROM ROGER FORGUES AND IM READY TO GO JUST CANT FIGURE THE BEST WAY TO DO IT . I HAVE NEVER DONE THIS TYPE OF INSTALL BEFORE , SO ANY ADVISE YOU GUYS CAN GIVE ME , PICTURES ANYTHING WOULD BE GREAT . THANKS ALOT .
       Post #: 1
RE: g-202 engine installation help - 10/2/2005 12:40:19 AM
ben beyer
Status: offline
This is how I did the one that required a cut out:
1) Get the plane standing up like Tom says.
2) Get someone to help and hold the cowl off to the side but about where it will be when attached to the airframe.
3) Take a sharpie or something that can be removed with alcohol and mark on the cowl where you see the engine passing below the outline. Just a scribe mark. Do this for all four sides by holding it to the side and above the airframe.
4) Take a dremel tool and cut this area out. Take out the smallest possible area because you can always make it bigger.
5) Now use gravity to "hold" the engine in place and then put on the cowl. Make the necessary adjustments.
6) Now that it is big enough to accept the engine, line everything up and mark where the standoffs go so you can drill the necessary holes.
If you have any questions, feel free to post them or drop me a PM.
_____________________________
Team DOD Member
www.downonthedeck.com
(in reply to zach123)
       Post #: 2
RE: g-202 engine installation help - 10/2/2005 1:06:48 AM
zach123
Status: offline
so ben let me get this straight - you mark the cowl , then cut the cowl out to accept the engine , then put in the engine then place the cowl on , then mark and drill your holes , then i guess just screw the motor to the firewall . is that it do i have everything right and how it shoud be . let me know - thanks
(in reply to ben beyer)
       Post #: 3
RE: g-202 engine installation help - 10/2/2005 1:29:27 AM
ben beyer
Status: offline
Yes, sounds like you got it.
Team DOD Member
       Post #: 4
RE: g-202 engine installation help - 10/2/2005 1:43:17 AM
rctom
Status: online
It's a little more complicated than that. Did you read the manual?
If the standoffs bolt to the engine and you can set the engine on the forewall and it will stay in place it might be that simple. You may need to remove the carb to allow it to stand on the standoffs.
TF
       Post #: 5
RE: g-202 engine installation help - 10/2/2005 1:52:17 AM
zach123
Status: offline
yes i did read the manual ! This is my first install of this kind and i just want to do it right . i am a little confused but its getting better . your right i think i am going to need to remove the carb , i hope that is not any big deal ! . if you can think of anything else i should know please let me know . thanks .
(in reply to rctom)
       Post #: 6
RE: g-202 engine installation help - 10/2/2005 6:32:24 AM
Greg Cothern
Status: offline
Take some construction paper and tape it to the fuse where the engine will go beyond the cowl, place your engine on the standoffs and stand it up on the firewall as if it is mounted where it looks like it should go. Use the paper to make a good cutout template where the engine will extend through. Take the engine off put the cowl on, with the paper still taped on the fuse simple lay it over the cowl and you have a perfect template for what you need to cutout.
Then follow the reat as previously stated, works great.
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
       Post #: 7
RE: g-202 engine installation help - 10/3/2005 1:31:47 AM
Tired Old Man
Status: offline
With any of the single cylinder engines, it's often helpful to make a small bracing block that will support the cylinder head when you're positioning the engine. Those darn singles always want to fall over. don't forget to measure the distance from the firewall to the cowl face. Add 1/16 to 1/8" for spinner backplate clearance and that will be the size of the s
"stand off's" you will need. It's just as light, and cheaper, to make your own stand off's from hardwood blocks. If you make a block that runs the length of one pair of the mounting holes it's a lot easier to set the engine in place and position it rather than mess with 4 different legs. Another nice thing about only using two blocks is that you can scribe around the edges after the engine is properly located. Removing the engine from the blocks lets you sight through the mounting holes in the blocks and accurately drill the holes in the firewall.
Be certain tha all the stand off's or blocks are all the same length. The engine side thrust is already built into the firewall, and additional side thrust is not needed.
If you can''t fix it with a hammer, you have an electrical problem.
(in reply to Greg Cothern)
       Post #: 8
RE: g-202 engine installation help - 10/3/2005 2:20:34 PM
Shadow-RCU
Status: offline
Zach;
I live in Cape Coral and own one of Tom's Giles. Using his method I got the best engine fit I have ever had. I now do it on all my planes. If you want maybe we can get together and I can help. There are also at least two other people at the club that own a Wildhare that may be able to help you.
Let me know.
Randy
(in reply to Tired Old Man)
       Post #: 9
RE: g-202 engine installation help - 10/3/2005 7:14:55 PM
zach123
Status: offline
that sounds great - i did not know of anybody else in the club that had a giles ! . the others in the club are helping me right know , and you are welcome to also if you want to . i would like to meet up with you and check your plane out since you live so close . id like to see how you have it set up and everything . just let me know if you ever want to do anything like that , i am always checking my posts on here . hope to here from you soon - zach123
(in reply to Shadow-RCU)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.828RCU3
