Byrons fuel
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Byrons fuel
Page: [1]
Login
Byrons fuel - 10/2/2005 7:05:57 PM
ponderosa
Status: offline
lIs Byron's fuel still in existance? Their web address no longer works and Google does not return the home page for them.
Malcolm
< Message edited by hobbsy -- 10/2/2005 7:13:53 PM >
       Post #: 1
RE: Byrons fue; - 10/2/2005 7:11:55 PM
ponderosa
Status: offline
I forgot to specify I am interested in airplane fuel not car fuel.
Malcolm
(in reply to ponderosa)
       Post #: 2
RE: Byrons fuel - 10/3/2005 10:30:02 PM
carrellh
Status: offline
I saw it on the shelf at a Dallas shop last weekend.
_____________________________
Regards,
Carrell
       Post #: 3
RE: Byrons fuel - 10/4/2005 3:52:43 AM
depfife
Status: offline
http://www.byronfuels.com/
The website works for me.
(in reply to carrellh)
       Post #: 4
RE: Byrons fuel - 10/19/2005 2:50:24 AM
PlaneKrazee
Status: offline
I've been running Byron a long time now. Recently people have been saying that because Byron mixes by weight they have less oil than a Fuel that mixes by volume with the same percentage of oil listed.
Is this true? Does the oil weigh more than methanol?
KB1DTB
AMA11123
(in reply to depfife)
       Post #: 5
RE: Byrons fuel - 10/19/2005 3:54:05 AM
downunder
Status: offline
Both castor and synthetics have roughly the same density as water while methanol is a bit under 80% of water. If you mix your own fuel you'll see the oil just fall to the bottom until you shake it up.
As for Byron's..this was talked about over on SSW maybe a year ago and it seems it's mixed by weight. One of the guys did an evaporation test and fuel that was labelled 17% turned out to be more like 14% by volume. Mixing by weight is an excellent way to do it but only so long as it's to give the equivalent volume at a standard temperature (which is harder to do) and not to mislead. I'm only repeating what I've read on SSW because I've never even seen Byrons let alone tested it myself.
(in reply to PlaneKrazee)
       Post #: 6
RE: Byrons fuel - 10/19/2005 4:31:25 AM
Fuelman
Status: offline
Yes, doing the math using a handy little calculator that hauckf came up with. This is what you get comparing what is on the Byron label measured by weight vs. volume measurement at 20 degrees C (68F).
Byron Volume equivilent
0% nitro 0%
18% oil 14.85%
10% nitro 7.45%
18% oil 15.33%
15% nitro 11.36%
18% oil 15.59 %
30% nitro 23.92 %
18% oil 16.41 %
I'm not slinging mud here, these are just the facts.
Fuelman
Cooper Fuels LLC
(in reply to downunder)
       Post #: 7
RE: Byrons fuel - 10/19/2005 4:32:36 AM
Jim Thomerson
Status: offline
I found some numbers from a post on SSW.
Specific gravities at 20 - 25C
Castor 0.96
Methanol 0.79
nitro 1.136
Ucon 0.997
So you see that all the more expensive components are more dense than methanol. So 10% nitro by weight is thus less than 10% nitro by volume. It would be nice if the fuel manufacturer put on the fuel jug or can whether measure was by weight or by volume as the two measures are quite different.
       Post #: 8
RE: Byrons fuel - 10/22/2005 4:19:25 AM
vlizard
Status: offline
I used this fuel for about 15 years in the 80s-90s. While I have never had any problems that I know of it does disturb me to find out that I have been paying a premium price to get less nitro and or lube than I could have gotten with other brand for about 1/2 the cash all those years. Heck after getting back into glow Aircraft after a 9 or so year break I purchased 2 gallons of Byron's! I am going to try some of the other fuels that people have said that they are using. I think I may prefer the by volume method.
(in reply to Jim Thomerson)
       Post #: 9
RE: Byrons fuel - 11/15/2005 2:52:03 PM
PlaneKrazee
Status: offline
A friend was running Cool power 15% in his Saito 72 the other day and we switched to 10% byron fuel 18% oil. We had to richen the engine to prevent it running lean. I thought that if Byron had less oil and nitro it would have had to be leaned. It funny how things work.
KB1DTB
AMA11123
(in reply to vlizard)
       Post #: 10
RE: Byrons fuel - 12/19/2005 9:52:21 AM
viper07
Status: offline
ok i was told use nothing but Byron 20% in my Hyper 7 buggy but i have always been a Tornado fuel man.
Can i still use Tornado 25% in my buggy or is here any truth in what they say it will kill my engine a .21ofna
       Post #: 11
RE: Byrons fuel - 12/23/2005 11:15:10 AM
Fuelman
Status: offline
Viper,
Any quality fuel will be fine for your engine
Fuelman
Cooper Fuels LLC
(in reply to viper07)
       Post #: 12
RE: Byrons fuel - 2/8/2006 4:22:38 AM
diggin
Status: offline
what about in a CEN Nemesis ( big engine )
(in reply to Fuelman)
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
